Bigblueknight3k
Has thanked: 116 times
Been thanked: 53 times
Post by Bigblueknight3k » Wed May 20, 2020 12:30 am
I have nothing to hide and will put my conversation on here if needed and i have not sleighed you on here as you clame at all i am a professional person and say what i feel and i was let down and you have not expained anything to me at all and you charge me money for testing even tho you have no rig yet as if you said to test on another rx8 i would have and done so and still having this problem plus not my fault the coils did not turn up today late in the day after 4.30 pm and refit them and then have them miss firing. After waiting a long time not been keeping me informed to what is going on and explained to me today and now done it on here as i said i was not able to call and you would not discuss to me in message i have not gone on google and left bad feed back or anything else and want to sort this out and resolve it in a good manner and in the way it should have been expand and updated from the start
Sent from my LM-Q630 using Tapatalk
Has thanked: 130 times
Been thanked: 285 times
Post by mrspiller » Wed May 20, 2020 8:40 am
ChrisHolmes wrote:Decided to see if it was possible to return a painted carbon bonnet to a clear coated carbon finish and the answer is....eventually!
Don’t go through the lacquer over the carbon and you’ll be fine
That’ll take some patience
These users thanked the author mrspiller for the post:
ChrisHolmes (Wed May 20, 2020 10:00 am)
untakenname
Has thanked: 80 times
Been thanked: 102 times
Post by untakenname » Wed May 20, 2020 10:29 am
Looks like there's quite a few distinct layers of paint so could use a rotary polisher with some fine grit discs to get through the first ones and just do the last couple of layers by hand to save time.
These users thanked the author untakenname for the post:
ChrisHolmes (Thu May 21, 2020 12:36 am)
Craig010
Has thanked: 28 times
Been thanked: 30 times
Post by Craig010 » Wed May 20, 2020 8:27 pm
A small job today, but had a rattle coming from my driver's side mirror, a quick tighten was all it needed. While I had the cover off, I noticed it's held directly against the metal door frame which is bound be be causing rattles when the music is up, so took the opportunity to minimise them. Fits much tighter now.
Before:
After:
Should really get the door card off and do the same behind there - It's gets a bit buzzy with some music on.
Has thanked: 770 times
Been thanked: 312 times
Post by nightfire10 » Thu May 21, 2020 8:51 pm
Had to go downstairs first time in 9 weeks and get tools out of the boot of the car (flat battery) as the bike alarm was going off due to! (flat battery) lol at least the car alarm wasn't going off! 🙄
Has thanked: 4647 times
Been thanked: 1959 times
Post by ChrisHolmes » Thu May 21, 2020 10:01 pm
Put another faultless 30 miles on the car
These users thanked the author ChrisHolmes for the post (total 2):
Vj4sothername (Thu May 21, 2020 10:02 pm) • mi60o0 (Thu May 21, 2020 10:04 pm)
Bridge Ported 231
MazdaSpeed sills
Short shifter
Brittishlion1
Has thanked: 10 times
Post by Brittishlion1 » Sun May 24, 2020 1:55 pm
Clay bar, T Cut and polished.
Blacked out tyres.
These users thanked the author Brittishlion1 for the post (total 2):
Vj4sothername (Sun May 24, 2020 3:23 pm) • v-rex (Sun May 24, 2020 5:28 pm)
Brittishlion1
Post by Brittishlion1 » Sun May 24, 2020 2:53 pm
Oh, and fitted a dash cam that don't work.
SAS
Been thanked: 59 times
Post by SAS » Sun May 24, 2020 4:15 pm
Finally managed to give her the first clean And drive this year. Also took some up to date photos as I realised I haven’t got any.
These users thanked the author SAS for the post (total 4):
GreySilver Beast (Sun May 24, 2020 4:20 pm) • v-rex (Sun May 24, 2020 5:28 pm) • casey (Sun May 24, 2020 8:33 pm) • Vj4sothername (Sun May 24, 2020 9:58 pm)
Supercharged :thumleft:
Has thanked: 86 times
Been thanked: 98 times
Post by Scartlead » Sun May 24, 2020 9:57 pm
Ordered some premix from Opie, usually use Idemitsu from Aston, but his shipping is too expenive now, went for Millers KR2T this time, seems to be good stuff, so why not.
https://www.opieoils.co.uk/p-115235-mil ... t-oil.aspx
Post by Scartlead » Sun May 24, 2020 9:59 pm
Love the bonnet especially :thumright: Lovely 8 :thumleft:
Vj4sothername
Has thanked: 641 times
Been thanked: 146 times
Post by Vj4sothername » Tue May 26, 2020 3:14 pm
Sorted this horrible sticky mess out.Image
S1 - 231 - brilliant black
Feb 08 built,
Fake Toyosport back box,
Dents,
Scratches,
Replacement engine,
Smiles
Post by nightfire10 » Tue May 26, 2020 3:22 pm
Wow did you get any air passing through these
Vj4sothername
Post by Vj4sothername » Tue May 26, 2020 3:24 pm
nightfire10 wrote:Wow did you get any air passing through these
Not really. The Aircon got so cold it clicked off today. First time ever! Well since it's worked, smells less too.
These users thanked the author Vj4sothername for the post:
nightfire10 (Tue May 26, 2020 3:27 pm)
Feb 08 built,
Dents,
Scratches,
Replacement engine,
Smiles
Rafael
Has thanked: 6 times
Been thanked: 16 times
Post by Rafael » Tue May 26, 2020 4:29 pm
New shiny parts from RRP fitted :lol:
Top quality =D>
These users thanked the author Rafael for the post (total 3):
Vj4sothername (Tue May 26, 2020 5:54 pm) • Craig010 (Tue May 26, 2020 9:09 pm) • Ryan Rotary Performance (Thu May 28, 2020 8:57 am)
Cooper Red Evolve, Racing Beat Exhaust, Racing Beat Lightweight flywheel, AEM Intake, Tein Flex Z, RRP COFS,
Has thanked: 21 times
Been thanked: 203 times
Post by Yorindesarin » Tue May 26, 2020 4:55 pm
Worse than mine were ooft. Ahah. Probably never even been looked at since the factory.
Post by nightfire10 » Tue May 26, 2020 5:41 pm
Charged battery and went down and fired the car up, first time in 9 weeks lol and only 2nd time going down to the car park 🙄
These users thanked the author nightfire10 for the post (total 2):
GreySilver Beast (Tue May 26, 2020 5:50 pm) • Vj4sothername (Tue May 26, 2020 5:54 pm)
Has thanked: 124 times
Been thanked: 287 times
Post by V8 Power » Tue May 26, 2020 5:44 pm
Started mine today for first time in a few weeks.
Hopefully going out for a bit of shopping in it tomorrow.
Direct cold air feed
RRP Coils MSD leads
Post by nightfire10 » Tue May 26, 2020 6:11 pm
Only on week 10 out of 12 and not sure if it will be extended for sheilding people, can't wait to hear rrp cat sound again going to the beeeep 😻😂
These users thanked the author nightfire10 for the post (total 3):
GreySilver Beast (Tue May 26, 2020 6:21 pm) • V8 Power (Tue May 26, 2020 6:34 pm) • Vj4sothername (Tue May 26, 2020 8:07 pm)
johnbb99
Has thanked: 320 times
Been thanked: 41 times
Post by johnbb99 » Wed May 27, 2020 10:34 pm
Found the battery was so weak it would only rattle the starter solenoid. Gave it several hours charge, and then took it to do the weekly shop.
Craig010
Post by Craig010 » Thu May 28, 2020 5:44 am
Fitted my new RRP MKIII ignition upgrade set, and my RRP 100 Cel CAT. Really impressed with both the quality of the items, and what it's done to the car. It now actually feels like it's got a bit of power, and is so smooth it's like a completely different car! Plus, that rotary sound is much more noticeable through the new CAT, and sounds fantastic, but not intrusive.
A very happy chappie.
These users thanked the author Craig010 for the post:
Post by ChrisHolmes » Thu May 28, 2020 9:53 pm
Painted the Hinsberger exhaust shrouds satin black today. Most annoyingly I got two massive runs on the second one, very peeved with that!
Bridge Ported 231
MazdaSpeed sills
Short shifter
Post by V8 Power » Fri May 29, 2020 6:07 pm
Took mine out for bit of a drive today for the first time in a good few weeks.
Went really well, had to wear the surface rust off the discs and took my time warming it up but once out on more favourable roads it seemed to be very good with no hangover from being parked up.
The backend felt a bit loose but that could just be the tyres are past their best.
These users thanked the author V8 Power for the post (total 3):
nightfire10 (Fri May 29, 2020 6:35 pm) • v-rex (Fri May 29, 2020 6:56 pm) • ChrisHolmes (Sun May 31, 2020 10:41 pm)
RRP Coils MSD leads
Has thanked: 87 times
Been thanked: 275 times
Post by mi60o0 » Fri May 29, 2020 6:47 pm
I'm reading this and I'm so jealous Im still waiting to sell my mazda 6 so rx8 can replace her on the insurance atm 2 cars on the road insured can't afford for n3
BatRex 192 stock
Craig010
Post by Craig010 » Fri May 29, 2020 9:49 pm
Took mine for a decent drive this morning as I had to make a journey, then got busy cleaning and polishing it. Took a few hours but I think it was worth it...
These users thanked the author Craig010 for the post (total 4):
johnbb99 (Fri May 29, 2020 11:22 pm) • untakenname (Fri May 29, 2020 11:38 pm) • V8 Power (Sat May 30, 2020 7:56 am) • GreySilver Beast (Sat May 30, 2020 3:58 pm)
