- Has thanked: 15 times
- Been thanked: 13 times
Never been caught myself
I always know where they are going to be on my work route. On roads I don't know, I stick to the limit, that way I don't get caught.
Paul
RR Platinum Rebuild, Lightened Rotors and a Half Bridge, plus many other mods.
Check out http://www.rx8ownersclub.co.uk/forum/vi ... 04&t=66822
- Has thanked: 147 times
- Been thanked: 288 times
I call BUUUUUUULLSHIT!!!
- Been thanked: 220 times
Took my VR one to work today to brush the cobwebs off her. A quiet drive in but I’ll warm the tyres up on the way home
And only one speed camera on route
- Colour: Diamond Grey
- Been thanked: 3 times
Started car, reversed off drive, went to apply forward momentum in 1st gear, stalled. Oh, that was 3rd gear. WAKE UP!
Oh sh!t, has it flooded while I'm stuck in the middle of the road?
Turn everything off, ignition back on, try to start... Ohhhh thank fook for that - caught fire quite quickly, sounded a bit chuggy for about 5 seconds, cleared through. Not the start to the week I'd have wanted.
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
Managed to fix something. Yay
Windscreen washers on the driver side have always been poor - dribbly and impossible to direct.
Took the nozzle out, making sure I pulled through the rubber hose enough so it didn't disappear into the abyss and stuck a weight plate on it!
Soaked the nozzle in some Cillit Bang for a while, refit and bingo - power and direction
it's the little things.......
Black Cherry Mica
It shouldn't flood in that scenario.EvilDes wrote: ↑Mon Nov 20, 2017 8:46 amStarted car, reversed off drive, went to apply forward momentum in 1st gear, stalled. Oh, that was 3rd gear. WAKE UP!
Flooding occurs after the engine is started, switched off after only a few minutes and then the car is left to go cold again. Flooding actually happens on the next (attempted) restart.
So, had you not restarted straight away, perhaps thinking that it might flood the engine, rolled back to the curb and tried to restart later, then she may well have flooded.
"Bang, and your nozzle squirts" might not be the new tag line on the Cillit Bang adverts, although we can hope.
I normally jam a screwdriver up the end of the hose, so it doesn't get lost, and drop the nozzle in industrial strength limescale remover.Juey wrote: ↑Mon Nov 20, 2017 11:58 amManaged to fix something. Yay
Hadn't thought to try Cillit Bang.
- RX-8: Import
Was searching for Viakal or similar at home and was just about to use vinegar when I stumbled across some of Barry Scotts finest!
Next job: remove door card and gubbins to get to the wing mirror bolts. One must be loose as there's an annoying rattle from them unless I squirt WD40 behind the plastic cowl on the outside.
Black Cherry Mica
Wing mirror rattle is often the plastic covers on the back (the painted bit). The way I fixed it was to remove the covers - you don't need to remove the mirror from the car to do this - and then put a little bit of foam between the plastic cover and the mirror itself.
Went away absolutely fine
- Has thanked: 13 times
- Been thanked: 7 times
Not really to the Rex but in preperation for it, got these back from being refurbed, now to find some rubber and get fitted
Ahhhhh, thanks for explaining that. I did react quickly to get started again, it had been run for about 45 seconds before moving and I feared the worst, seeing as it wasn't really warm in the slightest. First time I've stalled the R3, and first time it's been turned off without any of the variable redlines extinguished.warpc0il wrote: ↑Mon Nov 20, 2017 12:04 pmIt shouldn't flood in that scenario.EvilDes wrote: ↑Mon Nov 20, 2017 8:46 amStarted car, reversed off drive, went to apply forward momentum in 1st gear, stalled. Oh, that was 3rd gear. WAKE UP!
- RX-8: Import
Dan.NJ72 wrote: ↑Mon Nov 20, 2017 1:00 pmWing mirror rattle is often the plastic covers on the back (the painted bit). The way I fixed it was to remove the covers - you don't need to remove the mirror from the car to do this - and then put a little bit of foam between the plastic cover and the mirror itself.
Yep did that to help the 'closing the door' tinnyness. But this jiffle comes on worn out roads mainly rather than bumps and is internal. Took me forever to find it and squirting WD40 behind the black plastic triangular bit makes it go away but only temporarily. May need a rubber washer, who knows
will take it apart and have a look. if it's all tight, then I dunno
Black Cherry Mica
Hmm... There is a little spring inside which allows the mirror to be folded in, so that might need a spacer or summink...
That said, tightening the little 8mm bolts on the back side will probably help too!
I also found that one of my rattles was due to a load of broken nylon clips holding the door card on. A few minutes spent over the weekend replacing all of them helped
- RX-8: Import
..had to replace all of them when I put in the Ghost light in the door, so they're sound.
Elec mirrors, so we'll see what's behind the cover......
Black Cherry Mica
Bought one of these today. Gues how many codes I had????
http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-GB
Hahahah, none. Result!
May I just add for £19 what a fantastic bit of kit! Sorted a code on my a4 avant as well. Can't recommend it enough.
Got a new pair of boots stuck on the front - KU39s (225 40 19s) again.
Car has been sat for around 10 days which includes two hard frosts so I thought let's see how it starts!
Turned the key and rrrrrrrrrrrrrrrrsplutsplutsplutsplut feeble just firing for about 10 seconds and then cough cough small black puff from the exhaust and away it went. Cold starts generally have been getting longer. New plugs about 1000 miles ago.
Mine took a second or 2 longer to start this morning, and I drove it properly yesterday!
Diamond Grey R3. RR D585 Ignition Coils & Magnecor Leads. Pettit Racing / Milltek Catback. RB Dual-Res Decat. RR Custom Remap + Pops & Bangs
- Has thanked: 105 times
- Been thanked: 46 times
Mine hasn't been started for 8 days, started up this morning no probs straight up
- Has thanked: 53 times
- Been thanked: 76 times
Mine hasn’t been started for 1 year, give or take a week or two. Wonder how that will fair? I’ve plans to get the ball rolling in March , so will miss the winter, but should be an eventful first turn of the key!
Warmed it up to defrost everything 1.5 mile trip to B&Q, parked for 15 minutes and..............started in about 3 seconds. Got love these cars idiosynchrasis. Did I spell that correctly, works with a y too!
- Has thanked: 24 times
- Been thanked: 18 times
Started slightly slower this frosty morning after 7 days of sitting about. Went off to see Luke to get the new coils and plugs fitted.
Really needed to be done too. Old coils had white pitting and spark plugs well past best. Really smooth now
Sent from my Nexus 6P using Tapatalk
Jon, was that with the new RRP coils ? Did luke adjust the dwell time to?jondkent wrote:Started slightly slower this frosty morning after 7 days of sitting about. Went off to see Luke to get the new coils and plugs fitted.
- Has thanked: 319 times
- Been thanked: 257 times
Idiosyncrasies is the word you were after I think Chris
Not missing any of them before somebody asks
- ChrisHolmes (Sat Nov 25, 2017 3:30 pm)
