- geofftl1000r
- Has thanked: 184 times
- Been thanked: 138 times
Got the oil temp. and pressure gauges fired up.
Picked a set of RX8 wheels from mi60o0 yesterday. Now to choose some tyres for them.
40th Anniversary RX8
- RXTaitt
- Has thanked: 33 times
- Been thanked: 37 times
They work well in the wet thanks for asking
Just had to wash all the crap of from having the tyres put on. White wheels may not have been the best idea...... Always need to be cleaned!
2004 231
Winning Blue
Knock off Toyo Cat back
Tein lowering springs
My on-going work on my car can be seen at the link below
viewtopic.php?f=104&t=82427&p=1286521#p1286521
Winning Blue
- mrspiller
- Has thanked: 280 times
- Been thanked: 763 times
I do enjoy clay barringGoobie wrote:First proper deep clean, now about to spend the next couple of hours clay baring followed by ceramic wax coat! Wish my wrists some luck.
- mrspiller
Car looks fabmrspiller wrote:I do enjoy clay barringGoobie wrote:First proper deep clean, now about to spend the next couple of hours clay baring followed by ceramic wax coat! Wish my wrists some luck.
- Has thanked: 2356 times
- Been thanked: 578 times
Started testing my lights. Getting closer
- These users thanked the author 30405 for the post (total 4):
- v-rex (Mon Aug 31, 2020 8:19 pm) • GreySilver Beast (Mon Aug 31, 2020 8:23 pm) • R1DSO (Mon Aug 31, 2020 9:13 pm) • ChrisHolmes (Mon Aug 31, 2020 11:30 pm)
- Scotty PZ
- Has thanked: 60 times
- Been thanked: 50 times
They are fantastic, do a group buy and im in!
- These users thanked the author Scotty PZ for the post (total 3):
- 30405 (Mon Aug 31, 2020 7:34 pm) • ChrisHolmes (Mon Aug 31, 2020 11:31 pm) • rotatopotato (Tue Sep 01, 2020 10:32 am)
Galaxy Grey PZ number 24.
- R1DSO
- Has thanked: 305 times
- Been thanked: 65 times
Not an RX-8, but doesn’t really warrant it’s own thread on ‘The other car’ either...
Installed new front lower control arms on my Landry with after market units fitted with Meyle bushings as the oil-filled bushings in the OEM arms had failed. Not the easiest job to do on my driveway - especially as the car’s air suspension (which was supposedly locked in low pressure ‘access mode‘) moved after disassembly. I had to manually depressurise the air out of the dampers to get the new parts in .
Anyway, no more knocks or wobbly steering now and better than paying £1,200 for a dealer to do the job . Just got to get a 4 wheel laser alignment booked in to fine tune my tracking approximations!
2009 R3 in sparkling black
Racing Beat REVi ram air duct
K&N panel filter
Suffix C Mazda coils
Magnecor leads
Racing Beat header / mid pipe
RRP engine mounts
Hel braided brake lines
Russell speed bleeders
Michelin Pilot Sport 4S tyres
R-Magic shift knob
Heel/toe pedal mod
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
- LeeW
- Has thanked: 198 times
- Been thanked: 128 times
I've got 2010 RRS that has the low speed knocking thing. Never had time to diagnose it fully as I don't know if its ARB bushes or arm bushes as I've heard that they're notorious for both. Interesting you've done that though and sorted it. It's got a horrific grind/squeal developed today though. Don't know what it is, maybe bearings. Maybe its the start of the dreaded LR ownership....R1DSO wrote: ↑Mon Aug 31, 2020 9:12 pmNot an RX-8, but doesn’t really warrant it’s own thread on ‘The other car’ either...
Kuro 174/500.
- R1DSO
If your RRS has the oil-filled rear lower control arm bushings and has done over 50k miles, I would strongly suspect the knocking is a failed bushing. I say ‘if’ as I believe some RRS had solid rubber bushings. It should be fairly easy to check by giving the control arm a waggle for excess movement with the wheel off.LeeW wrote: ↑Mon Aug 31, 2020 9:21 pmI've got 2010 RRS that has the low speed knocking thing. Never had time to diagnose it fully as I don't know if its ARB bushes or arm bushes as I've heard that they're notorious for both. Interesting you've done that though and sorted it. It's got a horrific grind/squeal developed today though. Don't know what it is, maybe bearings. Maybe its the start of the dreaded LR ownership....
I think most of the more modern LR reliability issues come from electronics. This is precisely why I bought Discovery without any electronic accessories that I could do without - electronic seats, reversing cameras etc etc.
Their heavy weight means they munch through suspension and brake components. And there are some other maintenance considerations - for instance, I’m eying up next a fairly unique and complicated DIY tranny fluid flush. And, if I ever blow one of the turbos, you have to remove the body from the chassis to replace it. That won’t be a driveway job .
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
K&N panel filter
Magnecor leads
RRP engine mounts
R-Magic shift knob
Heel/toe pedal mod
- Goobie
- Has thanked: 43 times
- Been thanked: 551 times
- Contact:
- These users thanked the author Goobie for the post (total 3):
- LeeW (Tue Sep 01, 2020 9:01 pm) • nightfire10 (Tue Sep 01, 2020 9:01 pm) • ChrisHolmes (Tue Sep 01, 2020 9:14 pm)
- ChrisHolmes
- Has thanked: 9680 times
- Been thanked: 4892 times
Received a quote to plate the rear of the sill on the passenger side.
Have a little guess before you click
Spoiler:
- Ollie
- Has thanked: 27 times
- Been thanked: 657 times
Ooft. Not as bad as it could be though.
- Ainmhidh
- Has thanked: 531 times
- Been thanked: 454 times
Spoiler:
- PaulAV
- Has thanked: 260 times
- Been thanked: 777 times
Not bad, there's a guy near me making a name for himself welding sills and arches on 8s he charges time plus materials.
- ChrisHolmes
Watch this space!
- Been thanked: 145 times
by the time thats been ground back to clean weldable metal that hole will be fair bit bigger...10 mins with the grinder...20/30 mins to cut a patch...20/30 mins with the welder.factor in the time it takes to jack up and paint some sealer on. 2 hrs work. so he wants £100 an hour? i will take up body welding again i think.
- These users thanked the author xamtex for the post:
- ChrisHolmes (Wed Sep 02, 2020 9:33 am)
- Has thanked: 938 times
- Been thanked: 1455 times
Get those horrible arch liners/sponges out Chris.
- These users thanked the author goodeggbob for the post (total 2):
- Honkytonk (Wed Sep 02, 2020 8:25 am) • ChrisHolmes (Wed Sep 02, 2020 9:33 am)
- Pingping010101
- Has thanked: 161 times
- Been thanked: 75 times
Having spent a while looking for quotes to sort my sills out, I think there’s a ‘worthwhile’ factor included in rusty car welding quotes. They don’t want to do the job so they just bump up the price to one where it’s worth it anyway but has nothing to do with time or materials.xamtex wrote:by the time thats been ground back to clean weldable metal that hole will be fair bit bigger...10 mins with the grinder...20/30 mins to cut a patch...20/30 mins with the welder.factor in the time it takes to jack up and paint some sealer on. 2 hrs work. so he wants £100 an hour? i will take up body welding again i think.
Sent from my iPhone using Tapatalk Pro
- These users thanked the author Pingping010101 for the post:
- ChrisHolmes (Wed Sep 02, 2020 9:32 am)
- LeeW
My grinding was a wheel bearing as I thought. Yeah it has the oil filled bushings as it has the dynamic response driving mode available. It's just done over 50k too so it all sounds about right. Mine is due to have all the transfer boxes and tranny fluids changed. Let me know how you get on with yours. I went for a 2010 for similar reasons. I wanted the modern interior but also wanted the simpler TDV8 and they only done it for one year!R1DSO wrote: ↑Mon Aug 31, 2020 10:58 pmIf your RRS has the oil-filled rear lower control arm bushings and has done over 50k miles, I would strongly suspect the knocking is a failed bushing. I say ‘if’ as I believe some RRS had solid rubber bushings. It should be fairly easy to check by giving the control arm a waggle for excess movement with the wheel off.LeeW wrote: ↑Mon Aug 31, 2020 9:21 pmI've got 2010 RRS that has the low speed knocking thing. Never had time to diagnose it fully as I don't know if its ARB bushes or arm bushes as I've heard that they're notorious for both. Interesting you've done that though and sorted it. It's got a horrific grind/squeal developed today though. Don't know what it is, maybe bearings. Maybe its the start of the dreaded LR ownership....
Kuro 174/500.
- Bigblueknight3k
- Has thanked: 197 times
- Been thanked: 227 times
Thats the rx8 mot for another year and yet again a clean sheet
Sent from my LM-Q630 using Tapatalk
- These users thanked the author Bigblueknight3k for the post:
- johnbb99 (Sun Sep 06, 2020 10:14 am)
- rotatopotato
- Has thanked: 606 times
- Been thanked: 373 times
Dropped off at Preserve & Protect this morning for the full monty underbody rust removal/conversion/protection treatment. Also getting stone guard black strips added up to the top of the sills/bottom of the doors seeing as the unsightly previous repair extended up a bit, and I don't plan to re-spray for a looooong time.
Should be back to me on Saturday.
Now I'm lost and confused for a week - what the heck am I supposed to do with myself??
- v-rex (Mon Sep 07, 2020 3:11 pm)
- ChrisHolmes
Gone for a week! How much are they charging for the job?
- rotatopotato
Quoted £650, plus £50 for the extra covering of the sills.
- ChrisHolmes (Mon Sep 07, 2020 4:59 pm)
- PaulAV
Swapped my bonnet today, the old one was showing a lot of aluminium corrosion, some had been there since purchase in 2008. Only thing is I have to refit my struts, so new rivnuts ordered.
