ChrisHolmes wrote:Excellent news mate, happy to read this postYorkie194 wrote:Put my baby back on the road for the first time since October. Was going to sell but can't bring myself to do it.
- Has thanked: 266 times
- Been thanked: 320 times
- Been thanked: 220 times
brix79 wrote:Good stuff Neil, why the hell not! It does match well, it has to be said (again..)!
Yorkie, great example of an S1 lookin' the absolute canine undercarriage. And those wheels, schaweeeeet.
Yea thanks for the kind words
Bought the car just to thrash around the track as my z3 just wasn't cutting it.
Turned out to be a good buy after fixing a loom fault. Engine seems strong no dreaded hot/cold start issuestested it out at Pembrey end of last summer, drove faultless.
So over the winter gave it some upgrades
Changed the suspension to R3 shocks and arb's with H&R rear springs
Overhauled the brakes
Polly bushed the rear
Four wheel alignment to a modified setting
Decated stock cat and fitted Toyo system
Refurbished the alloys and new tyres
Acquired spare wheels and fitted slicks
Fitted D585's NKG plugs and magnecor leads
And fitted the controversial rear spoiler
Fabricated floor brackets
Fitted seats and harnesses
And not forgetting the bling
As well as helping mr spiller with his little project, a busy couple of months.
Harnesses feel ok they are fixed into the rear seatbelt anchors so very secure.ChrisHolmes wrote:Aren't those harness shoulder straps at to steep an angle?
Trying to get a rear role cage so they'll be mounted to that hopefully
You're OK with the angle. It's on the limit, and not recommended for use with HANS devices, but is OK for no HANS. I passed scrutineering all last year using the rear seat belt points.Neilparry wrote:Harnesses feel ok they are fixed into the rear seatbelt anchors so very secure.ChrisHolmes wrote:Aren't those harness shoulder straps at to steep an angle?
PeteH wrote:You're OK with the angle. It's on the limit, and not recommended for use with HANS devices, but is OK for no HANS. I passed scrutineering all last year using the rear seat belt points.Neilparry wrote:Harnesses feel ok they are fixed into the rear seatbelt anchors so very secure.ChrisHolmes wrote:Aren't those harness shoulder straps at to steep an angle?
Cheers Pete, only doing Trackdays and spent all my pocket money on the car so nothing left for "armour" lol.
- Has thanked: 2567 times
Neilparry wrote:PeteH wrote:You're OK with the angle. It's on the limit, and not recommended for use with HANS devices, but is OK for no HANS. I passed scrutineering all last year using the rear seat belt points.Neilparry wrote:
Apologies if I caused you some stress Neil, thanks Pete for confirming the situation.
That's ok Chris. I did read up on the HANS information so no cause for concern!!
- Been thanked: 3 times
So... it turns out I have now become 16 again. A few lighting gaps to fill but all done with power rails in parallel... not bad for a cripple
- These users thanked the author Brooksyvon89 for the post:
- Azimuth (Sun May 28, 2017 4:53 pm)
Finally changed the air filter, coil packs, leads and plugs. I planned to do it a month ago and wish I had, the entire air system was caked in oil... thanks previous owner.
On the plus side, cleaning everything fixed my hotstart issue, seems it was a combination of choking on oil and ancient plugs and coils.
- Has thanked: 57 times
- Been thanked: 31 times
MoT passed with the fitment of 4 tyres (Nanking AS 2+) and a quick oil and filter change. Thank you LC Rotary, a good day
Sent from my SM-T550 using Tapatalk
NGK Iridium plugs
D585 coils
Magnecor leads
LC Rotary mini-map
Millers 10w/40 semi-synthetic oil
Millers NT Transmission Oil in Gearbox and Diff
Pre-mixing with Protek R
Sebring cat-back exhaust
H&R lowering springs (dropped 45mm)
Front number-plate relocated
De-badged front
Chrome SS Strakes (needing refurb)
D585 coils
Magnecor leads
LC Rotary mini-map
De-badged front
- RX-8: Import
- Been thanked: 21 times
I've got experience successfully surviving driving into a wall on track with my harness mounted like that :-PNeilparry wrote:Harnesses feel ok they are fixed into the rear seatbelt anchors so very secure.ChrisHolmes wrote:Aren't those harness shoulder straps at to steep an angle?
Sent from my iPhone using Tapatalk Pro
RX-8 (2011/PearlWhite) RE Amemiya Redom AType2.0 ECU+Super Intake Box+SportsCat,RMagic TunedMuffler TitanCut,5.125 Final,Tein MonoSport w/EDFC,WedsSport SA55mMGM 18x9.0J,Neova AD08R 245/40/R18,Dixcel SD+IDI GT2 brakes,AutoExe MemberBraceSet, Bride GIAS Carbon,HPI 4pt,MOMO,TRUST InfoTouch+LEG83005,YupiteruGWR53sd,Carrozzeria http://www.rx8ownersclub.co.uk/forum/vi ... 04&t=55428
That's reassuringtmk wrote:I've got experience successfully surviving driving into a wall on track with my harness mounted like that :-PNeilparry wrote:Harnesses feel ok they are fixed into the rear seatbelt anchors so very secure.ChrisHolmes wrote:Aren't those harness shoulder straps at to steep an angle?
@tmk Maybe you should change your forum name to クラッシュテストダミーtmk wrote:I've got experience successfully surviving driving into a wall on track with my harness mounted like that :-PNeilparry wrote:Harnesses feel ok they are fixed into the rear seatbelt anchors so very secure.ChrisHolmes wrote:Aren't those harness shoulder straps at to steep an angle?
Nothing wrong with Lights underneath an RX-8Brooksyvon89 wrote:So... it turns out I have now become 16 again.
- Has thanked: 84 times
- Been thanked: 20 times
The lights shining through the side vents are pretty damn sexy!Brooksyvon89 wrote:So... it turns out I have now become 16 again.
I painted my exhaust shrouds today. You'll see from my Avatar pic that they had gone very pale and grey. A little bit of reading found DanBass's Rustoleum recommendation, so I gave that a try.
30 mins prep and about 15 seconds spraying and they look great! Really pleased how they turned out. Good shout Dan!!
Of course that now means I need to spray every other exterior black surface. Even the black bits on my wing mirrors are looking pretty grey! I'll probably draw the line at my tyres.... joke, just in case anyone wants to tell me why that would be a bad idea.
- Has thanked: 71 times
- Been thanked: 90 times
Trekked across London to see an Evolve that's listed on ebay only to find out there's rust on the arches, really annoying as it was a rare one in the lower tax bracket
BigPete may still have an Evolve
- Has thanked: 9 times
- Been thanked: 7 times
Now that is cool does make me feel like a teenager again. May have to pop over and see it at some pointBrooksyvon89 wrote:So... it turns out I have now become 16 again. A few lighting gaps to fill but all done with power rails in parallel... not bad for a cripple
If its not broke I'm sure I can find a reason to take it apart
Things Done: Nexus Mod, Led Lights, D969 Coils, cobra exhaust, moded ash tray to gauge pod, Toyo Decat, cruise control mod with mazda 6 steering wheel and Lots of Cleaning
To Do: ?
Want:Ms kit
To Do: ?
Want:Ms kit
Absolutely! I'm home all day during the day as I can't drive until (hopefully) next month so let me know when your around.joney wrote:Now that is cool does make me feel like a teenager again. May have to pop over and see it at some pointBrooksyvon89 wrote:So... it turns out I have now become 16 again. A few lighting gaps to fill but all done with power rails in parallel... not bad for a cripple
- Founder Member
- Has thanked: 12 times
Car was fine last Sunday for the meet at Mazda HQ on Friday went to collect the car to go to the Essex meet only to find I had no power steering and an OBD reader borrowed from Shane at Sun Motors, adjacent to my garage, revealed a DTC B2278 'Steering Torque sensor malfunction which would not clear. A call to Aston at Essex Rotary and he provided me with not one, but two power steering modules, to possibly sort the problem, which I picked up at the Essex meet. So today was spent removing the ECU to access the steering module and replacing mine with each of the borrowed moules to see if this removed the problem. No joy with either of these, so replaced my original and set about removing the battery tray and air box and tray to gain access to the connectors at the torque sensor and the wiring loom. A circuit test gave a 13ohm reading which is within the 12-15ohm spec so all seemed to be in order and pointed to the torque sensor itself. Sprayed the connectors and reseated them and put everything back and prepared to park the car up until I could speak again to Aston to try and find a resolve. Lo and behold power steering back again, which is all good but does not reveal why it happened in the first place . Hey Ho RX8 foible strikes again. A vote of thanks to Aston again for being at the end of the phone over a weekend to offer help and advice.
- These users thanked the author Harrizone for the post:
- ChrisHolmes (Sun May 28, 2017 11:21 pm)
Now a distant memory unfortunately.
Could that connector have been splashed with acid when the battery cracked?
- RX-8: Import
Haha.. that's a thoughtwarpc0il wrote:@tmk Maybe you should change your forum name to クラッシュテストダミーtmk wrote:I've got experience successfully surviving driving into a wall on track with my harness mounted like that :-PNeilparry wrote:
- Founder Member
That was my initial thinking, but there was no evidence of that with the upper connectors, which are above and behind the level of the spilt acid, and the connector at the torque sensor and the sensor itself appeared to have missed any of the fan blown acid and were quite clean. Aston has had similar instances where after dismantling the connectors etc. this same fault has magically rectified itself.warpc0il wrote:Could that connector have been splashed with acid when the battery cracked?
Another quirk of the RX8, it's self healing.
Sorry to hijack the conversation but very rarely my steering will appear heavier when turning right for a while and then return to normal... similar issue?
- Founder Member
Yours is a known problem with the 8 in as much that the UJ gets caked in grot, remedy is to clean off with solvent and lubricate with chain oil or similar.
