Has thanked: 24 times
Been thanked: 236 times
Post by Yorindesarin » Sun Sep 01, 2019 7:40 pm
Ooft thats come up a treat. Might have to look into doing that myself at some point. My shrouds are unsurprisingly grey like everyone elses. Would be nice if they matched the rest of the plastics! But at the same time I may wait until I get a different bumper as mine has some damage to it. Though thats on the back burner for "when I respray to a different colour." So quite far down the line as of yet.
Has thanked: 239 times
Been thanked: 502 times
Post by Honkytonk » Sun Sep 01, 2019 7:44 pm
Took it for a Razz tonight as it had been sat around for a week and a half, poor thing :(
Time away makes the heart grow fonder, and boy did I miss it. Gave it a proper good thrashing and saw a winning blue one stuck behind someone else going the other way - my hands were too firmly glued to the wheel to wave :twisted:
The P-Shed Project Thread
jondkent
Colour: Stormy Blue
Has thanked: 56 times
Been thanked: 60 times
Post by jondkent » Sun Sep 01, 2019 8:24 pm
Took it for a nice long journey. Fun though Mintex pads are so squeaky that I've had enough of them. Back to ebc redstuff for me.
Has thanked: 4807 times
Been thanked: 2028 times
Post by ChrisHolmes » Sun Sep 01, 2019 8:43 pm
The 1144s should not squeak at all if the bedding in procedure has been followed. Do you have the anti squeal shims fitted to the back of the pads.
Bridge Ported 231
MazdaSpeed skirts
Short shifter
jondkent
Colour: Stormy Blue
Post by jondkent » Sun Sep 01, 2019 9:11 pm
ChrisHolmes wrote:The 1144s should not squeak at all if the bedding in procedure has been followed. Do you have the anti squeal shims fitted to the back of the pads.
Hmm, good question about the shims, I'll double check. Cheers
Has thanked: 399 times
Been thanked: 1558 times
Post by warpc0il » Sun Sep 01, 2019 11:14 pm
A thin wipe of Ceratec on the back of the pads also helps prevent squeaks.
brix79
Has thanked: 97 times
Been thanked: 333 times
Post by brix79 » Sun Sep 01, 2019 11:33 pm
Juey wrote:
Sun Sep 01, 2019 7:01 pm
Finally took the plunge and bought some bumper dye - results are pretty remarkable. Took many coats to cover the blue/grey but very pleased with how it's turned out.
Time will tell how long it lasts.......
They do look the business, will be interesting to see how it lasts compared to DTP (Direct to Plastic) as I was very pleased with the results from that too. :thumleft:
Chairman & Forum Admin Team
2017 // 2010 Aurora Blue R3
Potenza S001s | 20mm Eibachs | M1144s | Pettit Catback
2011-17 // 2005 Titanium Grey 231 | Gone, but never forgotten..
brix79
Post by brix79 » Sun Sep 01, 2019 11:41 pm
The Pettit is now on the car. At last!
The tips don't quite line up in terms of their protrusion, not sure how to deal with that. :-k
Sounds great though, instant grin. Now where's the nearest tunnel.. :twisted:
Juey
Colour: Black Cherry
Has thanked: 20 times
Been thanked: 100 times
Post by Juey » Mon Sep 02, 2019 11:01 am
""The tips don't quite line up in terms of their protrusion, not sure how to deal with that. :-k ""
Worry not, the flames will even out the bodywork around them for you.
It's tru dat!
I can explain it to you, but I can't understand it for you.
Juey
Post by Juey » Mon Sep 02, 2019 11:05 am
Used MLM bumper dye - came with a foam applicator (but this makes the dye go bubbly) and a micro fibre cloth - best to use this by dabbing into a small pot of the dye as it goes on more evenly without the bubbles :thumleft:
That looks wicked, I suffer the same issue, where did you get that black dye from? I could do with some.
eBay £11
a google search for mlm bumper dye brings up options for applicators with the bottle.
I put on many coats to the bumper and shrouds and only used a quarter of the bottle - loads left for topping up when it needs it, but hoping it doesn't all run off in the first shower :shock: :lol:
These users thanked the author Juey for the post:
Devon_Fourie (Mon Sep 02, 2019 9:37 pm)
Bigblueknight3k
Has thanked: 116 times
Been thanked: 57 times
Post by Bigblueknight3k » Mon Sep 02, 2019 6:45 pm
Hello everyone need a bit of help want to fit oil pressure and oil temp sensors heard banjo bolts can be changed to put sensors in the top not got a clue what size etc any help would be great
Post by ChrisHolmes » Mon Sep 02, 2019 8:47 pm
Simplest way is to use a sandwich plate under the oil filter and put both sensors there.
You can buy modified banjo bolts from the USA but your other option if your practical is get done banjo bolts from a breaker and drill and tap them yourself to suit the senders.
Bigblueknight3k (Mon Sep 02, 2019 8:56 pm)
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Luke0611
Has thanked: 16 times
Been thanked: 25 times
Post by Luke0611 » Mon Sep 02, 2019 9:00 pm
Looked at it, sad that I'm no longer insured on it. Going to miss it when it goes
Sent from my SM-G960F using Tapatalk
40th Anniversary [97/400] in Ford Frozen White. Sprayed by Scratch Repairs, Catshill (West Mids)
Engine Rebuild + bridge port with balanced rotating assembly by Ryan Rotary Performance.
Toyosports SS Catback, Japspeed Decat, TEIN Flex Z Coilovers
Nissan 350z GT4 [29/176] Black FOR SALE
Has thanked: 28 times
Been thanked: 250 times
Post by Neilparry » Tue Sep 03, 2019 8:14 pm
Set the alignment with our trusty gauge.
Maxed out on the negative camber and set the toe 1.5 ish out. Image
Rears already set as the rear end came off “Bully”.
And fitted the splitter
Post by warpc0il » Tue Sep 03, 2019 11:27 pm
Why have you "set the toe 1.5 ish out" ?
FWD cars normally run some Toe Out, as the wheels are trying to pull ahead of the car, so when all the slack is taken up under power, the result is nearer zero.
RWD cars normally run Toe In, as the car is being pushed from the rear, between the front wheels, so when all the slack is taken up under power, the result is nearer zero.
The Mazda specification for the 8 is Toe-In 1.4 +/-2.8,, which would allow you to to be 1.4 Out, but it still doesn't make any sense to me, unless you're planning to do something very unusual with the car.
sKenDread
Has thanked: 206 times
Post by sKenDread » Tue Sep 03, 2019 11:54 pm
warpc0il wrote:Why have you "set the toe 1.5 ish out" ?
Maybe to get that "early turn in" feeling?
I had my alignment done recently and it was toe out on the front. It did have an early turn.
Now it's been set to stock again and I notice it's slightly heavier to turn in although straight lines seem to be more... Straight and cornering seems to be smoother
Kia-ora!
RRP Performance Ignition Coil System MKII | RRP Mini Map | RRP COFS | Powerflow Twin Exhaust
Tein Flex Z Coilovers | 245 40r18 Uniroyal Rainsport3
Original engine 80k
Compression 050519 F: 4.38,4.72,4.78 R: 4.83,4.78,4.78
'08 231 PS, Galaxy Grey, Black Leather
Has thanked: 656 times
Been thanked: 557 times
Post by New Duke » Wed Sep 04, 2019 12:35 am
When mine was setup recently for track we put on some toe out. The idea was indeed to improve cornering. But in our case that meant reducing the toe out as it was previously in snowplough. The sweet spot we found was an angle that would give a nice sharp turn in, but not kill the tyres or create any tangible parasitic loss through increased drag. Which is likely where you'll want a motorsport engineer with lots of experience, hence why I didn't argue and just helped.
We also went as maximum as possible on the camber for the same reason, but were limited by the design of the PZ suspension and height of the car.
My castor bolts were rusted solid (like will-need-to-be-cut-out solid) but thankfully both sides were perfectly even and at an OK angle.
I was planning to go back for a tweak now it's been tested on track. But it's very good already tbh.
warpc0il (Wed Sep 04, 2019 12:49 am)
Post by warpc0il » Wed Sep 04, 2019 12:44 am
Interesting...
I played with zeroing the toe on my Alfa, to improve turn-in, but found that the trade-off in rolling resistance (obvious by the tyre wear) and the increased tendency to tramline, didn't make it worth while, on the road.
Post by Neilparry » Wed Sep 04, 2019 5:12 am
It’s going on track and most of the tracks I go on are quite tight.
Looking for a positive turn in hence the toe. And you don’t get the tram lining on track that you do on the road.
It’s more a case of trial and error, so a tweet here and there is easily sorted.
Alignment is always contentious
What works for one !!!
Has thanked: 141 times
Been thanked: 327 times
Post by V8 Power » Wed Sep 04, 2019 6:06 am
My car was set with toe out (can’t remember how much) it definitely improves corner turn in on track.
Direct cold air feed
RRP Coils MSD leads
Has thanked: 92 times
Been thanked: 97 times
Post by bigpete8 » Wed Sep 04, 2019 12:16 pm
wiped the baked bean juice off the passenger seat....
Early start picked up breakfast on way in - didnt notice till back out at car at lunch :(
Luckily leather seats dont absorb much but could do with buying more leather wipes!
Post by Yorindesarin » Wed Sep 04, 2019 12:33 pm
Got some headlight restorer off amazon. Going to probably polish up my spare set of headlights off the car and swap them over when its a decent day!
Post by Honkytonk » Wed Sep 04, 2019 1:08 pm
Which one did you plump for?
Post by Yorindesarin » Wed Sep 04, 2019 1:11 pm
Went for this in the end:
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
From what I gather most of them around the same price work just as well as each other.
Also currently waiting for a pilot bearing I ordered from Rotary Revs last friday... Rang up to enquire about the progress of it get told it'll be packaged up and sent out today... Seems a bit slow if they ship 7 days a week... :/ Waiting for it to get my clutch changed...
Has thanked: 166 times
Been thanked: 569 times
Post by qwakers » Wed Sep 04, 2019 5:52 pm
been having issues with the daily driver recently (not the rx8 but it is a car so sorta ok in here? :D. long list of issue with it but today it started using a lot of oil at full throttle and it cut out on me dead 3 times on the way home. thatll be the turbo just let go then :(
just going out to the garage to confirm, but this MIGHT put paid to me attending the ramp and bbq meet :cry:
