rotatopotato
Has thanked: 70 times
Been thanked: 25 times
Post by rotatopotato » Tue Sep 15, 2020 10:43 am
Must be a design feature to counter the quiet (when stock!) smoothness of the rotary engine 😁
Has thanked: 127 times
Been thanked: 117 times
Post by bigpete8 » Tue Sep 15, 2020 12:59 pm
Took her for a lunch time blast. :)
need to burn some juice so can put pre MOT cataclean through.
(It is handy being next to the Motorway!)
rotatopotato
Post by rotatopotato » Tue Sep 15, 2020 1:29 pm
I also did the on-ramp GP during my lunch break, after taking it for a quote on the remaining rust in the arches - going to need both sides done completely (so that'll take care of other dings etc as well) as the guy knew all about how impossible velocity red is to blend (he has an MX-5 in the same colour). We had a good chat about Mazda's, rotaries, and rust :D
I'm looking at ~£1600 to get both sides done, which includes patching what will be a decent hole in at least one arch. I'll probably get the bumpers done too since they've got their share of chips & scrapes. But that will have to wait until spring, when I've recovered from the amount of money I've already spent on it. It might put off getting it bridgeported, which I was hoping to do in the first half of next year, but it's better to make sure it isn't going to turn to dust first!
craigy85
Has thanked: 51 times
Been thanked: 15 times
Post by craigy85 » Tue Sep 15, 2020 10:40 pm
Had her cleaned... in the past 2 weeks she's had new coils, leads, plugs and all filters, belts and fluids changed, so thought it was time to give the bodywork some love...
These users thanked the author craigy85 for the post (total 2):
GreySilver Beast (Wed Sep 16, 2020 2:55 am) • CLOVERLEAF159 (Fri Sep 18, 2020 8:26 pm)
2008 Sparkling Black R3 with RRP Mk3 Coils & MSD 8.5mm leads
Previously - 2005 Nordic Green 231 with Axxess Ipod kit, Integrated Bluetooth Handsfree Kit, SS Strakes, SS Lockwood Grilles
Post by bigpete8 » Wed Sep 16, 2020 2:34 pm
More lunch time fun with the cataclean in this time.
Pippypip
Post by Pippypip » Wed Sep 16, 2020 2:45 pm
Picked up a new engine and transmission today and managed to fit it the Rx8 Image
Has thanked: 99 times
Been thanked: 269 times
Post by PaulAV » Wed Sep 16, 2020 3:03 pm
You may have trouble accelerating with the engine and transmission installed like that
Bigblueknight3k (Wed Sep 16, 2020 6:18 pm)
rotatopotato
Post by rotatopotato » Wed Sep 16, 2020 3:04 pm
1 forwards, 6 reverse 👍
Has thanked: 25 times
Been thanked: 320 times
Post by Yorindesarin » Wed Sep 16, 2020 3:07 pm
What's the compression like on that one?
Pippypip
Post by Pippypip » Wed Sep 16, 2020 3:14 pm
Yorindesarin wrote:What's the compression like on that one?
I honestly have no idea, but it’s been rebuilt be rotary revs about 2000 miles ago with the receipt/documents.
I bought it as I got a good deal on it so I thought it’s worth the risk seeing that my engine start up is getting worse every week.
Post by Yorindesarin » Wed Sep 16, 2020 3:35 pm
Ooft not bad then. Any port work? Will be good to see what it's doing once you have it in.
Pippypip
Post by Pippypip » Wed Sep 16, 2020 3:36 pm
Yorindesarin wrote:Ooft not bad then. Any port work? Will be good to see what it's doing once you have it in.
Unfortunately not as the lad I got it from said that he wanted something “reliable”.... Which is a shame to be honest
Post by Yorindesarin » Wed Sep 16, 2020 3:47 pm
But a street ports as reliable as no port. Dang!
Been thanked: 618 times
Post by New Duke » Wed Sep 16, 2020 4:08 pm
Tried to fit a silicone reducer intake hose to fill the void between the revi scoop and the stock air box. (haven't been able to find anything else suitable to couple the gap, including items from the relevant threads)
I'd measured it wrong. It's not snug so could shift. So back to searching... or rethink the whole thing. Half tempted to SORN it.
Also managed to break the underside of the airbox pulling it out of the tray. Too heavy handed when I thought the feet had released. So all in a bit of a fail.
rotatopotato
Post by rotatopotato » Fri Sep 18, 2020 8:56 am
While pouring over the car looking for broken bits that need replacing (our bigpete is a legend btw :thumleft:), I discovered an unplugged connector by the expansion bottle.
If already come across mention of the dodgy level sensor, so it was not a shock at all to find the image of the parthenon light up.
Vj4sothername (Fri Sep 18, 2020 9:25 am)
delta0
Has thanked: 76 times
Been thanked: 38 times
Post by delta0 » Fri Sep 18, 2020 9:25 am
I think it needs to be renamed to the Parthenon light! :D
These users thanked the author delta0 for the post (total 2):
Vj4sothername (Fri Sep 18, 2020 9:26 am) • rotatopotato (Fri Sep 18, 2020 9:38 am)
RX8 R3 Aurora Blue Mica
BHR coils+MSD leads, Stage 1 ecu tune, HKS Hybrid oil filter, Idemitsu 10w30, BHR engine mounts, Racing Beat oil cooler lines, Essex Rotary undertray, Racing Beat Revi Intake+Ram Air, Milltek/Pettit cat+catback and Continental SportContact 6
About to add; SuperPro bushes, Racing Beat flywheel, Exedy stage 1 clutch, Pettit Ti flywheel nut, Lockwood grills
Reloy
Has thanked: 139 times
Been thanked: 217 times
Post by Reloy » Fri Sep 18, 2020 12:38 pm
Replaced my gear lever, luckily I have a spare gearbox out in the garden (as you do).
I was driving down the motorway yesterday, attempted to shift to sixth, and got a very horrible crunchy sounding attempt at reverse :shock: It would appear that my gear lever was stuck in the press down mode. At first I assumed that the return spring was broken, but no, it's the big plastic sleeve/collar, it no longer grips the main ball firmly enough for the collar to operate the spring.
These users thanked the author Reloy for the post:
rotatopotato (Fri Sep 18, 2020 12:44 pm)
Rex II
Rhino Rack
Rex I (gone but not forgotten)
Rotary Revs Rebuild, Oil Temp/Pressure Guages, Uprated Starter, K&N air filter, Eibach Pro Kit Springs, Bilstein B8 Shocks, RR D585 Coils, Magnecor Leads, Aero Kit
Has thanked: 180 times
Been thanked: 392 times
Post by V8 Power » Fri Sep 18, 2020 12:45 pm
I’ve got a spare one if you want it.
£20 posted?
Direct cold air feed
RRP Coils MSD leads
Reloy
Post by Reloy » Fri Sep 18, 2020 12:52 pm
£20 posted?
Thanks for the offer, the spare gearbox is from my first Rex that had serious issues with 1st, 2nd, and 3rd, I doubt I'll be using it for anything more than a garden ornament ;)
V8 Power (Fri Sep 18, 2020 12:54 pm)
Rex II
Rhino Rack
rotatopotato
Post by rotatopotato » Fri Sep 18, 2020 2:51 pm
Had it in getting a second hand AC compressor fitted, turns out it's leaking in the exact same way as the original (came off a similar mileage car, so must be a common failure time). So it's looking like the best option will be to fit a brand new compressor at about ten times the cost :(
That can wait until the new year.
Post by V8 Power » Fri Sep 18, 2020 3:04 pm
Give Bigpete a go at supplying a compressor.
I had one off him and it has been faultless.
rotatopotato (Fri Sep 18, 2020 3:13 pm)
RRP Coils MSD leads
rotatopotato
Post by rotatopotato » Fri Sep 18, 2020 3:13 pm
This is the second time it's been in, tbh at this point I think I'd rather take the hit on a brand new one and know its going to work, especially as the labour costs of fitting/gassing are starting to add up. At least with new parts it's done and dusted.
Post by Yorindesarin » Fri Sep 18, 2020 3:58 pm
Finally installing my struts.. Minor accident occurred..
Whelp.. Ima just.. Be over here.. Removing my upper intake manifold. 😂
Angle grinders going to be coming out to carefully split the nut off so I can hopefully unscrew the bolt thread..
Has thanked: 1047 times
Been thanked: 481 times
Post by nightfire10 » Fri Sep 18, 2020 4:11 pm
Mot time!
Passed but the left exhaust failed but right was fine, he recons it drawing air somehow. Image
These users thanked the author nightfire10 for the post (total 2):
CLOVERLEAF159 (Fri Sep 18, 2020 8:30 pm) • ChrisHolmes (Sat Sep 19, 2020 5:36 pm)
Post by Yorindesarin » Fri Sep 18, 2020 8:05 pm
Managed to sort the rivnut issue thankfully with the help of my angle grinder... Its probably my favourite tool purchase so far... Something doesnt budge? CUT IT! Heh. See my project thread for some top quality pictures I swear.
Struts installed. Upper intake manifold almost removed. Should get the electric connectors off the back of the solenoids tomorrow... Going to clean up the top of the manifold because its all oily... And possibly remove more insulation around the bay. May also go find out the price of replacing the underhood insulation too..
Vj4sothername (Fri Sep 18, 2020 8:53 pm)
