Has thanked: 114 times
Been thanked: 158 times
Post by mrspiller »
Nickp47 wrote:Started it up for possibly the first time this year with the intention of doing a compression test.
The accelerator pedal however is not working and when it gets warm it starts auto-revving up and down.
Can I put this down to its current lack of steering wheel or potentially another issue?
This happened to me once after changing an engine
We tried a basic throttle reset , ignition on
Held it down for 10 seconds - up for 10 - back down for 10 - 5 times and it worked .
No idea where the thought came from but it worked
These users thanked the author mrspiller for the post:
Nickp47 (Sat Mar 21, 2020 10:40 am)
Media Team
Media Team
Has thanked: 121 times
Been thanked: 202 times
Post by Honkytonk »
Nickp47 wrote:
Sat Mar 21, 2020 8:43 am
I had a similar issue when I replaced my coils and a PCM reset cured it. I would say though, mine was doing it whilst cold as well, so it could be similar symptoms, different cause.
Video of behaviour here;
Have you got a dongle plugged into the OBD port. If so unplug it and then restart the engine.
Nickp47
Has thanked: 176 times
Been thanked: 324 times
Post by Nickp47 »
I don’t think so but will check
Techathy
Has thanked: 9 times
Been thanked: 18 times
Post by Techathy »
Bodge/test fitted the driver's seat from my Evroa into the RX8 and went for a 'quick' test drive... a tank of fuel later I'm 10x happier with my Rex and thinking a Tesla EV conversion is on the cards. Though I'll want a different chassis, after getting it high up on ramps I think the car's been in a queue bump rear-end collision :censored: :censored: :censored:
So plan of action
1. Get OE Ricardo seats for the Evora
2. Sell the Evora
3. Buy new RX-8 with a really solid chassis, possibly Jap import to eliminate alarm issues.
4. Buy loads of EV bits 'n bobs
5. Build a RX-8 which revs to 16'000 rpm :twisted:
Does anyone know how stop the airbag/SRS light going on without the OE seats installed?
Has thanked: 742 times
Been thanked: 284 times
Post by nightfire10 »
Not yet done but will 20mm spacers fit anniversary wheels without cutting the studs down?
Has thanked: 219 times
Been thanked: 350 times
Post by goodeggbob »
hi Steve,if the studs project 27mm from hub face,as mine did,you would need to reduce them by 7mm,or pocket the back of the wheel to accomodate the extra,hope this is clear,rob.
nightfire10 (Sun Mar 22, 2020 8:41 am)
Rob :thumright:
Been thanked: 2088 times
Techathy wrote:
Sun Mar 22, 2020 7:30 am
The SRS is looking for a specific resistance down each circuit, whether that's for the seat airbag or the seat-belt pre-tensioner.
If you remove either then fit a resistor across the connector that you unplug.
See search.php?keywords=airbag+resistor
Techathy (Sun Mar 22, 2020 9:44 am)
Techathy
Post by Techathy »
Ah! I was looking at ways to code out the seat airbags to turn the light off! :lol:
gazmazdauk
Post by gazmazdauk »
Recently MOT'd and just advisories on two front tyres due to kerbing.
Something still wasn't right, so it went into Rotary Revs for an oil/filter change and check-up.
One drop link will need changing in the future - ok for now, sump seal is starting to bubble, will need changing - ok for now.
Biggest thing is, well priciest anyhow, differential will need replacing - ok to drive for now.
Oh and Rotary Revs have shut down for 2 weeks in response to Covid 19 pandemic.
Pretty sure bigpete is still open for all your rotary needs. No need to go without.
Been thanked: 220 times
Post by Neilparry »
Yesterday I loaded VR onto the trailer ready for Anglesey on Saturday. Then today Circuit Days cancelled the day.
So it’s back off with VR as I need to use the trailer next week
Post by Neilparry »
Or maybe not. According to boris
Has thanked: 174 times
Been thanked: 524 times
Post by PaulAV »
Due to a few days of nice weather and being out of work again (was only agency) I thought it would be the ideal time to get the waxoil out, hopefully got a good coating inside both sills front to back. May have a go at the rear subframe tomorrow and maybe fit my brand new exhaust shrouds.
Has thanked: 93 times
Been thanked: 165 times
Post by V8 Power »
Washed my Rex today for the first time in about 3 years and true to form it was then plopped on by the feathered flying squad!
nightfire10 (Fri Mar 27, 2020 8:08 am)
As I have to stay home for the next 12 weeks I thought I'd get the decat out of the shed and clean it up! Any idea how much it would be worth? As far as I know its a racing beat duel resonated decat
Nickp47
Post by Nickp47 »
£200-250 normally
Post by mrspiller »
If it’s not a Mazda one hardly bugger all
And price of scrap dropped about 70% end of last week
Not sure where it is now
Shuffled them around on the drive so I can get to all four wheels on each car and do the brakes and suspension swap over. Well once the orange paint arrives that is. May strip the TEINs whilst they are off and paint the springs green.
Ollie
Been thanked: 283 times
Post by Ollie »
Figured as it's the first day of isolation for me and its sunny and not windy out. That I'd take the wheels off the 8 and have a peak under the arch liners.. However on the passenger side this has happened!
Also noticed some rust at the bottom of my passenger wing. Only surface so I should be able to save it right?
mrspiller wrote:
Fri Mar 27, 2020 12:29 pm
LOL it's a decat Mrs
Has thanked: 100 times
Been thanked: 547 times
Yorindesarin wrote:
Fri Mar 27, 2020 4:40 pm
1st pic, slide a screwdriver underneath and smack the screwdriver with a hammer. it will fall apart. need a new one after, but they're not hard to find.
2nd pic, bet you thats coming from inside, be a lot worse once you start cleaning it up.
Ollie
Post by Ollie »
Ight I'll give the screwdriver a go tomorrow if it's nice weather James.
You think so? Completely new wing then since that one's been badly repainted before. So cleaning up that rust I'd have it repainted anyway. VR matching issues though.
Heat up a small flat blade screwdriver just enough ti melt the plastic and push it into the centre. Hold it until it cools, you can use a wet cloth or spray to speed cooling up, then just turn the driver gently et voila!
goodeggbob (Fri Mar 27, 2020 6:06 pm)
