Has thanked: 51 times
Been thanked: 173 times
Post by PaulAV » Thu Jan 30, 2020 2:37 pm
Have moved on to my next project, front and rear mudflaps, were fairly fast pink, now sunlight silver, filled, primed and first coat of silver applied. At some point I'm going to have to fit these, along with the aero skirts, managed to download pdf files for oem fitment, any hints and tips? Searched already and there was a post about fitting, but it's no longer available.
Mog1
Been thanked: 11 times
Post by Mog1 » Thu Jan 30, 2020 10:29 pm
Took the RX8 to the garage for repairs and MOT. Needs new drop links, rear coil spring, two tyres and discs and pads. First time driving it since the summer. Total mileage covered since last MOT, 260 miles. Too busy last year to really enjoy it. But me and the wife intend to enjoy it this year
johnbb99
Has thanked: 310 times
Been thanked: 41 times
Post by johnbb99 » Fri Jan 31, 2020 12:01 am
Cue GSB....
dvs
Post by dvs » Sat Feb 01, 2020 2:07 pm
I can't really take credit for "doing" this but managed to fix up a bunch of issues yesterday (credit to Luke Murdoch):
- replace engine mounts
- replace exhaust/cat gasket
- fix oil leak
- fix rear droplinks
- fix rear ns shock
- fix os front ABS wiring
- fix os wing mirror (not pitching up/down)
- replace interior passenger lamp
- fix handsfree kit (mic unplugged :D)
- fit custom plate
chuffed!
2004 Sunlight Silver 231
Has thanked: 4523 times
Been thanked: 1877 times
Post by ChrisHolmes » Sat Feb 01, 2020 3:37 pm
Calibrated the EDFC and it bleeps away merrily doing its work invisibly.
Has thanked: 87 times
Been thanked: 88 times
Post by bigpete8 » Sat Feb 01, 2020 4:37 pm
Fitted new battery terminals.
Didn't all go to plan as think I've messed up fuel trims.
viewtopic.php?f=6&t=74918&p=1248881#p1248881
EDECOA Battery Terminals Connectors with Wing Nut 12 / 24V Battery Clamps (1 pair)
Has thanked: 28 times
Been thanked: 227 times
Post by Neilparry » Sat Feb 01, 2020 4:37 pm
ChrisHolmes wrote:Calibrated the EDFC and it bleeps away merrily doing its work invisibly.
Does this mean I’ll see you next Thursday Image
Has thanked: 82 times
Been thanked: 95 times
Post by Scartlead » Sat Feb 01, 2020 5:46 pm
looked at my 8, said hello but got no reply :)
Post by ChrisHolmes » Sat Feb 01, 2020 9:47 pm
Certainly does as I presumed you had swapped me and Dan around.
Post by Neilparry » Sat Feb 01, 2020 9:50 pm
Yep I’m picking his up Wednesday so is Thursday ok
ChrisHolmes (Sat Feb 01, 2020 9:56 pm)
Davred
Post by Davred » Sat Feb 01, 2020 10:56 pm
Removed rear offside light cluster. Dried out the water spots inside with hairdryer. Fitted new gasket which I covered with silicone grease then re-fitted and torqued up.
Hopefully will stay dry this time, third time of doing!
Velocity Red, 231.RR rebuild and street port.KKS Cat.
Chilli Red MR2 Roadster
Daily car MB GLA 4matic amg line
Based in Leamington Spa.
RED's the Thing!!! (Mostly) :thumleft:
shroom
Has thanked: 49 times
Been thanked: 335 times
Post by shroom » Sat Feb 01, 2020 11:09 pm
Scartlead wrote:looked at my 8, said hello but got no reply :)
Image similar to me , noticed an albatross has plopped all over it so gave it a jet wash didnt thank me or even acknowledge me. I'm sure its upset but it ain't going anywhere until the AGM
Sent from my SM-N960F using Tapatalk
Post by Scartlead » Sun Feb 02, 2020 9:45 am
The Nerve of it :)
Post by PaulAV » Sun Feb 02, 2020 4:02 pm
So while fitting the front aero splash guard, I couldn't help being nosey and I looked behind the plastic expecting to see rust, all I can say is the rust treatment guy must of got some the night before.
Post by ChrisHolmes » Sun Feb 02, 2020 5:26 pm
Drove over to meet Gary Deery at Peartree Services, Oxford. Car ran well, fiddled with the EDFC.
Parked for about an hour then set off to Johns (Vj4sothername) place.
The dreaded rear end vibration returned, like driving with a badly flat spotted tyre you can hea4 and feel it plus the rear spoiler visibly vibrates. After a couple of miles thinking the car would shake itself apart the vibration suddenly stopped!
Hmm! Maybe because the tyres are a few years old the PS rear had “set” with a flat section whilst parked and then once some heat got into the tyre it levelled out.
Anyone experienced anything similar to this?
Techathy
Been thanked: 19 times
Post by Techathy » Sun Feb 02, 2020 6:08 pm
Failed hub bearing on a BMW 1 series, but that would also appear as suddenly as it disappeared.
These users thanked the author Techathy for the post:
ChrisHolmes (Sun Feb 02, 2020 6:32 pm)
Techathy
Post by Techathy » Sun Feb 02, 2020 6:12 pm
Took the rear brakes apart as best I could without a new 'rebuild' kit cleaned everything, put in back together and bleed the brakes. Also, look at and despaired at the amount of corrosion behind the rear arch liners.
Has thanked: 139 times
Been thanked: 505 times
Post by qwakers » Sun Feb 02, 2020 7:40 pm
got a similar issue with the laguna at the moment. caused by a sticking caliper and warped disk. its also very random.
Has thanked: 245 times
Been thanked: 544 times
Post by Dr. FrankenRex » Sun Feb 02, 2020 8:12 pm
Test fit of the track wheels!
Ordered tyres too, some cheap Accelera 651s in soft!
Post by PaulAV » Mon Feb 03, 2020 3:20 pm
Continued with the aero kit install, today was side skirt/deflector day, again I'm surprised at how well my car is resisting the dreaded rust, definately wasn't a Friday car in the rust treatment department.
shroom
Post by shroom » Mon Feb 03, 2020 3:27 pm
Dr. FrankenRex wrote:Test fit of the track wheels!
I like the bales in the background gives it that barn look Image
Post by Dr. FrankenRex » Tue Feb 04, 2020 8:28 am
Somewhat controversially that is why I called it the Auto Barn ;) :lol:
Post by Dr. FrankenRex » Tue Feb 04, 2020 12:40 pm
Well hello there 265/35R18 tyres!
Picture won't upload properly for some reasons, but they're tasty meaty bois
Post by ChrisHolmes » Tue Feb 04, 2020 2:58 pm
Loaded the car ready for Thursday at Neil’s.
Ainmhidh
Has thanked: 360 times
Been thanked: 321 times
Post by Ainmhidh » Tue Feb 04, 2020 3:34 pm
think you need to put a bit more weight on the front end Chris. Looks like the steering will be light at that angle.
These users thanked the author Ainmhidh for the post (total 2):
Vj4sothername (Tue Feb 04, 2020 3:39 pm) • johnbb99 (Tue Feb 04, 2020 7:38 pm)
