Has thanked: 26 times
Been thanked: 375 times
Post by Yorindesarin » Fri Sep 27, 2019 6:41 pm
Successfully changed the coils and leads. RRP and Magnecore! Starting up a lot better now to say the least. Whoever designed the stock airbox should be shot... Painfully... Several times. I will never understand how to get it in/out with ease! (out is easier... in what even)
The coils the car had on it. 2x bremi (one came apart whilst removing the crappy HT lead) and 2x what I can only presume were factory originals... One with a lovely white spot underneath!
Probably the last actual thing Ill get done before the car hopefully goes off the road for winter!
Honkytonk (Fri Sep 27, 2019 6:47 pm)
The Red 8:
Racing beat Revi, Tein street basis z coilovers, RRP Mk2 Coils (and one Mk3), Stock catback, Cruise Control (Zoom Zoom).
xamtex
Been thanked: 121 times
Post by xamtex » Fri Sep 27, 2019 8:47 pm
stripped the engine from my mazda 3 today,trying to find the cause of its 1 litre of oil to 100 mile thirst. and you think a rotary uses oil!!!
These users thanked the author xamtex for the post:
johnbb99 (Fri Sep 27, 2019 10:05 pm)
Post by Yorindesarin » Fri Sep 27, 2019 8:52 pm
Just drove to town and ooft does a proper ignition system make the car feel lively... Started it up again after going round tesco for it to stall... Think I forgot to do up the clamp around the accordian pipe... will have to check tomorrow not sure what else it could have been!
The Red 8:
Has thanked: 1186 times
Been thanked: 550 times
Post by nightfire10 » Fri Sep 27, 2019 9:10 pm
Mot passed today but advisory for valve stems cracked all 4! Tyres only 2 years old?
Has thanked: 489 times
Been thanked: 1995 times
Post by warpc0il » Fri Sep 27, 2019 9:36 pm
Yorindesarin wrote: Whoever designed the stock airbox should be shot... Painfully... Several times. I will never understand how to get it in/out with ease! (out is easier... in what even)
There's a knack to removing the airbox, which is dead easy.
Start with the engine hot, as this makes the accordian pipe soft.
Pull the box up to disengage the lugs and then push back hard to clear the front. If you've got a 192 then you can cut away the redundant VFAD pipe clip, which gives you more clearance.
Before refitting, apply a coat of silicone grease to the lugs underneath and to the end of the pipe, making it easier to fit and even easier to remove next time.
Post by Yorindesarin » Fri Sep 27, 2019 9:48 pm
Getting it out is a piece of cake Dave... Almost anyway! Getting it back in is a nightmare! The accordian pipe when I push the box back always ends up causing it to not go far enough so I cant clear the VFAD etc with ease... Not sure if I just apply force in the wrong direction or what.. But I always have a massive struggle with it.
The Red 8:
Has thanked: 5594 times
Been thanked: 2562 times
Post by ChrisHolmes » Fri Sep 27, 2019 9:55 pm
Guaranteed to be a combination of piston ring and bore surface finish. Are the bores alusil or sleeved?
Street Ported 231
MazdaSpeed skirts
xamtex
Post by xamtex » Fri Sep 27, 2019 11:17 pm
yes chris,bores do look glazed.but i must say there is little actual wear,no lip on bores,bearings like new and its all std and the barcode label says it was built in 2004.
johnbb99
Has thanked: 340 times
Been thanked: 46 times
Post by johnbb99 » Fri Sep 27, 2019 11:23 pm
Xamtex, is your Mazda 3 turbocharged?
Not likely, but if it's like my Mazda 6 it's possible that oil is going from the turbocharger into the engine.
(In my case it consumed all the oil before I had an indication that there was something wrong. 😞)
Post by ChrisHolmes » Sat Sep 28, 2019 12:10 am
Modern engine bores can look glazed if they are alusil and you cannot glaze bust them in the traditional way it’s a job for a engine machine shop using a honing head fitted with diamond stones and then finishing with felt pads and abrasive paste.
Street Ported 231
MazdaSpeed skirts
xamtex
Post by xamtex » Sat Sep 28, 2019 2:55 am
found this via google... The LF-DE has a high-grade aluminum alloy cylinder block with cast iron sleeves...so its a session with my honer.
and its non turbo.
These users thanked the author xamtex for the post (total 2):
johnbb99 (Sat Sep 28, 2019 9:13 am) • ChrisHolmes (Sat Sep 28, 2019 11:00 am)
Post by warpc0il » Sat Sep 28, 2019 11:35 am
so it's a session with my honer.
Nigel? [-X
GreySilver Beast (Sat Sep 28, 2019 11:45 am)
Post by ChrisHolmes » Sat Sep 28, 2019 1:30 pm
That’s an h not a b !!!
Street Ported 231
MazdaSpeed skirts
Markl17
Colour: Stormy Blue
Has thanked: 46 times
Been thanked: 193 times
Post by Markl17 » Sat Sep 28, 2019 2:18 pm
My car passed the ct,today with no advisory’s happy days.
Mark
These users thanked the author Markl17 for the post:
nightfire10 (Sat Sep 28, 2019 2:42 pm)
Post by nightfire10 » Sat Sep 28, 2019 2:45 pm
After getting an advisory on mot for cracked valve stems I went back to ats who fitted tyres 2years ago they changed valves balanced and refilled with nitragen all for £20
Has thanked: 297 times
Been thanked: 649 times
Post by Honkytonk » Sat Sep 28, 2019 7:43 pm
Tried changing my sparks and coils. Failed miserably at the former. Gave up as I was losing light and it was raining. Don't think I've ever left a job unfinished but there's always a first...
Have a gander at my Diamond in the Rough (Now with extra Orange!) in
The P-Shed Project Thread
And my OEM-only Luton Adonis, the awful(ly fantastic!) Mighty Vectra
Nickp47
Has thanked: 126 times
Been thanked: 259 times
Post by Nickp47 » Sat Sep 28, 2019 7:49 pm
What was the issue with the plugs?
Post by Honkytonk » Sat Sep 28, 2019 8:14 pm
They wouldn't come out. Blaming my tools as I think the socket extension I was using was intruding on the spark plug socket, and I either couldn't get leverage because of how tight the space was or, the extension wasn't long enough.
I will try again, with some better tools. Just miffed by my apparent lack of ability to do such a basic thing.
Nickp47 (Sat Sep 28, 2019 8:17 pm)
Has thanked: 1542 times
Been thanked: 1566 times
Post by MARKTHOMASBRAND » Sat Sep 28, 2019 8:23 pm
Better than snapping them off :D
At least you still have use of the car :thumleft:
TBH I thought the plugs were easy on the RX8 but that was in comparison to changing them on an LT1 V8 in a 4th Gen Camaro Z28 :!:
You'll be fine with some more time & light 8)
Mark's : 2020 Championship White Honda Civic FK8 Type R .
Mandy's : 2019 Mazda MX-5 30th Anniversary RF # 1761/3000.
Has thanked: 211 times
Been thanked: 807 times
Post by qwakers » Sat Sep 28, 2019 8:30 pm
you want hard? try getting at the rear 3 in a 3vz-fe v6 swapped mr2!
Post by warpc0il » Sun Sep 29, 2019 11:10 am
You need a wobbly extention or a uj as the access isn't directly in line and otherwise there's a strong chance of snapping the plugs and/or damaging the threads.
Post by Honkytonk » Sun Sep 29, 2019 11:36 am
Have a UJ, just a bit short. (I tried it on the spark socket as well before someone says)
At least I didn't break the plug
#-o
Not to fear. Any excuse for some new tools.
shroom
Has thanked: 57 times
Been thanked: 473 times
Post by shroom » Sun Sep 29, 2019 11:41 am
Honkytonk wrote:Image
#-o
Bit overkill but always worth having tools in Image
My spark plugs did the same on the end, TBF it was one of the easiest jobs I have done on the RX-8 funny how some cars cause people problems !
Post by Honkytonk » Sun Sep 29, 2019 11:53 am
Breaker bar is massive overkill, but I don't have one at present so will be good to have about anyway. It's an investment, or so I tell Mrs Honkytonk.
Vj4sothername (Sun Sep 29, 2019 12:10 pm)
shroom
Post by shroom » Sun Sep 29, 2019 11:58 am
Honkytonk wrote:Breaker bar is massive overkill, but I don't have one at present so will be good to have about anyway. It's an investment, or so I tell Mrs Honkytonk.
Yeah TBF I used the breaker bar as it was nice and long so made it easy to wind it in then tighten up with socket and extension
