Has thanked: 373 times
Been thanked: 1419 times
Post by warpc0il » Sun Dec 29, 2019 2:43 pm
That much wear in the diff isn't ideal but at least there's no chunky bits.
Fresh oil and she'll be fine
mrspiller (Sun Dec 29, 2019 3:49 pm)
Has thanked: 118 times
Been thanked: 266 times
Post by mrspiller » Sun Dec 29, 2019 3:50 pm
warpc0il wrote:That much wear in the diff isn't ideal but at least there's no chunky bits.
Will do
Has thanked: 4523 times
Been thanked: 1877 times
Post by ChrisHolmes » Sun Dec 29, 2019 9:18 pm
Tidied up the charge cooler radiator piping which all routes to the left side of the engine (looking from the front) one connection to the bottom left front of the intercooler, a second to the top left rear.
Filled the system, turned in the ignition to start the pump and prime the system only to find FL22 pouring out under the car! It was running down the spark plug face of the front housing, and I mean pouring not dripping. Switch off the pump and it stops.
Totally puzzled as there are no pipes / hoses of the charge cooler circuit on that side of the engine. Definitely not from the engine which runs fine.
Post by warpc0il » Sun Dec 29, 2019 11:04 pm
@Chris Do you have a pipe off the throttle body?
Or it could be random failure of a heater hose...
Post by ChrisHolmes » Mon Dec 30, 2019 12:31 pm
Cannot be either as the engine cooling system is separate and isn’t losing fluid.
As soon as the SC circuit pump start the FL22 just pours out!
Post by warpc0il » Mon Dec 30, 2019 1:01 pm
Go seek with a UV light...
Post by mrspiller » Mon Dec 30, 2019 1:12 pm
Here a piccy of the oil in the pan , is that bronze sparkle a bad sign , showing wear Image? The rear end has had a horrible whirring noise on RH corner .
shroom
Has thanked: 49 times
Been thanked: 335 times
Post by shroom » Mon Dec 30, 2019 1:36 pm
Looks like you have been panning for gold
Sent from my SM-N960F using Tapatalk
Post by mrspiller » Mon Dec 30, 2019 1:39 pm
Might need to if I need a new diff lol
Has thanked: 28 times
Been thanked: 227 times
Post by Neilparry » Mon Dec 30, 2019 2:47 pm
Yep. That’s your thrust washers failing.
Need to replace before it goes “bang”.
mrspiller (Mon Dec 30, 2019 3:50 pm)
shroom
Post by shroom » Mon Dec 30, 2019 5:05 pm
Well I thought I better start mine and clean the brakes off. Let it warm up and took it for a drive up and down the private drive on the estate which isn't gritted, got the blowers on to dry it all out and put it back away again.
leeroy69
Has thanked: 48 times
Been thanked: 15 times
Post by leeroy69 » Mon Dec 30, 2019 5:21 pm
Taken the differential alloy cover off for a clean and inspection. What sealant do I use when replacing it chaps...
Post by ChrisHolmes » Tue Dec 31, 2019 6:36 pm
Sorted! The car was jacked up at the front so I dropped it down level. Removed the air filter and throttle body to give a better view, just, of things. Replaced the FL22 with water and started the pump. Water flowed down the front iron and cover.
Looking underneath it was coming off the bottom of SC casing!
Back up top and I immediately spotted green liquid in the groove on top of the SC between the gear case and the main body. When the car was jacked up the fluid must have been flowing behind the breather hose that runs across the groove, once level it sores£ across the whole width of the groove.
The hose clamp was tight, but the pipe was not. Removal of the clamp revealed that the two sides were touching before the hose was fully clamped, got to love fancy SS hose clamps.
So in a nutshell it was all down to me selecting an incorrect size hose clamp.
One clip later and all was fine again.
Now to find why the aux engine water temp gauge isn’t working after fitting the adaptor into the top hose!
These users thanked the author ChrisHolmes for the post (total 2):
nightfire10 (Tue Dec 31, 2019 7:03 pm) • Vj4sothername (Wed Jan 01, 2020 12:47 am)
Has thanked: 90 times
Been thanked: 257 times
Post by V8 Power » Tue Dec 31, 2019 8:25 pm
Glad you got it sorted Chris
ChrisHolmes (Tue Dec 31, 2019 8:27 pm)
Direct cold air feed
RRP Coils MSD leads
Bigblueknight3k
Has thanked: 108 times
Been thanked: 51 times
Post by Bigblueknight3k » Tue Dec 31, 2019 8:29 pm
Yep i might have bolt my temp sensor adapter down
Has thanked: 51 times
Been thanked: 173 times
Post by PaulAV » Thu Jan 02, 2020 4:59 pm
So finally got around to fitting my stainless braided oil cooler hoses, not a moment too soon either, although they had been replaced under the mazda recall, they were about 11 years old and In places suffering really bad, took about 4 hours so far, didn't help that I have a racing beat intake which took half an hour to get out, just got to clamp everything tidy and put the car back together, but while it's apart going to make an ally under tray and replace the oil seal in my sohn adapter, surprisingly I hadn't been getting a random misfire or eccentric shaft sensor issue, it was caked in crap, but all nice and clean now, you watch me get a fault now.
Post by ChrisHolmes » Thu Jan 02, 2020 10:31 pm
Refitted then bumper which now fitted properly unlike after I reversed the car off a kerb!
DS Tein to remove tomorrow to replace the seized adjuster screw. Under tray to refit and then that’s it for now.
Well until I get the buckets seats and 4 point belt bar fitted!!!
Vj4sothername (Fri Jan 03, 2020 12:04 pm)
Juey
Colour: Black Cherry
Has thanked: 20 times
Been thanked: 98 times
Post by Juey » Fri Jan 03, 2020 11:38 am
Major works over the holidays - finally replaced drivers side windscreen washer nozzle.
That is all. 8)
These users thanked the author Juey for the post (total 2):
Vj4sothername (Fri Jan 03, 2020 12:04 pm) • nightfire10 (Fri Jan 03, 2020 1:45 pm)
Has thanked: 80 times
Been thanked: 263 times
Post by mi60o0 » Fri Jan 03, 2020 1:57 pm
Steering wheel
Thanks bigpete
These users thanked the author mi60o0 for the post (total 3):
GreySilver Beast (Fri Jan 03, 2020 2:01 pm) • ChrisHolmes (Fri Jan 03, 2020 3:50 pm) • Honkytonk (Fri Jan 03, 2020 4:07 pm)
BatRex 192 stock
Has thanked: 9380 times
Been thanked: 2251 times
Post by GreySilver Beast » Fri Jan 03, 2020 2:03 pm
You now need PURPLE RX-8 Decals from the Club Shop Mihail :thumleft: :thumleft: :thumleft: :thumleft:
RX-8OC Club Calendar - R.A.C.E Car Club - NPT Website - GSB III 03/08/13 - Present
S/D-C/limits - RX-8,3MPS,RX-8 R3,GT86 =17 Skid Pan =1 Go Karting =1 Cars Driven =185
3 MPS MKII T/D = 6
RX-8 R3 T/D = 5 + 7 session's
GT86 T/D = 60.5 + 31 session's
Total T/Days Jan 2011 = 71.5 + 38 session's
Post by ChrisHolmes » Fri Jan 03, 2020 3:49 pm
Final task today was to remove the DS TEIN Coilover and replace the £10 seized adjuster. Simple you would think except it was not to be due to shearing 3 top mount bolts and then the adjuster shaft sheared off down inside the main rod.
Unit now has to go off to TEIN for repair!
Sheared adjuster.JPG (66.03 KiB) Viewed 46 times
Both Front units.JPG (173.27 KiB) Viewed 46 times
3 Sheared bolts.JPG (110.3 KiB) Viewed 46 times
Vj4sothername
Has thanked: 478 times
Been thanked: 124 times
Post by Vj4sothername » Fri Jan 03, 2020 4:08 pm
ChrisHolmes wrote:Final task today was to remove the DS TEIN Coilover and replace the £10 seized adjuster. Simple you would think except it was not to be due to shearing 3 top mount bolts and then the adjuster shaft sheared off down inside the main rod.
And this is why I fear using the rent-a-garage.
How long do you think it will take them to fix it? I guess it isn't cheap either.
S1 - 231 - brilliant black
Feb 08 built,
Fake Toyosport back box,
Dents,
Scratches,
Replacement engine,
Smiles
Has thanked: 210 times
Been thanked: 411 times
Post by Honkytonk » Fri Jan 03, 2020 4:12 pm
Didn't realise you had the Japanese sat nav controls mi60o0, nice. Do you already have the cruise mod as well?
The P-Shed Project Thread
Juey
Post by Juey » Fri Jan 03, 2020 4:19 pm
....and does the cruise work with the R3 wheel buttons???? :-k
Post by PaulAV » Fri Jan 03, 2020 4:35 pm
Finished putting the engine bay back together after swapping out oil cooler hoses, also swapped out the oil seal on my sohn adapter (its probably done 40,000 miles and I've started using more engine oil and less 2 stroke and I have no leaks now) just got to get some fuel and start it up, front end is still on stands.
