300 Mile Club (S1 RX8s) or 325 mile club for S2 RX8s
Vian
Has thanked: 27 times
Been thanked: 52 times
Re: 300 Mile Club (S1 RX8s) or 325 mile club for S2 RX8s
Post by Vian »
I've effectively done it - refilling (no choice, was on the M25) when the light had just come on at 328, but that's the closest.
Has thanked: 2572 times
Been thanked: 940 times
Post by ChrisHolmes »
Vian wrote:
Mon Oct 15, 2018 7:19 pm
Has thanked: 186 times
Been thanked: 548 times
Post by Dr. FrankenRex »
The Ginga NinjRx8 wrote:
Mon Oct 15, 2018 4:20 pm
Is this a record miles then?
You're certainly close, but there is a chap who owns an S1 and has crept over 400 miles!
I've hit over 400 in my R3, but that has an extra 1 gallon in the tank.
Interestingly, since the rebuild (with mental porting etc.) I still managed to hit 165 out of half a tank, and that was cruising at about 80 on the motorway. I reckon, as it stands, I could clear 350 to a tank on a run, even running a full bridgeport with race extension...
Mpv2k3
Has thanked: 52 times
Been thanked: 31 times
Post by Mpv2k3 »
I still don't get how you managed 400 or even 350 in the R3
A solid ignition system and cruise control. 60mph on a motorway without the AC on. Any RX8 will do it :thumleft:
nightfire10 (Thu Nov 01, 2018 1:16 pm)
nightfire10
Has thanked: 742 times
Been thanked: 284 times
Post by nightfire10 »
Dr. FrankenRex wrote:A solid ignition system and cruise control. 60mph on a motorway without the AC on. Any RX8 will do it :thumleft:
Hmm that's the problem, I have a job to stay at 60 ImageImage
And that is why cruise control helps. I use it more than I thought I would, purely because it prevents my speed from creeping up! :lol:
Mpv2k3
Post by Mpv2k3 »
I'll try and find 60 then. Any specific gear?
Ainmhidh
Has thanked: 233 times
Been thanked: 146 times
Post by Ainmhidh »
For 60mph, probably 6th unless you're facing some significant uphills, in which case 5th might be better for those bits.
6th all the way (in a stock RX8 anyway). You won't need to use 5th on any motorway in Britain, none of the hills are steep enough to trouble an 8 at 3,500 rpm.
Not going to lie, it's boring as sin warbling along at 60, but still. That's 6 hours and 40 minutes of driving, for reference.
Goobie
Has thanked: 12 times
Been thanked: 104 times
Post by Goobie »
So 155 from a full tank bad then? Maybe I should try the other 4, 5 and 6th gears...
These users thanked the author Goobie for the post:
nightfire10 (Thu Nov 01, 2018 5:14 pm)
Not "bad". Unless you're crusing in 6th at 60 and getting that... ! :lol:
#CheckYourCoils
Thu Nov 01, 2018 4:31 pm
I do hope your not motorway cruising at 60mph to run the engine in. Worst thing in the world constant light load, you need A or B roads with regular gear changing and variable throttle loading on the engine to ensure correct bedding in.
I think you know better though so not sure why I am posting this!
v-rex (Fri May 31, 2019 1:26 pm)
Course I know better, silly billy
ChrisHolmes (Fri Nov 02, 2018 5:59 pm)
Kamys
RX-8: Kuro
Been thanked: 8 times
Post by Kamys »
275 miles is the best I got so far. I must admit that I did step on it quite a few times, as its so boring I could fall asleep. I'm not sure i'll pursue this anymore, as when I stopped the idle didn't sound very healthy. 2-3 redlines later everything got back to normal.
nightfire10
Must try harder LOL
ChrisHolmes (Fri Jan 11, 2019 10:03 am)
So, just a quick one - can anyone remember the name of the chap who did 400 miles on a tank in an S1?
I know I'm not the only 400 mile nutter on here, but can't for the life of me remember the other chap.
zippyonline
Has thanked: 30 times
Been thanked: 27 times
Post by zippyonline »
Fri Jan 25, 2019 3:11 pm
Cabbie
These users thanked the author zippyonline for the post:
Dr. FrankenRex (Fri Jan 25, 2019 8:43 pm)
bigpete8
Has thanked: 150 times
Been thanked: 162 times
Post by bigpete8 »
nightfire10 wrote:
Fri Jan 11, 2019 9:42 am
Must try harder LOL
That's all to familiar .. 😁
nightfire10
bigpete8 wrote:
Must try harder LOL
That's all to familiar .. Image
Hey I did 175 on last tank , I'd be the first to admit I don't hang around and beep at least every 10 mins Image
Has thanked: 442 times
Been thanked: 2089 times
I did 425 miles on a tankful in my S1 on the way back from Blyton Park a few years ago, if my dash display is to be believed :shock:
Or maybe I just forgot to reset the trip at the previous top-up #-o
nightfire10 (Fri Jan 25, 2019 6:57 pm) • ChrisHolmes (Sat Feb 09, 2019 7:14 pm)
Colour: Nordic Green
Has thanked: 100 times
Been thanked: 550 times
Post by qwakers »
meh cruising at 50 (average speed zones) on the motorway my renault laguna will average 67mpg :)
but at 80... 45mpg 8)
sorry. y’all. an get back on topic now :mrgreen:
SteveTroman
Post by SteveTroman »
I never got over 250 until my rebuild, then I got 297 before I chickened out and filled up. But have not managed a good run of over 60 miles at a time yet.
delta0
Has thanked: 66 times
Been thanked: 45 times
Post by delta0 »
Looks like Felix from Living with a Rotary is in a club of its own. Over 400 miles in an S1! :shock:
RX8 R3 Aurora Blue Mica
Nickp47
Has thanked: 176 times
Been thanked: 324 times
Post by Nickp47 »
Fair play to him, wonder what 42psi tyres do to the handling!?
