Has thanked: 54 times
Been thanked: 182 times
Post by PaulAV » Sat Apr 06, 2019 5:12 pm
Fitted japspeed rear toe control arms today, the bolts were seized solid, even with drilling one was easy the other was a pain (the one that was a pain was because i drilled it too well and I still had a wall of metal around the drill hole, the easy one was a little off center and had blown through the wall, so released easier) those suspension arms are scary, so rusted there couldn't be much left to them.
Has thanked: 88 times
Been thanked: 275 times
Post by mi60o0 » Sat Apr 06, 2019 5:14 pm
For the last few weeks I just drive the rex
BatRex 192 stock
Has thanked: 86 times
Been thanked: 98 times
Post by Scartlead » Sat Apr 06, 2019 5:16 pm
Update your sig :) what do you think of them?
Post by PaulAV » Sat Apr 06, 2019 5:23 pm
The new arms are fine, they are more substantial than the standard arms, yet to drive the car as I just did a basic alignment with a straight edge across the wheel and measured the gap between straight edge and body,
Scartlead (Sat Apr 06, 2019 6:00 pm)
Has thanked: 130 times
Been thanked: 285 times
Post by mrspiller » Sat Apr 06, 2019 6:00 pm
PaulAV wrote:The new arms are fine, they are more substantial than the standard arms, yet to drive the car as I just did a basic alignment with a straight edge across the wheel and measured the gap between straight edge and body,
Try using a thin string line / fishing wire from front wheel to back wheel - that should give you a better indication Image
These users thanked the author mrspiller for the post:
PaulAV (Sat Apr 06, 2019 6:05 pm)
simonweb
Been thanked: 8 times
Post by simonweb » Sat Apr 06, 2019 7:20 pm
+10BHP!Image
Sent from my ANE-LX1 using Tapatalk
Post by mi60o0 » Sat Apr 06, 2019 7:26 pm
+10BHP!Image
Where from you get this one
BatRex 192 stock
SeeJay
Has thanked: 168 times
Been thanked: 360 times
Post by SeeJay » Sat Apr 06, 2019 8:23 pm
Shiny new Varta E23 battery fitted :thumright:
Has thanked: 350 times
Been thanked: 614 times
Post by kopite72 » Sat Apr 06, 2019 8:25 pm
NIce Chris,fitted the same a few weeks ago,excellent battery,the thing is a beast :rambo:
PLAN...RR HB OR FB PLATINUM REBUILD
FULL RESPRAY
DONE...
FULL MZ CUSTOMS KIT
MILLTEK CATBACK
JAPSPEED DROPLINKS
FULL ALLOY REFURB
RR D585 COILs
6000K HID KIT
TINTS
20MIL SPACERS
PROJECT THREAD....http://www.rx8ownersclub.co.uk/forum/vi ... 04&t=59971
LOOKED AFTER BY THE FANTASTIC CREW AT ROTARY REVS
LOVING DORITOS SINCE 1991
simonweb
Post by simonweb » Sat Apr 06, 2019 8:28 pm
mi60o0 wrote:
+10BHP!Image
Google `Mazda "Batman" Logo` and you'll find something!
This is the closest to what I ordered: https://amzn.to/2D1kCSW
SeeJay
Post by SeeJay » Sat Apr 06, 2019 8:31 pm
My third in six years of ownership,Ian.. I replace every two years ;)
Has thanked: 768 times
Been thanked: 311 times
Post by nightfire10 » Sun Apr 07, 2019 2:28 pm
Lidl oil pump put to good use again ! Oil change 30min's
Has thanked: 4647 times
Been thanked: 1958 times
Post by ChrisHolmes » Sun Apr 07, 2019 11:15 pm
Puzzled by this as the Varta E23 batteries seem to carry a 4 year warranty https://www.batteriesontheweb.co.uk/sho ... r-battery/
johnbb99 (Mon Apr 08, 2019 12:10 am)
Bridge Ported 231
MazdaSpeed sills
Short shifter
Has thanked: 259 times
Been thanked: 566 times
Post by Dr. FrankenRex » Mon Apr 08, 2019 9:03 am
Fair dos, but *why* do you replace every 2 years?
Has thanked: 386 times
Been thanked: 1483 times
Post by warpc0il » Mon Apr 08, 2019 9:21 am
I "replaced" the Bosch battery in my Alfa after only 2½ years, because it wouldn't hold its charge.
I suspect that this was my fault as I'd allowed it to go totally flat, twice, after not realising that my battery conditioner defaulted to Off after power cuts.
Anyway, it was replaced under the 4-year warranty.
Were these Varta "replacements" also under warranty?
jondkent
Colour: Stormy Blue
Has thanked: 56 times
Been thanked: 60 times
Post by jondkent » Mon Apr 08, 2019 9:41 am
20 brake stomp last night, and gave it 15 mins at idle, to see if that would sort out p301 error as I can't find anything else at fault. Seems (fingers crossed) to have done the trick, plus I'd swear it's performance has improved.
Nickp47
Has thanked: 85 times
Been thanked: 149 times
Post by Nickp47 » Mon Apr 08, 2019 5:58 pm
Bit of plasti dipping , not used it before, found removing the excess to be rather frustrating as it kept catching the bits I wanted to remain.
Dr. FrankenRex (Wed Apr 10, 2019 9:56 am)
Has thanked: 155 times
Been thanked: 540 times
Post by qwakers » Mon Apr 08, 2019 5:59 pm
i started it :D BRappy Brapness!
Post by warpc0il » Mon Apr 08, 2019 6:12 pm
I like the effect.
A good trick I found when doing badges etc is to degrease the area, badge and paintwork with IPA or Tec7 Universal Cleaner, allow to dry and then apply some silicon oil spray using a cotton bud to the paintwork, avoiding the edge of the badge.
The plastidip then sticks like sh*t to the badge and hardly at all to the paint.
Spray at least three light coats and let dry before you attempt to remove.
Nickp47 (Mon Apr 08, 2019 6:16 pm)
Post by PaulAV » Tue Apr 09, 2019 9:32 pm
Received my hardrace rear camber arms today, will be fitting them at the weekend, hopefully along with my newly ordered Ryan rotary High flow cat. Need to get the killer cat off sooner rather than later.
Been thanked: 613 times
Post by goodeggbob » Tue Apr 09, 2019 9:43 pm
seems like your car is having all its birthdays at the same time, runaway beemers are not so bad after all,good luck,rob.
PaulAV (Tue Apr 09, 2019 9:43 pm)
Essex2Visuvesi
Been thanked: 294 times
Post by Essex2Visuvesi » Wed Apr 10, 2019 9:54 am
Dropped Adam's off for MOT this morning
Post by Dr. FrankenRex » Wed Apr 10, 2019 9:58 am
Looks good. How long did you wait before peeling? I find it's much easier to peel if left for a day (looks daft for said day, sure) as the dip itself cures properly and 'tightens'. You can then peel with a greater degree of care around the parts you wish to keep :thumleft:
Nickp47
Post by Nickp47 » Wed Apr 10, 2019 10:23 am
Ah, that’s probably where I went wrong then, being impatient I only waited for a short while after the last coat.
I still have have the rear badges to do so with a combination of the advice from yourself and Warpcoil I should be able to make a better job of it. :thumright:
Post by Dr. FrankenRex » Wed Apr 10, 2019 10:36 am
It's all trial and error really, but it's a nice quick way of changing the look of bits. You can run some glossifier over it if you'd rather a gloss finish, but mileage varies quite drastically in my experience with that...
Nickp47 (Wed Apr 10, 2019 11:14 am)
