Devon_Fourie
Been thanked: 18 times
Post by Devon_Fourie »
Yorindesarin wrote:One thing about those LED projectors I don't particularly like is how bulbuous they might look in the door when fitted... I wonder as to why they're designed this specific way and if it would be possible to make them look a bit... Neater maybe?
Due to the lens that has to point down and inside they have a heatsink as well for the cree led used in the projection. They are a bit bulky but it’s kind of ok.
My next step will be to replace the actual white lights in that holding to red ones to match my colour scheme. So it will be red door lights with white projection.
Ollie
Been thanked: 283 times
Post by Ollie »
Yeah that is a bit bulky. And I was also going to change the puddle LED to red if I can. I wonder if theres enough room behind the door card to move the heatsink etc back out of the way possibly. Just wondering if it would be possible to reeingineer it so the projecter points downwards at an angle out of the way compared to directly down and bulbuous looking. For 13 quid theres no real loss... I'm pretty sure theres a possibility of doing it a little better with some work. The question is if I can manage it.. :p
You can get logo projector lights that fit in the mirror housing, much neater as they're already facing down.
Ollie
Post by Ollie »
Oo. Ill have to have a look for those then Dave, or do you perchance have a link? Im pretty sure theres a much neater way to do what these chineese ones are doing anyway. Just seems like they were made the way they are for the sake of easy and quick to manufacture.
Found this video on youtube... Looks like a bit of a better solution for a bit more money on the puddle light LEDs. Hm.
https://www.youtube.com/watch?v=os3O89yUZ8E
xamtex
Been thanked: 50 times
Post by xamtex »
had a hesitation on acceleration for a while so i took the plugs out today and found this.....
changed the plugs and its running well again....but the compression test i did was not the best news... high 5s on rear rotor...high 4s on the front. it starts hot and cold without tooo much drama so its let it develop time i think...do something with it over the winter.
Has thanked: 742 times
Been thanked: 284 times
Post by nightfire10 »
xamtex wrote:
Fri Aug 02, 2019 4:14 pm
what tester was it ?
xamtex
Post by xamtex »
the group buy tester
Has thanked: 100 times
Been thanked: 544 times
today i fitted a bluetooth handsfree kt for imaken.
considering it was a cheap chinese knockoff, it was no worse to install than the xcarlink. not as refined, but usable.
Dazza44
Has thanked: 105 times
Been thanked: 46 times
Post by Dazza44 »
xamtex wrote:the group buy tester
I wouldn't rely on them there really not very accurate one of my comp test came.back with cranking speed of over 800rpm and other members have had similar issues.
xamtex
Post by xamtex »
mine was doing that,but today after i pulled the ess plug off it was giving consistant good results...every time.
These users thanked the author xamtex for the post:
ChrisHolmes (Sat Aug 03, 2019 7:04 pm)
Been thanked: 220 times
Post by Neilparry »
All loaded up ready for its first shake down at Pembrey tomorrow since fitting Bully’s rear end and suspension components.
Hoping for quicker Lap-times ImageImage and a dry day.
These users thanked the author Neilparry for the post (total 2):
nightfire10 (Fri Aug 02, 2019 10:14 pm) • ChrisHolmes (Sat Aug 03, 2019 7:05 pm)
shroom
Has thanked: 16 times
Been thanked: 87 times
Post by shroom »
Neilparry wrote:Image
Just out of interest what's the weight of an RX-8 and trailer etc for towing?
Post by Neilparry »
Haven’t weighed it but I’m thinking car 1400kg + 400kg trailer
Not counting the spare wheels.
TerryH
Been thanked: 13 times
Post by TerryH »
Finaly got the 4 outstanding recalls done.
2 around tbe fuel pump, and both front airbags.
Used Guildford mazda, no issues with them, all work complete within 2 1/2 hours.
Now just keeping an eye out for any fuel leaks but so far so good.
If anyone else in the area still has recalls, i have no issue recommending them.
These users thanked the author TerryH for the post:
40th Anniversary Metropolitan Grey [028/400]
20mm Eibach Spacers
Milltek Pettit Exhaust ( Decat/ Highflow Cat)
Axial Flow Short Shifter
EBC Braided Brake Lines
RRP "Sohn" Adapter
RRP Performance Coil system MKII
RB REVi Intake & RAM Air Duct
PZ Suspension
Hmm I'm hoping to get mine tested on a proper tester to compare!
Has thanked: 38 times
Been thanked: 116 times
Post by mi60o0 »
I done mine on my old rex I had rr test and my tester rpm same values 0.1 bar different on one rotor
Post by mi60o0 »
I had pictures on my old phone and I think I was texting Chris at the time like always so mby is in our history rr test and my tester
Bigblueknight3k
Has thanked: 90 times
Been thanked: 45 times
Post by Bigblueknight3k »
Fitted one side of rear springs bit of a pain lolImageImage
Dave2112
Been thanked: 93 times
Post by Dave2112 »
Massive thanks to Chris Holmes for helping me replace my coolant hoses today. Still got the air pump to remove but ran out of time :( A job for another day :thumright: Beer and food on me Chris at the meet.
These users thanked the author Dave2112 for the post (total 3):
V8 Power (Sat Aug 03, 2019 6:35 pm) • ChrisHolmes (Sat Aug 03, 2019 7:06 pm) • Devon_Fourie (Sat Aug 03, 2019 10:10 pm)
Kamikaze
Too many to list.
Post by mi60o0 »
Chris do you do apoitment for hose replacement I want the purple set of these
Ninja_Freak
Has thanked: 40 times
Post by Ninja_Freak »
Looks excellent Dave!
These users thanked the author Ninja_Freak for the post:
Dave2112 (Sat Aug 03, 2019 9:54 pm)
56 Plate PZ in Galaxy Grey!!
Ollie
Post by Ollie »
Gave it a long overdue wash after 2-3 weeks of rain whenever I could wash it. Twas quite the mess to the say the least. I then took a picture with not my phone with the car facing the exact right way I swear so its just as good a picture as always!
mi60o0 wrote:
Sat Aug 03, 2019 7:16 pm
Only if within a 15 mile radius of my home!
Post by mi60o0 »
Don't let the distance to come between us dear...
SeeJay
Has thanked: 41 times
Been thanked: 109 times
Post by SeeJay »
ChrisHolmes wrote:
Sat Aug 03, 2019 9:13 pm
Ask Chris if he can recommend a local hotel or B&B...or maybe he has a spare room he's willing to let you stay in ;)
