I read that as "same colour as your wheels would look the nuts"
actually I think he was right the first time
- Scotty PZ (Tue Aug 20, 2019 1:58 pm)
- Been thanked: 17 times
Had the Vredestein Ultrac Vorti 225/40/R19 fitted today. Found a good local garage to do the work, and spent a while talking to the owner (who turned out to be a proper car enthusiast).
Oh, and thoroughly enjoyed bedding in the tyres - the blue lines are already gone
And still three gears left...
- Has thanked: 16 times
- Been thanked: 87 times
Added my go faster dragon and name to make sure I don't forget it.
- These users thanked the author shroom for the post (total 2):
- GreySilver Beast (Wed Aug 21, 2019 12:30 am) • ChrisHolmes (Wed Aug 21, 2019 7:12 pm)
- Has thanked: 23 times
- Been thanked: 14 times
Only gone and got it through it’s first MOT in 4 years...... “It’s alive!”
Let the fun commence....
- These users thanked the author NeMFO for the post:
- ChrisHolmes (Wed Aug 21, 2019 7:12 pm)
- Has thanked: 57 times
- Been thanked: 31 times
Anyone else headed to Brands Hatch to watch the RX8s in action - RSV Graphics New Millenium race series?
Sent from my SM-T550 using Tapatalk
- Been thanked: 15 times
Went to change the rear brakes yesterday, then realised they were wind back pistons. That makes two cars of mine now, so will pop to machinemart and get the kit rather than resorting to borrowing it off a mate each time.
See the diy section for a really good write-up on doing the brakes, complete with photos.Dom-PZ wrote:Went to change the rear brakes yesterday, then realised they were wind back pistons. That makes two cars of mine now, so will pop to machinemart and get the kit rather than resorting to borrowing it off a mate each time.
Starts with the fronts, just scroll down for the rears.
https://www.rx8ownersclub.co.uk/forum/v ... ilit=brake
Reason: added link
Reason: added link
- Dom-PZ (Sun Aug 25, 2019 11:43 am)
Ah good shout, I thought I knew all of that but I didn't. I will return armed with wind back tool... and hammerite! Another little bit of value extracted from the membership fee
Get some Ceratec while you're at it, unless you already have some.
After suffering from brake judder before and during the Croft track day last Tuesday, plus the brake went decidedly "less sharp" after lunch I finally got time to have a look at the fronts today and they say a picture tells a thousand words so feast your eyes.
Note the missing pad locating spring which has allowed the pads to move forward and overlap the outer edge of the disc.
- Has thanked: 68 times
- Been thanked: 131 times
Might still have a couple of springs retaining plates in the garage have a look tomorrow let you know mind you they could be in one of those boxers you have found the valet key as well
- These users thanked the author exiled--viking for the post:
- ChrisHolmes (Tue Aug 27, 2019 11:20 pm)
Tony might have a spare forget it.
Reason: update
Reason: update
- ChrisHolmes (Mon Aug 26, 2019 11:43 pm)
- Has thanked: 53 times
- Been thanked: 76 times
Changed engine oil, now my oil pressure guage is acting a little weird. When I'm 6k rpm and over I'm reading over 7 bar on the rspec guage. First thought was Ive over filled it, but I've only used 4 litres on the change so rules over filling out. Hard to tell also on the dipstick as the oil is so clean, but I'm sure it's half way up. I've kept the same filter as I've only done 500 miles since the last change and also have a greddy sump fitted.
The official Mazda minimum oil pressure check is to heat the oil to 100'C, run at a steady 3000rpm and the minimum pressure you should see is 3 bar.
Note that an uprated relief valve will not affect the pressure at this rpm.
7bar at 6k is good
7bar at 6k is good
- Scartlead (Tue Aug 27, 2019 4:44 pm)
Thanks for that Chris. I didn't recall it running that high pre oil change and got me a little worried, considering the guage Max's out at 7 bar, so I'm not sure where the max result at the beep would be. No oil leaks and running sweet as a nut too.
- Has thanked: 19 times
- Been thanked: 18 times
Put my car through MoT today, got advisory for rear brake pads and apparently my front driver side is completely worn so I’ve order ebc Redstuff all around other than that there are no other issues.
- Been thanked: 220 times
Engine out. Engine in
Thank you Wayne for all your help
Auxiliaries and oil to finish off then a bit of camber adjustment.
- Devon_Fourie (Wed Aug 28, 2019 9:16 pm)
I do so hate, sorry envy that garage!!
Took the discs in today for grinding and the Greddy sump too as I managed to strip the thread on the temp sensor by fitting an incorrect thread adaptor. Plus the sump to block joint was weeping anyway and the way it came off easily confirmed the sealant I used was crap, now I have some good black goo!
SORNed the car for September as I am away for 3 weeks so it wont be driving it at all.
- Has thanked: 38 times
- Been thanked: 116 times
Hah batrex get a journey to Yorkshire last bankholiday weekend another 500 plus miles in total and no issue a all even proven to me to be economical up to Yorkshire 170miles on half tank.
Rex get mapped and pop and bang all the way Yorkshire to luton wife was driving she aprove the new goods on rex. Last few weeks before I sorn my rex mid September.
LEXUS LS430 4.3 v8 family car
Done exhaust and work wheels
I knowChrisHolmes wrote:I do so hate, sorry envy that garage!!
It’s great being able to work on two engines next to each other and still have room for a party lol
Party!
Always fun and games at Wayne’s
- ChrisHolmes (Wed Aug 28, 2019 9:40 pm)
Nothing like chilling in the garage working on cars and bikes with friends and some nice cold beers. Perfect night inChrisHolmes wrote:Party!
- These users thanked the author Devon_Fourie for the post (total 2):
- ChrisHolmes (Wed Aug 28, 2019 9:40 pm) • mrspiller (Thu Aug 29, 2019 9:23 am)
fitted my new brakes all around, job went smooth apart from breaking my only 14 socket so treated myself to a new quality socket set. Brand new ebc red stuff brakes are amazing, the car tries to throw me through the windscreen every time I brake.
Car passed mot with no issues at all.
