Why not an ignition live relay to disconnect it?
Coolant change today, nice luminous pink colour now....
Old one didn't look bad to be honest when it came out but had no evidence of when it was last changed.
- Been thanked: 93 times
Didn’t think of that, however that would have been beyond my electrical comfort zone my way I’ve only got 2 wires to worry about
Kamikaze
Too many to list.
Too many to list.
I've pretty much done the same thing on a customer's car recently - I can send you a relay with all the wires labelled if you like - car leccies aren't that hard.
Thanks for the offer Nick, but as I have fitted the switch now, I’ll just leave it as it is.
Kamikaze
Too many to list.
Too many to list.
- Has thanked: 71 times
- Been thanked: 90 times
Mocked up fitment of a USA rear foglight delete emblem, it doesn't fit too well so will need to make the bumper cutout a bit narrower.
Bought a laser foglight from China which I intended on shining through the hole but it's really cheaply made, no waterproofing so will have to do something custom.You do not have the required permissions to view the files attached to this post.
- Has thanked: 75 times
- Been thanked: 34 times
A diode on the live wire to stop any higher voltages flowing from the engine to the solar panel?
40th Anniversary RX8
- Been thanked: 546 times
solar panels usually include such a diode as standard anyway. stops them discharging at night.
That would protect the panel from the 14.5V of the "12V" supply when the engine is running.geofftl1000r wrote: ↑Sun Jan 06, 2019 7:01 pmA diode on the live wire to stop any higher voltages flowing from the engine to the solar panel?
However, the draw of the starter pulls the 12v waaay below 12 actual volts, which the panel would effectively see as a short circuit across its output.
Diodes also have a forward voltage drop (in the order of 0.7V) which the panel would have to overcome when trying to charge the battery.
- geofftl1000r (Sun Jan 06, 2019 7:20 pm)
Was worried about wear on obd port from plugging / unplugging solar charger so bought one of these...
(will also allow my obd reader to stay connected)
Edit:
Quick test fit over lunch and still allowing charge via solar (so not a totally useless ebay purchase from china) - yet to put obd reader back on though.
And my coolant level looks okay so (probably) haven't got any leaks after change.
Edit:
You know that you can unclip the ODB2 port and tuck it away underneath.
You might then be able to get one of those white connectors to lock in the original mount.
- bigpete8 (Mon Jan 07, 2019 12:40 pm)
Now that sounds like a plan....
- Has thanked: 86 times
- Been thanked: 38 times
Here it is. Sorry I've just overlaided them with some transparency for now so lines are the same colour...delta0 wrote: ↑Fri Jan 04, 2019 2:03 pmLook forward to seeing those. Nice pic!LeeW wrote: ↑Fri Jan 04, 2019 11:37 amAll I know at the moment is +10whp peak increase. When I got home and compared the graphs from the stock visit, the original visit had RPM on the X-axis and the printout from the 2nd run had MPH which is a bit annoying. So I don't know how the graphs actually compare. Could be 20whp down across the whole range apart from that one +10 point for all I know. I've asked for all runs to be emailed individually plus the best run from both visits to be overlaid on the same graph, all with RPM on the Xaxis. I'll update when I get them through...
Nice flammage though
You could extract the data from the graphs https://automeris.io/WebPlotDigitizer/
-Stock (Except RR D585 and ER "minimap" and Japspeed HiFlo Cat): lower set.
-RRP Single Resonated DeCat, Miltek/Pettit Catback, AEM CAI: upper set.
RRP remote remap coming soon, then another run.
I might chat to the guys at EST when I'm there next and ask about things like how temperatures effect things on the dyno and what the drag line is all about... Unless anyone wants to school me here.
- These users thanked the author LeeW for the post (total 2):
- 13Black (Mon Jan 07, 2019 3:24 pm) • delta0 (Mon Jan 07, 2019 4:09 pm)
Kuro 174/500.
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
Drag is fly minus wheel. I.e. the drag on the engine resources by the time it gets to the wheels.
So 160 ish at wheels whp = 210 'norm' - (fly) difference is 50 lost in drag.
- These users thanked the author Juey for the post:
- 13Black (Mon Jan 07, 2019 4:47 pm)
Black Cherry Mica
Oh OK, so the drag is an "assumed" figure in this instance? Am I right in thinking that the only measured number here is WHP and torque? These being the actual readings made by the dyno? The drag number is guessed or calculated based on you telling the computer things like what the car is, and what it measures the conditions locally to be (intake temperature, ambient temperature, humidity and air pressure)? It then is added as you say to the measured number to give the norm number...?
Kuro 174/500.
It depends..... A good dyno run will have a coast down run, during which the drag is measured. However, some dynos will just use a "made up" percentage of the measured power. You should ask the dyno operator if the drag is assumed or measured.
- Has thanked: 33 times
Changed the plugs
It might be a optical illusion in the photo but it does look like the ground electrodes had eroded back quite a long way.
On new plugs the ground electrodes go completely over the centre electrodes.
This would mean that your plug replacement was well overdue, apart from the build-up of crud.
What were the outsides looking like?
Cheers Pete. I actually decided to have a read through Maha user manual last night to try and learn a bit more about what they’re doing. Yes I’ve got a bit of time on my hands at the moment..... Going to ask a few questions next time I go after the remap.
Kuro 174/500.
- RX-8: Import
Got impatient topping up the oil and had to pela some back out - doh!
Thought a litre from dot above min would be about right, apparently not. That's too much.
All tyres on 27-28 psi too, legs now knackered!
Black Cherry Mica
Maybe if you weren't so unfit, Juey
You still use a footpump??
Blimey can't recall the last time I used one of them.
Suppose lighter socket ones are a bit expensive to run on a Rex, but either use my ryobi one with power pack or run one off my battery booster pack.
- RX-8: Import
- ChrisHolmes (Wed Jan 09, 2019 11:01 pm)
Black Cherry Mica
- Has thanked: 173 times
- Been thanked: 523 times
Fitted my new ebc disc's and pads all round, took about 3 hours all told, including checking and lubing slider pins, one was a little sticky, but is all good now. lubed up the steering column uj as well due to steering getting a little notchy,couple of applications of spray grease followed by a good rub of high melting point grease. Let's see how it likes that.
- RX-8: Import
Realised my fuel gauge lies.
Needle got well below the last line and light on 25 miles ago, couldn't risk any further, I was getting well twitchy - still only got 56 litres in her.
Small tank or drama queen gauge?
I guess the only way to find out for sure would be to run it dry, but that seems like a bad idea!
Black Cherry Mica
