- RX-8: 13B 4-port
- Has thanked: 33 times
- Been thanked: 56 times
Ooh phew! I’ll keep an eye on it more often though, I normally check it once a week.
- Has thanked: 10 times
Cheers for heads up Feedthegoatxi, got my MoT thursday so ill try book it in fri/sat
Changed the 3 oils today, now starts up whilst hot :O think i need to check if i have done the gearbox oil level correct, their are 2 fill plugs, is it meant to overflow from back (lower) plug or the front higher plug?
Also, gave it a quick polish
Build Thread: https://www.rx8ownersclub.co.uk/forum/v ... 04&t=77496
Overflows from the higher plug. If you only filled to the lower plug then you have no oil in your box.
- These users thanked the author PeteH for the post (total 2):
- 13Black (Fri Jun 22, 2018 9:48 pm) • Culdranth (Sat Jun 23, 2018 11:05 am)
The 192 has two drain plugs on the gearbox plus the fill/overflow
Just about to start an all round brakes check and car valet before Tunerfest South tomorrow!
Think I need to get back under car then gonna see if can squeeze and access it with car in floor. Putting car on 4 Jack's was sketchy
!!!!!! All sets of Mintex 1144 pads are not created equal. Adams last set from the group buy which I collected after the AGM only had three pads in the box bad the holographic silver foil seal was intact so definitely a Mintex packing error.
Thank goodness I had another set or else I would have been gambling with only about 4mm of material left.
AdamG I need a refund!
- RX-8: Evolve
- Been thanked: 7 times
Chased up my RE-Amemiya 5 speed short shifter, paid for 11 June and acknowledged by trader site, UK stock, still waiting delivery.........(ordered a low profile FD sump and crossmember on Monday this week from Russia and it’s here......)
No Pistons:
2004 231 PS Titanium Grey RX-8
2006 Copper Red Evolve RX-8
1993 Montego Blue RX-7 FD3S
Previous: 2005 231 PS Velocity Red RX-8
- Been thanked: 550 times
spent the day hillclimbing. was a complete hoot! and took 1.2 seconds off my time from 1st practice to last timed run, which over a 20 odd second run, is a LOT!
see my thread for details (im uploading photos soon)
- Has thanked: 71 times
- Been thanked: 90 times
6pm and I've still got a lot to do before tunerfest tomorrow, at least the days are long atm...
Washed it ready for brands hatch tomorrow
- Has thanked: 266 times
- Been thanked: 320 times
Ditto (or I took it to the local Albanians to wash on my behalf).
- Has thanked: 24 times
Checked oil before Tunerfest. Whoops a tad low, obviously been enjoying myself with it. Topped up and ready to go.
- Has thanked: 3 times
Tried fitting Padgid Rear pads but they were really tight,,,,, is it normal to need to file them down, I have scraped every little bit of muck/corrosion for behind the springs on the carriers, ended up putting the old ones back in (slipped in fine) going to take them back and opt for another brand
- Has thanked: 66 times
I have Pagid pads on mine and they fit fine. 101680188 on the front and 101680238 on the rear.
RX8 R3 Aurora Blue Mica
Just finished my car for now, still got a bit to do (bleed brakes and perfect the demon eye) but knackered atm so gonna do it when it's light.
Built the front end up and gave it a Polish just before it got dark.
Was great fun!
Yeh same ones.... I think I'll give them another shot tomorrow... maybe even a new spring kit
We know there are some fake Mintex and Ferodo pads in circulation, let's hope there aren't fake Pagid as well.
Foots now going nearly to the floor even though yesterday the pedal was quite firm, hope it just needs bleeding properly and there's not a leak in the system.
Picked up a caliper from LC Rotary yesterday, probably should have fitted it first rather than working on the lights.
Going to try the oil extractor on it, see if any air comes out.
You got time Simon as you don't have to roll up until 8.45am
