SOS immobiliser won't let me start the car - RESOLVED
- Has thanked: 40 times
- Been thanked: 13 times
Hi Folks,
Drive to a meeting in Southampton a d parked in a multi story. Came back after the meeting and the car won't start due to the immobiliser. (blinking key thingy)
Battery has plenty of power and this is my daily driver. Any thought please?
Sent from my LYA-L09 using Tapatalk
56 Plate PZ in Galaxy Grey!!
- Events Team Member
- Has thanked: 507 times
- Been thanked: 451 times
Re: SOS immobiliser won't let me start the car!
Have you installed D585 coils from BHR?
I say this as I had this symptom, the cause being the wiring loom to the coils have chafed through where it passed the engine hoist bracket, causing a short to ground, which blew the 15A engine fuse in the main fusebox. I'm not the only one this has happened to, so it wasn't a one-off.
New coils and leads put in a couple of years ago. Nothing since
I checked the engine fuse and it looks OK.
I have full power to the dash etc, I just can't start it.
In a taxi now heading to mazda for new battery for the key. Not sure what to do if that doesn't work..
- Has thanked: 97 times
- Been thanked: 539 times
that wont work most likely, the battery only does the lock functions, the immobiliser is passive, proven by my car having no key with just the immobiliser chip taped to the receiver.
it has been know that local interference can stop a immobiliser reading the key, moving the car a few yards will sometimes sort it, other than that i cant be much help im afraid.
Will it bump start?
Now at mazda. Spare key won't start it. Same issue.
- Has thanked: 89 times
- Been thanked: 172 times
Just did a quick google:
Turn the key on. Disconnect the battery. Hold your foot on the brake pedal for 1 min. With the key still on, reconnect the battery and start the vehicle.
Worth a shot
Worth a shot
You can call me Madam Secretary
Thanks. I'll see what mazda has to say. I'll let them know your trick..
I suspect that "trick" was on a US forum, as their cars have a totally different security system.
One way to screw up the immobiliser on ours is to have a loose battery connection when the key is On, which is what that "trick" would emulate. It can also damage the PCM...
Hopefully Mazda know better.
No idea - was the only reset method I could see
Maybe ignore that as Dave suggests
- Club Discount Manager
- Has thanked: 67 times
- Been thanked: 70 times
Probably worth giving the engine bay fuse box a good check before going too far down any rabbit holes.
RX-8 PZ: viewtopic.php?f=104&t=85661
RX-8 40th: (Charlotte's)
Daily: BMW 330D
RX-8 Evolve (Banger Rally project) gone : viewtopic.php?f=104&t=86460
Old daily (Alfa MiTo - gone too ): viewtopic.php?f=36&t=85722
Daily: BMW 330D
The last time someone reported an "immobiliser issue" the cat had be stolen and the O2 sensor wire was left shorted to the underside...
- Has thanked: 174 times
- Been thanked: 323 times
The only time I have had the above issue it was a fuse at fault so definitely a good place to start, unfortunately I don’t recall which one was responsible.
- These users thanked the author Nickp47 for the post:
- rx8hunter (Tue May 24, 2022 5:50 pm)
- Forum Trader
Hi Folks.
Car was recovered to Mazda Soton.
It was showing an issue with the chip reader / ignition switch. That wasn't the culprit.
It was the 15a engine fuse in the end. Tbf, I looked at it from the top and side but my fuse puller ended up in the road in frustration. Absolute sh*t.
I normally don't carry tools but I've added a few bits including needle-nose pliers. They gave me a couple of spare fuses just in case.
Can someone change the thread title to resolved please?
Thanks for all the input. Much appreciated as always.
Re: SOS immobiliser won't let me start the car - RESOLVED
Ha, so I was right about the 15A engine fuse then! I would thoroughly check for see why the fuse blew.
When my 15A engine fuse blew, it was in the overtaking lane on the M3. I suddenly lost all power as the ignition was cut. I had to coast over 2 lanes of traffic to the hard shoulder - very, very scary and it could have resulted in a serious incident!
My D585 coils had been installed (by me ) about 3 years previously with no trouble, but the chafing took that long to work it's way through the loom tape and cable insulation. Yours could have done the same after two years. If it is this issue, it just needs some engine vibration to cause the short and fuse to blow again. You don't want to be doing 70mph in the overtaking lane when that happens
The BHR D585 has very thin tape insulation on the loom, unlike other kit suppliers (such as Rotary Revs) where the loom protection is much more substantial.
Have a look where the cable loom passes the engine hoist bracket, as this can have a sharp edge and may be in contact with the loom.
Here's a pic of my loom, showing the exposed copper wire...
with the loom tape removed....
- These users thanked the author casey for the post (total 2):
- HarSc (Tue May 24, 2022 6:56 pm) • Ninja_Freak (Tue May 24, 2022 6:59 pm)
Thank you sir! I'll have a look tomorrow. The pictures are a helpful addition.
Thanks for editing the name of the thread.
- Has thanked: 741 times
- Been thanked: 282 times
Mine chaffed against the engine hoist loop on the front
Sent from my SM-G991B using Tapatalk
Well that's one more thing to add to my paranoia list
Although my coil set up isn't the standard 4 in a row so hopefully will be OK but will be under the bonnet to check anyway
- These users thanked the author Cscameron for the post:
- casey (Tue May 24, 2022 8:06 pm)
- Has thanked: 301 times
- Been thanked: 253 times
For future reference you can edit the thread title yourself
Just click on the pencil icon ✏ , on your first post, & edit it till your heart's content
If I'm giving you IT advice then you have serious problems
BTW glad the car is fixed
- These users thanked the author MARKTHOMASBRAND for the post:
- warpc0il (Tue May 24, 2022 10:00 pm)
Thanks.. I was on Tapatalk at the time and couldn't figure it out! (cheeky git.. )
- These users thanked the author Ninja_Freak for the post:
- MARKTHOMASBRAND (Wed May 25, 2022 11:15 am)
- Has thanked: 10 times
- Been thanked: 57 times
i blew the engine fuse at JDM combe in 2019, rear O2 sensor wiring contacted the exhaust, melted and shorted blowing the fuse as i was on my way up avon rise...
Thanks, Stu
Mad as anything
Mad as anything
i still have that loop of wire to short the fuel pump relay in the coin tray.
when i was last under the car the harness has been clipped into place this time.
Thanks, Stu
Mad as anything
Mad as anything
