Air bag recall booked with Donald’s Mazda under very strict instructions to ONLY touch the airbag parts and NOT do a health check. Last thing I need is the numpties that work there messing with what is currently a nicely running car, which from their reputation is a big ask
Expect the car to run poorly after the airbag is replaced.
This is because they have to disconnect the battery, for safety, and will be reconnecting and starting the car with a still-warm engine. The PCM will have cleared its fuelling memory and will struggle to relearn when the engine is already warm.
This may result in it struggling to maintain idle, and run rough at low-medium revs.
DON'T PANIC
It will sort itself eventually as you drive.
Alternatively, you can force a reset, once you're back home and after the engine has cooled overnight. viewtopic.php?f=25&t=34703
DON'T PANIC
Stories I’ve heard (and personal experiences) of this particular dealer don’t fill me with confidence but thats good to know at Petes the day after anyway so any problems I’ll have an actual expert that can take a look
2nd visit to Robs to finish the repairs.
Can highly recommend the Bacon sausage snd egg sandwich, yum yum.
But they are only for special people who can manage to bugger up a family's Saturday twice in a row.
Anyway before and afters, warts and all, is there no end to the talent of this man?
Now to Krown to future proof.
Looks like a thorough job, how much did it cost?
I scrapped my 04 RX-8 and bought a Kuro instead as the quotes I got to repair the rust was multiples of what the car was worth.
Decided to do some testing with my subs/amps and blew a 100 amp fuse in the process.
Gave the car a wash then went for a long drive to EuroCarParts to get a few things
Sorry but any costs involved must remain between Rob and I, I am sure you will understand.
Luckily the structural parts behind the outer panels were in good condition, going further in would have been much more challenging.
The most tricky bit was the outer to inner arch detail, which originally comprised of 2 skins coming very close together just in front of the wheel, a guaranteed moisture trap,so we opted to bring the inner arch down vertically thus allowing any further inspection and maintainence much simpler.
All in all a fairly easy job if a little time consuming,and lets hope that it is now future proofed with the help of Krown.
These users thanked the author goodeggbob for the post:
Today I changed the oil and spark plugs on my Step father's 2007 Nemesis. Also gave it a compression test as we don't know the history of the car. Discovered that the coils and revision C ones so not gonna bother changing them. Below are the results of the compression test. Hot engine in the top spark plug hole, not sure if it matters which plug you use...!?!!
The 7s are front rotor.
The car has circa 40k miles on the clock. I would be keen know peoples opinions of these results given the age/mileage of the car.
Sent from my Phone 2 using Tapatalk
These users thanked the author Calcifur83 for the post (total 2):
nightfire10 (Sun May 02, 2021 5:22 pm) • v-rex (Sun May 02, 2021 7:49 pm)
Gordon
.....Loading.....
Petit Racing Modular Exhaust
Tein S Lower Springs
K&N Hi-Flow Air Filter
Spent all of yesterday with mi60o0 fitting his old R-Magic manifold to my car. Suspected slight blow from it, hoping to head up to Revs to get the gasket replaced and then re-tuned soon.
Since last time (dyno'd at 209WHP) I've installed an AEM intake, Racing Beat catback, RRP dual res midpipe and now the R-Magic manifold. Bit of a mashup, but hoping to scrape a few more digits out of it, maybe even hit the magic 220WHP if I'm lucky.
These users thanked the author Luke0611 for the post (total 4):
LeeW (Sun May 02, 2021 6:28 pm) • v-rex (Sun May 02, 2021 7:49 pm) • untakenname (Sun May 02, 2021 11:55 pm) • Nanotrox (Mon May 03, 2021 8:44 pm)
R3-40th Anniversary [97/400] R3 face conversion in Ford Frozen White (originally Met Grey) Engine Rebuild at 96,###.
Full bridge port
Tuned by Rotary Revs @209whp
Lightweight flywheel
Mazda Rev C Coils
AEM CAI
Racing Beat catback
Dual Res Decat
R-Magic Exhaust Manifold
Rota Pro R 18"/9.5
Yokohama AD08RS 255/40/18
TEIN Flex Z Coilovers
Whiteline ARBs
Calcifur83 wrote:Today I changed the oil and spark plugs on my Step father's 2007 Nemesis. Also gave it a compression test as we don't know the history of the car. Discovered that the coils and revision C ones so not gonna bother changing them. Below are the results of the compression test. Hot engine in the top spark plug hole, not sure if it matters which plug you use...!?!!
I’d be well happy with them
That's what I was thinking, shame its not my car! Lol.
These users thanked the author Calcifur83 for the post:
mrspiller (Sun May 02, 2021 9:54 pm)
Gordon
.....Loading.....
Got rid of the nasty rusty subframe, calipers and steering knucles today, well, this weekeend.
Wishbone bushes had split away from the steel due to corrosion so fitted new wishbones and anti roll bar links, finally as it was all out i replaced the sagging engine mounts.
The wishbones are new and the subframe and knucles came from Japan. The parts from Japan came from a higher mileage car but just look at the difference no road salt makes:
Nice virtually rust free subframe with new wishbones ready to go in:
Not such a bad job once i bit the bullet and got stuck in:
Now i stand a chance of an MOT pass :-)
Ade
These users thanked the author Yozhek for the post (total 2):
nightfire10 (Mon May 03, 2021 4:58 pm) • PaulAV (Mon May 03, 2021 5:08 pm)
Booked her in for a full set of Michelin Pilot Sport 4s.
To get finally get rid of the ditch finder's she is currently wearing.
And here they are, not been able to use them properly as it was torrential rain on the road from Abergele to Llanrwst 5 miles in
Got a deal at Kwik Fit I was happy with so job done.
Donalds Mazda eh...
Not too pleased to have to go to them it but at least it’s only the airbag and not the fuel pump. Big Pete saying he’ll look it over while I’m there has put me a bit at ease at least
Was adding up the costs of parts I need to buy to get my car road ready once again.. Checking EBC for some Pagid rear brakes.. £40 for a pair.. I was budgeting up to £90 off the top of my head so ehm... I have some lovely new disc brakes on the way to me..
Just brake fluid, EBC blue stuff all round, FL22, drop links all round and oil filters.. Still over 200 quids worth to go I guess.
Kentaro The Red - Sadly fallen... Star Platinum - Work in progress
Pagid is part of TMD Friiction and used to be the oem brake suppliers to the likes of Aston Martin, among others.
However, these days they only sell product through Euro Car Parts.
It's a bit like when the Hygena Kitchens brand was bought by MFI - for those that have long memories.
I'm not sure how, or even if, that reflects in the quality of the products but it certainly makes them more competitive on price.
I just put a set of Pagid pads on the rear of Pauline's Octavia, and that now stops fine
I remember you saying Dave before about them being OEM to certain brands in the past. I figure since the cars not hitting the track this year at all.. For 40 quid to replace the gouged disc and have new rears it's pretty worth it.
I think my fronts are still in pretty good condition.. If not I have a feeling John will be pawing some C hooks off on me.
Also just realised I put EBC instead of ECP.. Brakes were definitely on the mind when I typed that.
Long overdue airbag recall at rrg Stockport today.
Guy said they don't see many these days and the ones they have had recently were a bit worse for wear, the mechanic's were admiring it.
Also nice to see some rotary heritage in the showroom, even if only in a picture on the wall.
Sent from my TA-1012 using Tapatalk
