Brooksyvon89
Been thanked: 18 times
Post by Brooksyvon89 » Mon Jun 12, 2017 5:21 pm
PeteH wrote:
Brooksyvon89 wrote:Image
That's my baby! (I designed a lot of the suspension for it, so if you don't like the way it rides and handles it's my fault :thumright: )
It's a monster! Ploughs through and over anything!!!
Has thanked: 177 times
Been thanked: 786 times
Post by PeteH » Mon Jun 12, 2017 5:27 pm
(I know it's off topic, but hey, I may never get the opportunity to post this picture again)
This is a secret night time drive of a pre-production Freelander, before the car was released to the public :ninja:
1_0008 (2) (Copy).jpg (46.25 KiB) Viewed 1179 times
These users thanked the author PeteH for the post (total 2):
ChrisHolmes (Mon Jun 12, 2017 6:18 pm) • johnbb99 (Mon Jun 12, 2017 11:34 pm)
Has thanked: 766 times
Been thanked: 684 times
Post by New Duke » Mon Jun 12, 2017 8:51 pm
PeteH wrote:(I know it's off topic, but hey, I may never get the opportunity to post this picture again)
That's very cool Pete, wish my dad could have seen that.
We had one of the first batch of Freelanders, and many fun holidays conquering anything the alps would throw at it. IMO it was the only all-terrain vehicle in its class that was truly off-road capable. Ours sadly had the dreaded 1.8 Rover K Series engine though, which had to be rebuilt twice.
At the same time my parents also had an early MGF also with the K Series engine (which my mum has just begrudgingly decided to scrap after slowly losing a battle of 20 years of various engine issues). At 100k miles that was on it's third engine!
Such a shame as everything else about those cars, to me at least, was perfect and defined so much of my childhood.
So I always :roll: at the RENESIS' poor reputation for reliability... it's all relative and there are much worse out there!
(Sorry for the off-topic ;) )
northerner69
Been thanked: 28 times
Post by northerner69 » Mon Jun 12, 2017 10:00 pm
went de cat!
untakenname
Has thanked: 94 times
Been thanked: 113 times
Post by untakenname » Tue Jun 13, 2017 12:43 pm
warpc0il wrote:Opening the rear light units isn't that much of a problem, as a few people have found, using a fine saw blade in an oscillating multi-tool or a Dremal.
The challenge is to create an edge that can be glued back together without the joint showing.
There are plenty of used ones around to practice on.
A decent thin cutting disc I found to be best, went through a couple before I got the knack.
light shell.PNG (624.93 KiB) Viewed 1108 times
I started a thread about opening the lights a while back, will update it over lunch with the end results.
Edit: uploaded here http://www.rx8ownersclub.co.uk/forum/vi ... 6#p1094092
These users thanked the author untakenname for the post:
Dr. FrankenRex (Tue Jun 13, 2017 1:56 pm)
Harrymonk
Has thanked: 14 times
Post by Harrymonk » Fri Jun 16, 2017 10:41 am
I know this sort of thing is marmite, but after trying films and fly-eye paper decided a light tint was in order as its the look I like, with upgraded bulbs there is sufficient light coming through.
Tint Applied:
Laquered, bit of orange peel:
Sanded and rubbing compound with some elbow grease:
Just enough of a tint for me:
Hoping the weather holds to get them on the car after making some upgraded foam/rubber seals..
Has thanked: 111 times
Been thanked: 299 times
Post by PaulAV » Fri Jun 16, 2017 12:15 pm
Swapped out APV motor, had constant cel error code 2008, was a bit of a pain to swap, but now have intermittent cel 2008, so I have an improvement but not as good as I would of wished for, apv itself turned without issue and magnet was at the 1 o'clock position, so think there may be a damaged pin or something or the magnet is going weak.
wgimenes
Has thanked: 118 times
Been thanked: 82 times
Post by wgimenes » Fri Jun 16, 2017 12:28 pm
Created a new mod: sun visor extensions
thomo8568
Post by thomo8568 » Fri Jun 16, 2017 10:41 pm
Gave it a wash and test fitted my oil cooler grills.
I've already covered the oil coolers with mesh but didn't like that they didn't match. So cut up an old center grill. Not bad for a first attempt.
Ian, 40th anniversary in metropolitan gray mica
Previous cars
94 Toyota supra mkiv 1jzgte 350+Bhp
02 Impreza WRX bug eye 320bhp
94 Toyota mr2 G Limited
98 escort GTI
00 Yamaha R6
Has thanked: 5438 times
Been thanked: 2476 times
Post by ChrisHolmes » Fri Jun 16, 2017 10:52 pm
wgimenes wrote:Created a new mod: sun visor extensions
Wow! That is incredible. Wozza will be quaking in his boots if he sees this!
Are you taking orders?
These users thanked the author ChrisHolmes for the post (total 3):
wgimenes (Fri Jun 16, 2017 10:55 pm) • kopite72 (Sat Jun 17, 2017 5:49 pm) • Wozza (Sun Jun 18, 2017 9:49 am)
Street Ported 231
MazdaSpeed skirts
wgimenes
Post by wgimenes » Fri Jun 16, 2017 10:57 pm
LOL, Chris.
My first attempt.
The idea needs refining :-)
Brooksyvon89
Post by Brooksyvon89 » Fri Jun 16, 2017 11:16 pm
Did a full wash, decontamination, polish and resin coating:
brix79
Has thanked: 109 times
Been thanked: 366 times
Post by brix79 » Fri Jun 16, 2017 11:18 pm
Dayum, that looks like it's made of mirror! 8)
Need to get those shrouds back to black though. ;)
Chairman & Forum Admin Team
2017 // 2010 Aurora Blue R3
Potenza S001s | 20mm Eibachs | M1144s | Pettit Catback
2011-17 // 2005 Titanium Grey 231 | Gone, but never forgotten..
Post by PeteH » Fri Jun 16, 2017 11:26 pm
Brooksyvon89 wrote:Did a full wash, decontamination, polish and resin coating
It does look amazing.
(But, so does your drive! #Filter.... :ninja: )
Brooksyvon89
Post by Brooksyvon89 » Sat Jun 17, 2017 5:44 pm
I just happen to have a picture perfect front-of-the-house... Image
Busted lol
It is super clean though Image
Has thanked: 82 times
Been thanked: 106 times
Post by Scartlead » Sat Jun 17, 2017 7:41 pm
Brooksyvon89 wrote:Did a full wash, decontamination, polish and resin coating:IMG_0369.JPG
Looks really well, though do I sniff a little photoshop effetcs ? :-k
exiled--viking
Has thanked: 186 times
Been thanked: 341 times
Post by exiled--viking » Sat Jun 17, 2017 9:09 pm
This Is Only A Mock Up Of the Defuser Fitting......So Made the Mounting brackets today and did a trial Run Of the Rear Defuser still a long way to go but I think there going to be enough rear down force on the lower wings the defuser is not just for show and when completed will be finished of in a Carbon effect hydro Dip....
Also went with the double staggered wing as there is enough air flow for this modding the rear bumper was 4 X 3/4 slots need to be cut but hardly noticeable....!
Thank for taking the time to Look....!
[url=http://s32.photobucket.com/user/Tonyspi ... .jpeg.html
As you can see the Defuser is mostly under the rear bumper & not protruding or extending the length of the body ...Also there no need to have it under the exhausts as they have there own air scoops
mock up brackets made but some adjustments to be done, all the aluminium to be coated black nuts and bolts also need to be done in Orange .... this is only a Mock up the finished effect will look a little different .
Last edited by exiled--viking on Mon Jun 19, 2017 5:51 pm, edited 2 times in total.
These users thanked the author exiled--viking for the post (total 2):
ChrisHolmes (Sat Jun 17, 2017 9:47 pm) • Wozza (Sun Jun 18, 2017 9:49 am)
WAS THE WINNER OF THE 2015 EUROPEAN ROTOR STOCK BEST RX~8 in Show ( Won me 40 trophy"s the Beast is Now Sold A New Beast To Be Built SOON :banghead: ) new car MX5 Now Called the SHARK 8)
gareth_1912
Post by gareth_1912 » Sun Jun 18, 2017 4:56 pm
Not done anything today but ordered tein springs and drilled and grooved mtec discs and pads should be here Thursday :). Image.
Got a nice picture at castle Combe yesterday whilst I was at the rally school Image
Dove66
Has thanked: 32 times
Been thanked: 64 times
Post by Dove66 » Sun Jun 18, 2017 5:41 pm
thomo8568 wrote:Gave it a wash and test fitted my oil cooler grills.
I've already covered the oil coolers with mesh but didn't like that they didn't match. So cut up an old center grill. Not bad for a first attempt.20170616_202937.jpg
They look really good. I thought it looked like the centre grille before I read the text. I wonder if anyone else has done it that way.
Crystal White 40th Anniversary
001/400
Dove66
Post by Dove66 » Sun Jun 18, 2017 5:43 pm
Harrymonk wrote:I know this sort of thing is marmite, but after trying films and fly-eye paper decided a light tint was in order as its the look I like, with upgraded bulbs there is sufficient light coming through.
Tint Applied:
They look great. Mine are Covex covered but these look oem.
These users thanked the author Dove66 for the post:
Harrymonk (Mon Jun 19, 2017 9:30 am)
001/400
Reloy
Has thanked: 139 times
Been thanked: 219 times
Post by Reloy » Sun Jun 18, 2017 9:24 pm
Removed all the seagull crap from the roof, bonnet, boot, windows and both sides of the car. Never ever park your car overnight on Aberystwyth seafront. Great night though so it was worth it :-)
Sent from my VFD 600 using Tapatalk
These users thanked the author Reloy for the post:
wgimenes (Sun Jun 18, 2017 9:39 pm)
Rex II
Rhino Rack, Oil temp/pressure guages, Uprated Starter, Tein S-Tech Springs, 20mm Spacers, RRP MkIII Coils.
Rex I (gone but not forgotten)
Rotary Revs Rebuild, Oil Temp/Pressure Guages, Uprated Starter, K&N air filter, Eibach Pro Kit Springs, Bilstein B8 Shocks, RR D585 Coils, Magnecor Leads, Aero Kit
Salesy
Been thanked: 10 times
Post by Salesy » Sun Jun 18, 2017 9:38 pm
After 6 months in storage i decided it was due a deep clean ready for some summer use.
Full snow foam x 2, Meguires compound, Megs clear coat polish and finally a coat of carnauba wax. Silicone all black plastics and clean glass inside and out.
Sweating my nuts off for 4 hrs.
https://www.flickr.com/photos/134115384@N07/35350484906
https://www.flickr.com/photos/134115384@N07/35350483166
https://www.flickr.com/photos/134115384@N07/35223209692
Nintendologist
Colour: Phantom Blue
Has thanked: 64 times
Been thanked: 39 times
Post by Nintendologist » Mon Jun 19, 2017 7:21 am
Salesy wrote:After 6 months in storage i decided it was due a deep clean ready for some summer use.
Links don't seem to work?
Nov 2007 - May 2010: Galaxy Grey PZ (Parking sensors, Cruise control)
October 2015 - : Phantom Blue Evolve (D585 coils/Magnecor leads, Galtress 'Halo' LED headlights, resprayed alloys, hoop spoiler, Lockwood grilles all round, dropped numberplate, 13 Black ECU mini map, custom Nexus install, 20mm H&R spacers, Cobrasport cat back exhaust)
Has thanked: 265 times
Been thanked: 580 times
Post by Dr. FrankenRex » Mon Jun 19, 2017 9:04 am
Mmm... Brakings...
Harrymonk
Post by Harrymonk » Mon Jun 19, 2017 9:33 am
Thanks, I did try the covex style film but just couldn't get it to sit right...
They do look factory, which is what I was after, less chance of being stopped if it looks manufacturer, but also enough red is visible, we will see.
