Overheated RX8
nox
Overheated RX8
Post by nox » Wed Sep 16, 2020 1:30 am
Hi folks. Sadly my RX8 overheated on the M4 on Sunday and had to be towed back home. RAC man diagnosed it as blown head gasket
Anyway what does overheating do to the renesis? I’m thinking of putting the car out for anyone who needs parts/new project/etc as last resort. I did have to drive it for about 2 miles to park and wait at a service (advised by RAC) and the didn’t sound bad.. but unless looked at deeper, won’t know obviously...
8 years of joy but sadly has to go looks like.. Mine is a 231 Titanium Grey. Mostly stock. Apart from d585’s and custom exhaust from Carl Hayward. Engine rebuilt 2017 by Chris at Apex Rotary.
Cheerz!
What's the difference between a mosquito and a blonde?
Nickp47
Has thanked: 110 times
Been thanked: 205 times
Re: Overheated RX8
Post by Nickp47 » Wed Sep 16, 2020 6:03 am
I had one overheat a few years back, it destroyed the coolant seal which meant a rebuild was required.
Nerdstrike
Been thanked: 31 times
Re: Overheated RX8
Post by Nerdstrike » Wed Sep 16, 2020 8:50 am
Mine boiled up years ago after the fan seized. It survived and ran fine for years until I sold it. It may be ok, depending on the nature of the failure. If yours overheated in slow traffic you might have a chance. I can see how an overheat under power would suggest a much more dramatic event.
Been thanked: 618 times
Re: Overheated RX8
Post by New Duke » Wed Sep 16, 2020 8:56 am
Normally if it overheats the PCM should cut the throttle to protect the engine. I've done that a couple of times. But then it should be fine once cooled a bit. If Mr RAC couldn't restart it then maybe it had failed to cut the throttle in time.
Yeah overheating can cause anything from absolutely nothing to a rebuild. If it sounds fine, drives fine and has no leaks then it's probably fine.
nox
Re: Overheated RX8
Post by nox » Wed Sep 16, 2020 9:54 am
He actually restarted it and it sounded fine. There was a slight whining noise. He added coolant and then used a device that looked like a test tube with blue fluid in it. I believe this is to test for gas leakages in the coolant? That’s where he said head gasket is gone. But the 8 doesnt have one right?
Has thanked: 448 times
Been thanked: 1760 times
Re: Overheated RX8
Post by warpc0il » Wed Sep 16, 2020 10:20 am
If there's exhaust gases in the coolant - which is what his tester was looking for - then it's going to be a water jacket seal failure. That was mean a strip and rebuild.
OTOH it could appear to overheat, blowing coolant and steam all over the engine bay, just from have a loose or damaged cap on the header tank.
You need to get it checked by someone who understands rotary.
Is Luke around?
Has thanked: 1047 times
Been thanked: 481 times
Re: Overheated RX8
Post by nightfire10 » Wed Sep 16, 2020 10:23 am
The coolant seals are our head gasket as such, dave should be along with his knowledge to confirm that if exhaust gasses are found in the coolant its rebuild time unfortunately
That was quick
Re: Overheated RX8
Post by New Duke » Wed Sep 16, 2020 10:31 am
EDITED - Set straight by Nick :salut:
13Black (Wed Sep 16, 2020 2:23 pm)
Has thanked: 521 times
Been thanked: 801 times
Re: Overheated RX8
Post by 13Black » Wed Sep 16, 2020 11:53 am
To be honest I doubt it needs a rotary specialist - they'd be no more clued up than a regular mechanic when it comes to checking for exhaust gasses in the coolant - they'll use the same tool and there's no user input / deciphering required. If you can read a pregnancy test, you can tell if a water seal has gone.
If you saw him do the test and the blue fluid turned yellow, it needs a rebuild.
Has thanked: 127 times
Been thanked: 117 times
Re: Overheated RX8
Post by bigpete8 » Wed Sep 16, 2020 1:22 pm
Buy one of these and test it yourself...
Re: Overheated RX8
Post by 13Black » Wed Sep 16, 2020 2:25 pm
I should hope that we can trust the RAC to do a simple test - for half the price you could stick some K-Seal in it and possibly get some more miles out of it (though not without the usual caveats).
stewartm
Forum Administrator
Forum Administrator
Has thanked: 33 times
Been thanked: 223 times
Re: Overheated RX8
Post by stewartm » Wed Sep 16, 2020 5:05 pm
Others might have a more informed opinion to say whether this is correct/worthwhile - but leaving the car to stand for a few days or so if you have the time and seeing if you have trouble starting it, might also reveal the likelyhood of a water jacket seal failure. My first 8 would easily overheat under load AND if left for a while would struggle to start - the theory being that under load escaping gas would cook the coolant and whilst stood, that coolant would seep back into the chambers.
nox
Re: Overheated RX8
Post by nox » Wed Sep 16, 2020 8:04 pm
Thank you everyone. Great ideas and thoughts. I will try and follow some of these in the week-end. Once again, thanks ever so much for taking the time to reply. =D>
