Not quite!
- Been thanked: 2087 times
- Has thanked: 121 times
- Been thanked: 202 times
Spent an excellent day spannering with 30405, and now I have a beautiful PZ backbox (courtesy of the care of ScottyPZ) - and confirmed (if minor) flameage, and the car now picks up revs like it's going out of fashion.
Yet another day where my membership to the club repaid itself twice over.
- These users thanked the author Honkytonk for the post (total 4):
- 30405 (Sat Mar 07, 2020 8:38 pm) • ChrisHolmes (Sat Mar 07, 2020 9:14 pm) • sKenDread (Sat Mar 07, 2020 10:10 pm) • GreySilver Beast (Sun Mar 08, 2020 11:12 am)
- Been thanked: 220 times
Might it be this one
Spoiler alert
Spoiler alert
- These users thanked the author Neilparry for the post (total 2):
- 30405 (Sat Mar 07, 2020 9:07 pm) • GreySilver Beast (Sun Mar 08, 2020 11:12 am)
Insider knowledge used there Neil.
- Has thanked: 742 times
Would it be a VR one?
- Been thanked: 283 times
Looks like it may or may not have a lovely mazdaspeed body kit on it.
- nightfire10 (Sat Mar 07, 2020 9:32 pm)
HahahaChrisHolmes wrote:Insider knowledge used there Neil.
- Has thanked: 694 times
https://konigchain.com/en_uk/chains/con ... cu-10.htmlChrisHolmes wrote: ↑Sat Mar 07, 2020 7:16 pmYes but what about the snow chains. They look like a great piece of kit.
Thanks Chris. I got the Konig Easy-Fit CU-10. Needed something requiring minimal arch clearance and that self tightens (because I'm done with fighting with chains halfway up a mountain in the freezing dark). They're well made and although not quite as quick to fit as the video suggests (the vehicle in that video has huge arch clearance), I had them on in 5 mins which is much better than classic chains. They have bumpers to protect the wheels too. It looks likely that I'll have to use them on an upcoming trip in which case I'll post up a mini review.
- ChrisHolmes (Sun Mar 08, 2020 11:18 am)
- Has thanked: 39 times
- Been thanked: 59 times
Well I was cleaning the car when just for a change it started to rain!!!!
Crystal White 40th Anniversary
001/400
001/400
- Has thanked: 219 times
- Been thanked: 350 times
Keni must be doing something to his car then.
- These users thanked the author goodeggbob for the post:
- 30405 (Sun Mar 08, 2020 12:49 pm)
Rob
Took the car out to see how loud the RRP cat is and quite loud when going up the gears but OK when cruising along also no complaints from the boss
- Has thanked: 48 times
- Been thanked: 60 times
Managed to come back from Cadwell with completely spent front brake pads, so have just stuck some new 1144s on.
Sent from my Pixel XL using Tapatalk
The new 2022 Rotary Fleet - RX-8 PZ - Purple Helmet Warrior
Previous Threads:
2004 Sunlight Silver 231 Impulsive Panic Buy Rotary Shed - Sold & lesser seen RX-7 FD3s - R.I.P.
2005 Winning Blue 231
Previous Threads:
- Has thanked: 112 times
- Been thanked: 74 times
Air pump delete day today.
First thing was to check that I could actually remove the nuts holding the air feed to the exhaust manifold. Luckily they loosened with no real force.
I hadn't bought a blanking plate so out came the grinder and Piller drill and some sheet. Copied the shape (close but not exact) measured the holes. 7mm hole and 43mm from the inner edge to the other. That gave me 50mm between hole centers.
Drilled the holes. Cut out the shape.
Whipped up a plate.
Next, removed the air pump and valve. Fed the line from the solenoid and attached it onto the nipple on the SSV actuator ( the dreaded tapping noise cause (one of em) no more clacking
viewtopic.php?t=79722
I also found another possible cause of the rattle is where the bar is attached to the actuator via the c-clip. There's a little bit of play in there too. I think a nylon washer to reduce the play would fix that.
Anyhoo, Repositioned the fuel pump resistor and mounted the barometer.
Tidied up and done
All in all it could've taken less time but I wasn't in a hurry. 10-2pm 4hrs total with many chats, coffees and tripping over crap in my garage.
I love this dudes videos. I can't stop hearing "and take it off" in my head
Now to some real work. Mopping the floors in the house
PS and it didn't rain again!
Whipped up a plate.
Tidied up and done
- These users thanked the author sKenDread for the post:
- 30405 (Sun Mar 08, 2020 7:29 pm)
Kia-ora!
'09 R3 Aurora Blue Mica
- Has thanked: 750 times
- Been thanked: 175 times
Any chance you can knock up another blanking plate?sKenDread wrote: Whipped up a plate.
- sKenDread (Sun Mar 08, 2020 11:56 pm)
- Has thanked: 41 times
- Been thanked: 109 times
Pulled the R3 out the garage,spent a couple of hours washing and waxing the gal,fitted a new battery - I fit a new Varta E23 every year - checked and corrected the tyre pressures,as they always lose a bit during hibernation,then took her for a 30 mile run...and fell in love all over again. Been seriously considering putting her up for sale,but now I'm really torn..
Renewed my membership.
- These users thanked the author Honkytonk for the post (total 3):
- Ainmhidh (Sun Mar 08, 2020 9:39 pm) • sKenDread (Sun Mar 08, 2020 9:58 pm) • 30405 (Sun Mar 08, 2020 10:22 pm)
Cleaned throttle body and reset fuel trims.
Why the jaffing heck do you buy a new battery every year?! That's hideously bad for the environment. I appreciate this is a forum of RX8 owners, some running decats, but how fecking wasteful is a new battery every year?!?!SeeJay wrote: ↑Sun Mar 08, 2020 8:36 pmPulled the R3 out the garage,spent a couple of hours washing and waxing the gal,fitted a new battery - I fit a new Varta E23 every year - checked and corrected the tyre pressures,as they always lose a bit during hibernation,then took her for a 30 mile run...and fell in love all over again. Been seriously considering putting her up for sale,but now I'm really torn..
Just disconnect it over winter or get a trickle charger...
- shroom (Sun Mar 08, 2020 9:40 pm)
- Has thanked: 90 times
Ordered a clutch kit from usa today stage 2. See how well it does had a stage 4 in my subaru 5 years no problem so see what the stage two is like as my old one has the rattle dont trust it to do another track day lol
- Has thanked: 233 times
- Been thanked: 146 times
Thanks for renewing Duncan. For some reason I'm currently seeing a number of failed delivery responses when I send emails for renewals and new members. Hopefully normal service will be resumed shortly.
What I choose to do with my car has zero to do with your opinion.Dr. FrankenRex wrote: ↑Sun Mar 08, 2020 9:18 pmWhy the jaffing heck do you buy a new battery every year?! That's hideously bad for the environment.
I use a battery conditioner during hibernation,but still like to fit a new battery,and the hell with the environment..
Just out of curiosity do you do some good for the environment and recycle the batteries by donating them for a good cause
- These users thanked the author Neilparry for the post:
- Dr. FrankenRex (Mon Mar 09, 2020 10:41 am)
