v-rex
Been thanked: 167 times
Post by v-rex » Thu May 14, 2020 9:12 pm
They look like kPa. So you would divide by 100 if so, which will give you bar, which unless I'm mistaken is what mazda testers would usually report in. Would be good to ask the tester what units for sure though.
These users thanked the author v-rex for the post:
sztriki (Thu May 14, 2020 9:57 pm)
sztriki
Has thanked: 28 times
Been thanked: 8 times
Post by sztriki » Thu May 14, 2020 9:56 pm
Normalized to 250rpm (cranking speed was 273). Should be kPa. I did ask him, he said it's an okay result, one is weaker than the other but it should be okay for a while but unfortunately some repairs took longer and I had to dash once it was all done. Just curious as to how these results would be converted to this table:
https://www.rx8club.com/attachments/new ... _chart.png
Cuz if all I need to do is divide the values by 100 then the back rotor is failing, and the front rotor may not even exist...?
Has thanked: 5422 times
Been thanked: 2465 times
Post by ChrisHolmes » Thu May 14, 2020 9:58 pm
Found the reason for the brake fluid leak.
Pingping010101 (Sun May 17, 2020 3:18 pm)
Street Ported 231
MazdaSpeed skirts
Has thanked: 26 times
Been thanked: 375 times
Post by Yorindesarin » Thu May 14, 2020 10:08 pm
Using foxed.ca I got these results:
Front rotor:
(In bar)
5.04
4.85
5.10
Rear Rotor:
6.48
6.50
6.34
Normalised to 250 and altitude of 20m. Based on the RX8club chart its big failure on the front and a slightly less worse fail on the rear... But the yanks are a bit... Compression happy for what is/isn't a runnable engine.. Some people have run worse engines for a while until they go pop.. Saving up wouldn't be a bad idea at all. The difference between rotors especially on the front one is a bit of a worry. Which is a shame because the rear rotor is in pretty okay shape!
sztriki (Thu May 14, 2020 10:47 pm)
The Red 8:
Racing beat Revi, Tein street basis z coilovers, RRP Mk2 Coils (and one Mk3), Stock catback, Cruise Control (Zoom Zoom).
sztriki
Post by sztriki » Thu May 14, 2020 10:47 pm
Update, just got this e-mail as a follow up from Essex Rotary:
Outcome of the test
Fail
Due to the low numbers on the Front rotor and the out of spec Rotor Difference we have not other choice but to class this as a fail, however after looking at this test compared to your test 2 years ago there is very little if any difference in the compression. There is actually a better rotor difference now with a better front chamber difference that there was on the previous test.
Guess premixing and Cataclean did help a bit...still, better start saving up.
Has thanked: 469 times
Been thanked: 1899 times
Post by warpc0il » Thu May 14, 2020 11:10 pm
The chart that Mazda produced
compression testing chart.png (45.78 KiB) Viewed 495 times
related to tests performed by US dealers, where a potential warranty claim may be being made for a replacement engine.
Anything below the line is considered "a fail" and qualified for replacement.
However, they were talking about failures within the warrant period of 3 years or 36,000 miles.
Certainly failures at much lower mileages would suggest a manufacturing/materials fault.
Having a 10-15 year old car with twice or even three times that mileage fall below the line isn't an ideal situation but also isn't really "a fail".
sztriki (Thu May 14, 2020 11:16 pm)
sztriki
Post by sztriki » Thu May 14, 2020 11:17 pm
Thanks. It's a 55 plate with 81k on the clock and no prev rebuilds. I'm genuinely surprised to see those numbers cuz the car starts without any problems and pulls great, one of the most problem free pieces of machinery I have. :-k
Pingping010101
Has thanked: 164 times
Been thanked: 76 times
Post by Pingping010101 » Sun May 17, 2020 3:17 pm
Today I booked the transport to move my car from the seller in Edinburgh to Chris Holmes to have the interior swapped and, depending on how difficult it will be to remove the wings, have the lambo door hinges fitted.
I started to get an odd feeling from the seller who is difficult to reach while I'm overseas and is slow to answer questions. I am now also having to apply for the V5 myself as he can't find the one he received when he bought the car! Hopefully Chris will be able to take a good look and give a thorough appraisal of the car's condition when it reaches him.
These users thanked the author Pingping010101 for the post:
ChrisHolmes (Sun May 17, 2020 6:35 pm)
tmk
Been thanked: 84 times
Post by tmk » Sun May 17, 2020 3:34 pm
Drove it today. That shouldn’t been an event, but not happening that often these days.
Despite the ongoing soft lock, several nice cars at Tatsumi PA.
Sent from my iPad using Tapatalk Pro
These users thanked the author tmk for the post:
RX-8 (2011/PearlWhite) RE Amemiya Redom AType2.0 ECU+Super Intake Box+SportsCat,RMagic TunedMuffler TitanCut,5.125 Final,Tein MonoSport w/EDFC,WedsSport SA55mMGM 18x9.0J,Neova AD08R 245/40/R18,Dixcel SD+IDI GT2 brakes,AutoExe MemberBraceSet, Bride GIAS Carbon,HPI 4pt,MOMO,TRUST InfoTouch+LEG83005,YupiteruGWR53sd,Carrozzeria http://www.rx8ownersclub.co.uk/forum/vi ... 04&t=55428
Post by ChrisHolmes » Sun May 17, 2020 6:49 pm
Finally removed the engine & gearbox as a unit by dropping the sub-frame and engine as a unit then undid the engine mounts, pulled the sub-frame clear, lifted the engine with a jack under each mounting bracket and pushed a 4 wheel dolly under it with a chock under the gearbox. Along the way earlier the jack under the gearbox had slipped out allowing the tail of the gearbox to drop and out came all the gear oil!
With the engine-gearbox unit out of the way I then needed to roll the car back so I could wash the oil off the tarmac. Difficult as there were now no front wheels! Two 4x2s and the trolley jack got the front end up in the air but due to the little jack wheels and tarmac it I couldn't push it! another piece of 4x2 applied as a lever under the engine bay cross member and pushed solved the moving issue in stages.
Of course earlier when first lowering the engine sub-frame assembly the DS went down lower that the PS side! Once I undid the clutch slave pipe and the heater hose it became easier!!!!
Vj4sothername (Sun May 17, 2020 6:54 pm)
Street Ported 231
MazdaSpeed skirts
Vj4sothername
Has thanked: 1364 times
Been thanked: 321 times
Post by Vj4sothername » Sun May 17, 2020 7:20 pm
ChrisHolmes wrote:Finally removed the engine & gearbox as a unit by dropping the sub-frame and engine as a unit then undid the engine mounts, pulled the sub-frame clear, lifted the engine with a jack under each mounting bracket and pushed a 4 wheel dolly under it with a chock under the gearbox. Along the way earlier the jack under the gearbox had slipped out allowing the tail of the gearbox to drop and out came all the gear oil!
How'd you find the out from under approach? How high up did you have to get the front of the car?
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Post by ChrisHolmes » Sun May 17, 2020 7:28 pm
Not a good experience to be honest too many things to undo. Engine out top for me every time now having done things this way.
Vj4sothername (Sun May 17, 2020 7:29 pm)
Street Ported 231
MazdaSpeed skirts
Post by Yorindesarin » Sun May 17, 2020 7:41 pm
I was half tempted to take my engine and gearbox out from under so I could properly clean up the tunnel etc... But I had second thoughts because that'd be impractical.
The Red 8:
Post by warpc0il » Sun May 17, 2020 7:49 pm
Apparently it's the sort of thing you should try once, just for variety, but it can often hurt and the result can be disappointing for both of you.
Vj4sothername (Sun May 17, 2020 8:07 pm) • CraigS (Wed May 20, 2020 7:48 am)
Has thanked: 204 times
Been thanked: 741 times
Post by qwakers » Sun May 17, 2020 9:05 pm
i did it from underneath. i still maintain its far easier if you want to take the box out as well. but if its just one or the other, the more traditional way is easier.
IMPORTANT EDIT:
i suspect my view is coloured by the fact i have a electric gantry crane......
exiled--viking (Sun May 17, 2020 9:11 pm)
Post by ChrisHolmes » Sun May 17, 2020 10:30 pm
IMPORTANT EDIT:
Well that is a slight edge!
qwakers (Sun May 17, 2020 10:38 pm)
Street Ported 231
MazdaSpeed skirts
NeMFO
Has thanked: 34 times
Been thanked: 28 times
Post by NeMFO » Mon May 18, 2020 12:36 pm
Drove mine for the first time since fitting a decat pipe and it is like a different car! So much more torque at low revs (<4K) .I Fell in love all over again.
In case you were wondering, it was a Toyo sports Cat that I removed.
Nickp47
Has thanked: 120 times
Been thanked: 238 times
Post by Nickp47 » Mon May 18, 2020 7:34 pm
Compression test today, readings of 6.6 to 6.9. Not quite hitting the magic 7s but solid for almost 54k Miles and a gentle improvement from when I bought the car.
ChrisHolmes (Mon May 18, 2020 9:06 pm)
Scotty PZ
Has thanked: 59 times
Been thanked: 50 times
Post by Scotty PZ » Mon May 18, 2020 8:52 pm
Finally got around to painting my brake calipers. I went with Mazda Soul red, two stage paint, they came out very well!
The Prodrive sticker is to one side as I need to apply the new 8pot sticker too.
These users thanked the author Scotty PZ for the post (total 3):
johnbb99 (Tue May 19, 2020 2:53 pm) • exiled--viking (Tue May 19, 2020 4:03 pm) • v-rex (Wed May 20, 2020 8:04 am)
Galaxy Grey PZ number 24.
Large street port. Lots of flames, lots of smiles.
johnbb99
Has thanked: 340 times
Been thanked: 46 times
Post by johnbb99 » Tue May 19, 2020 3:44 pm
Powered by V&MC 3.png (25.11 KiB) Viewed 234 times
This is my amateurish attempt at a logo / possible decal based on that AA man's comment. Sorry, I've forgotten who posted the comment originally.
Any (positive) criticism or suggestions welcome.
Does transforming the double 'o's into rotor housing shapes work?
Any interest?
Bigblueknight3k
Has thanked: 151 times
Been thanked: 115 times
Post by Bigblueknight3k » Tue May 19, 2020 5:41 pm
Not happy get my coils back from rrp not even been opened get charged 35£ for nothing take coils out that were running the car put rrp coils back in now back to miss firing i cant belive it spend all that money on them and so called tested and still nothing same problem return i know its not the car
Sent from my LM-Q630 using Tapatalk
Ryan Rotary Performance
Sponsor Trader
Sponsor Trader
Has thanked: 184 times
Been thanked: 656 times
Post by Ryan Rotary Performance » Tue May 19, 2020 9:32 pm
Well this is a bit naughty and false, I have ask this particular person to call me (or I call him) to discuss and help fault find what exactly is going on with the car as when tested the coils they worked as intended. Please consider why we not even open the box, charge you and then just send them back! It does not make sense for us to do that!
These users thanked the author Ryan Rotary Performance for the post:
Scotty PZ (Tue May 19, 2020 10:42 pm)
Bigblueknight3k
Post by Bigblueknight3k » Tue May 19, 2020 10:53 pm
Well yes fact of it is that the video attached is the vidoe you sent to me as you saying u tested my coils thing is it could be any coils to be fair and does not help i loan some coils car starts and runs no problem then i take them out and put my rrp coils back in then its miss firing yet again and i pay £12 pound to send them and after 12 days i get charged 35£ 20 £ testing fee and postage is the rest no print out or results from you apart from random video normally a test would in clued ohm's resistance and out put voltages etc but none of that i bought them from you as recommend from this club as they say your after service is good so yes i have the right to ask for help and advice from fellow club members as i feel let down by Ryan rotary performance //cloud.tapatalk.com/s/5ec452eddd2 ... 698625.mp4
Post by ChrisHolmes » Tue May 19, 2020 11:06 pm
Decided to see if it was possible to return a painted carbon bonnet to a clear coated carbon finish and the answer is....eventually!
Salokin (Wed May 20, 2020 8:29 am)
Street Ported 231
MazdaSpeed skirts
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Tue May 19, 2020 11:19 pm
That was one element of the test, we then actually fitted to our car and they worked flawlessly. We are in the process of build a bench testing facility.
I was going to suggest that maybe there is a high resistance earth which was created when you installed your bonnet struts as by your own word this is when this issue started.
These coils pull alot of current compared to OEM so would be affected by this more so.
As for RRP letting you down, ive given mine and scotts number to call to help diagnose and offered to call you both offers were not taken up, instead you message after working hours and then slight us here 8 minutes later with no chance of recourse.
Either way all we want is to get the problem sorted and help you on your way.
New Duke (Tue May 19, 2020 11:24 pm)
