4/5 shades? What cars that because thats a weak VR game..
- Been thanked: 283 times
- Ainmhidh (Thu Oct 21, 2021 5:26 pm)
- Has thanked: 60 times
- Been thanked: 37 times
RRP ignition coils and leads now on the car, running sweetly. Scott (RRP) noted there is a vibration while in neutral and thinks the engine mounts are corroded so i guess that's the next thing on the list.
I broke the skin on my fingers trying to get the third brake bulb out. Got it out eventually, led works and doesnt trigger the bulb out warning, but the bulb is too big which is f ing annoying. It's in but cant secure the holder. But the boot clips back in too they were a pain.
Based in Long Eaton
Based in Long Eaton
- Has thanked: 170 times
- Been thanked: 115 times
Filled the car up for the trip down to RR in the morning, had an older guy walk up to me at the pump complimenting the car and talking about wankle engines which was pretty cool
Lightened and balanced rotors
Pettit Catback
Exedy Clutch
CC Ultra Lightweight Flywheel
CC Counterweight
Tein S.Tech Lowering Springs
Racing Beat Ram Air Intake
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
- Former Trader
Sorn, off the road and tucked away for winter. Next job will be ordering all the parts for next years round of MoT
- Has thanked: 16 times
- Been thanked: 87 times
Waved goodbye to my RX-8
3 good years with it, time to go to a new enthusiast who can get some use out of it.
Now Jess is deciding what the money is spent on
Wont miss the fuel bill or the tax, but the drive out into the country roads and the pops and bangs sold it instantly. The way the bilstein suspension handles and the speed into corners shocked them.
Oh well, one to regret in the future. Off to have a shower to get the smell or v power out my hair and put my slippers on.
The door closes on rotary ownership for me
If you fit the wrong LED bulb to the centre brake light, then you don't get a bulb warning but the ABS system fails its preflight checks and both ABS and DSC are disabled.RichT_Derby wrote:RRP ignition coils and leads now on the car, running sweetly. Scott (RRP) noted there is a vibration while in neutral and thinks the engine mounts are corroded so i guess that's the next thing on the list.
Ah ok. I don't have any warning lights on the dash. But in all honesty the led bulb is way too bright so I might put the halogen back in or a smaller led if it's compatible. Thanks.
Based in Long Eaton
Based in Long Eaton
- Has thanked: 316 times
- Been thanked: 53 times
What amp rating should the main [thick] battery cable be, please? 170A enough?
- Been thanked: 547 times
i wouldn't go smaller than 35mm2
- johnbb99 (Sat Oct 23, 2021 2:09 pm)
Exciting day out to RR both solenoids changed and a clean of the plugs, seems to have fixed the issue I was having
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
I would go for a minimum 200A if the battery is still in the engine bay, or 300A if you're relocating to the boot, to avoid excess voltage drop.
Note that many suppliers quote the maximum current capacity of a cable (before it catches fire), not the nominal capacity (which it should be happy with all the time).
That's a bit like selling chain or rope based on the breaking load, rather than the Safe Working Load.
- johnbb99 (Sat Oct 23, 2021 2:03 pm)
- Has thanked: 750 times
- Been thanked: 175 times
"finished" my tmps project
- These users thanked the author 30405 for the post (total 5):
- LeeW (Fri Oct 22, 2021 6:37 pm) • bigpete8 (Fri Oct 22, 2021 6:44 pm) • casey (Fri Oct 22, 2021 7:09 pm) • MARKTHOMASBRAND (Fri Oct 22, 2021 7:15 pm) • HarSc (Fri Oct 22, 2021 10:05 pm)
Popped these on
- RX-8: Nemesis
- Has thanked: 48 times
- Been thanked: 61 times
Learned about balance points!!
It was resting on 3 jack stands until the rear subframe came unstuck.
Sent from my Phone 2 using Tapatalk
- These users thanked the author Calcifur83 for the post (total 2):
- ChrisHolmes (Fri Oct 22, 2021 8:05 pm) • 30405 (Fri Oct 22, 2021 8:28 pm)
Gordon
.....Loading.....
Petit Racing Modular Exhaust
Tein S Lower Springs
K&N Hi-Flow Air Filter
.....Loading.....
New underwear?Calcifur83 wrote: ↑Fri Oct 22, 2021 8:01 pmLearned about balance points!!
- johnbb99 (Sat Oct 23, 2021 2:06 pm)
- RX-8: Nemesis
Not for me, I expected it to happen, my Step father on the other hand was not! Lol.
Gordon
.....Loading.....
.....Loading.....
Can I just add my thoughts on this, I had a set of pz nero's fitted a few years ago and quite a while later I had all valve stems cracked ,I blamed it on the stems fitted with the tyres but thinking back it may have been due to the tpms caps loading weight to the stems on track ! Just my thoughts30405 wrote:"finished" my tmps project
- RX-8: Nemesis
That is one very tidy looking engine! Is it brand new or just really well cleaned.?Proactive wrote:Popped these on
Gordon
.....Loading.....
.....Loading.....
Brand New direct from Mazda via Clive at Racing Beat Europe.Calcifur83 wrote: ↑Fri Oct 22, 2021 8:55 pmThat is one very tidy looking engine! Is it brand new or just really well cleaned.?Proactive wrote:Popped these on
- RX-8: Nemesis
Very nice!!
Gordon
.....Loading.....
.....Loading.....
- Has thanked: 18 times
- Been thanked: 81 times
You all know where I am!
- These users thanked the author Keke for the post (total 2):
- chriskirkham (Sat Oct 23, 2021 10:08 am) • HarSc (Sat Oct 23, 2021 12:42 pm)
Enjoy the complimentary biscuits and coffee
Looked under the bonnet trying to find where the squeal is coming from, it would appear to be water pump pully location using a piece of 22mm pipe ,only below 2.2k revs is this a new pump or ?
Check the belt tension. Also if that’s ok put a drop of beak fluid onto the running pulley if it stops squeaking change the belt.
