- Has thanked: 90 times
New clutch on all joints greased up on fork etc and wax oiled the shell above gearbox taken heat shelds off wax oil and then back on new braided clutch line fitted box back on easy than most lol just cleaning up that frame part from gearbox to diff due to rust
Painting bits and wax Oil underneath today exhaust to put back on then all done just to do subframe brushes next
- These users thanked the author Bigblueknight3k for the post:
- 30405 (Wed Apr 08, 2020 11:18 pm)
- Has thanked: 15 times
- Been thanked: 20 times
Finished installing my new oil cooler lines today - Impressed with the quality I must say. Took me three days on the drive in total, but only because I was being fussy about placement, and doing the 'while I was in there' thing with a few little bits. It's a pretty big project though!
Pulled the plugs to have a look at them too, and it looks like one of my trailing plugs isn't firing - no carbon on it at all, so something is certainly off, plus there was a big hot spot on the relating coil - fingers crossed my new RRP coils and leads show up soon. I've also found that the steering rack is leaking at one end Always something else!!!
- Been thanked: 546 times
um, the steering rack is electric... nothing to leak....
- These users thanked the author qwakers for the post (total 2):
- Ainmhidh (Thu Apr 09, 2020 7:44 pm) • Craig010 (Thu Apr 09, 2020 7:50 pm)
Your absolutely right. I suddenly feel much better about this. Maybe it was residual oil from the (heavily) leaking oil line. Opposite side of the car though, so god knows.
Thank you for pointing that out though! Much appreciated! The brain is not functioning at full capacity during this lockdown...
- Been thanked: 2087 times
Did you get a bit carried away lubricating the steering uj?
- Has thanked: 121 times
- Been thanked: 202 times
People have been known to get a bit carried away with the lubrication during periods of isolation.
It's the opposite side to the UJ , looked like it was coming out the end of the steering arm boot, but toward the rack side. I presume there's grease in there even being an e-rack, so maybe some has leaked out?
- Has thanked: 114 times
- Been thanked: 158 times
What subframe bushes are you using ?Bigblueknight3k wrote:Painting bits and wax Oil underneath today exhaust to put back on then all done just to do subframe brushes next
Strongflex i bought them off a member on here
Do release bearing make noise all the time on these ??? Done the clutch and all its better than it was but u still hear noise when off clutch and press it goes quite ???
Really why is that
That's not the release bearing, if it's making the noise with the clutch up, in neutral.
That's just the normal sound of the unloaded gearbox.
It's quieter if the 'box oil is fresh, and the correct Gl-4 grade.
It's noisier if the gearlever shroud is torn underneath and/or you're parked against a wall.
A noisy release bearing is with the clutch held down.
- Bigblueknight3k (Fri Apr 10, 2020 7:38 pm)
- Has thanked: 42 times
- Been thanked: 229 times
Release bearings when worn are usually noisy under load ie when you put the clutch pedal down and basically the box is noisy because its the gears turning when being driven by the engine and in effect rattling then when you disengage the clutch it stops, the RX-8 is known to be a bit noisy.
Google "Gear Rollover"
- These users thanked the author Delanor for the post:
- Has thanked: 173 times
- Been thanked: 523 times
https://www.carscoops.com/2020/04/mazda ... -hypercar/
Don't think it'll ever make production
Yep ok i had to ask as i thought i missed something lol its the gearbox oil recommend on the list of oils on the club as i know it works beautiful and dont have any problems and it had a fully flush before track last year and now again so all clean on gearbox its just that it sounds like clutch bearing just opposite way round
- Has thanked: 750 times
- Been thanked: 175 times
PaulAV wrote:https://www.carscoops.com/2020/04/mazda ... -hypercar/
- These users thanked the author 30405 for the post (total 2):
- Bigblueknight3k (Fri Apr 10, 2020 7:42 pm) • PaulAV (Fri Apr 10, 2020 7:57 pm)
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
Offside front wheel off to lube the UJ, cos, why not?
Whilst in there, let's take a photo of the engine mount and see how it's doing. Well that's disappointing.
Had the same issue so just swapped the mounts out today and also removed and swapped over 4 ARB drop links all with no hassle.
Wheels now back on both cars ready to swap them round tomorrow and T200 will go back up on stands and start to be stripped out.
I think a Kathy is of the mind that now they are both on the ground that I will be spending less time out there, wrong!!!
- nightfire10 (Sun Apr 12, 2020 9:37 am)
- Has thanked: 32 times
- Been thanked: 35 times
Busy couple of days getting stuck into the car.
Front off, any rust removed, luckily it was all surface stuff, undersealed and reassembled, a bit engine bay tarting up as I had some bits knocking about.
One headlight separated and silvers bit sprayed satin black, then lacquered before reassembly, I'm pretty happy with it, but the lenses appear to have some sort of damage which looks like crazing.
Recaro seats played with until I broke my drill bits trying to get the old mounts off, they were very old to be fair, once they are apart fully I can see how I'm going to get them in the car at the right height.
- These users thanked the author Scotty PZ for the post:
- Honkytonk (Sun Apr 12, 2020 9:19 pm)
Galaxy Grey PZ number 24.
Large street port. Lots of flames, lots of smiles.
Started doing some body/paint repair work, stone chips, scratches and storage damage, bit of filling and sanding, high build primer, next step, remove the bumper, sand then base coats, followed by several clear coats, wet sand and polish, at least I have plenty of time to work on this.
- Been thanked: 93 times
When I bought the Pz they came with ditchfinders on, so eventually today I got new Rainsport 5’s fitted, will see how they fair compared to the 3’s I’ve been running.
- These users thanked the author Dave2112 for the post (total 3):
- V8 Power (Wed Apr 15, 2020 7:19 pm) • ChrisHolmes (Wed Apr 15, 2020 7:23 pm) • GreySilver Beast (Wed Apr 15, 2020 7:42 pm)
Kamikaze
Too many to list.
Too many to list.
I'm not sure which version of RainSports Casey was running around a very wet Three Sisters but I was very impressed by how hard he could lean on them - especially from the passenger seat
