direnza spacers...
Conan
Has thanked: 50 times
Been thanked: 640 times
Re: direnza spacers...
Post by Conan » Mon Mar 05, 2018 4:35 pm
GreySilver Beast wrote:
Sun Mar 04, 2018 9:56 pm
The interesting thing about these Spacers over Eibach ones I have had in the past on both RX-8's is that AdamGaltress who fitted them for me didn't have to cut the Studs down to fit, as they fitted perfectly :shock: :thumleft:
I think Nigel is talking about fitting these spacers to his GT86 in case that's not clear to everyone.
It may not be the same on an RX-8 :-k
Has thanked: 5735 times
Been thanked: 1412 times
direnza spacers...
Post by GreySilver Beast » Mon Mar 05, 2018 6:41 pm
Thanks Pete for pointing this out and have Edited my post to include the word GT86 :!:
RX-8OC Club Calendar - GBCC & Network Delivery Service
Track Days = 64.5 + 4 session's/Sprint Days = 13/Car Limits 4 person = 4/Skid Pan = 1/Go Karting = 1/Cars Driven = 181
http://npt-communications.webs.com < Click > ****GSB III**** - GT86 Track Days = 55
bc-49
Has thanked: 20 times
Been thanked: 24 times
Post by bc-49 » Tue Mar 06, 2018 11:39 am
Aston recently made a video about the recesses on the OEM wheels:
In short, rims without the recesses have approx. 3mm of space, those with have approx. 10mm.
2006 Galaxy Grey 231
Yokohama V105 | Eibach Pro-Kit Springs | Eibach 20mm Spacers | Mintex 1144 Pads | Racing Beat REV8 Catback | BHR Ignition | K&N Filter | Koyorad Alu Radiator | Mishimoto Thermostat | Greddy Sump | ER Braided Oil Lines | ER Oil Pressure Reg | ER Baffle Plate | Lockwood Front Grills
feedthegoatxi
Has thanked: 11 times
Been thanked: 5 times
Post by feedthegoatxi » Tue Mar 06, 2018 7:23 pm
I've checked the recesses on my 40th alloys and they're approx 3mm, I'm going to go for the 15mm spacers even though it will involve cutting
thanks for all the info everyone, I'll post a pic when I get them fitted, can't wait
SeeJay
Has thanked: 178 times
Been thanked: 306 times
Post by SeeJay » Tue Mar 06, 2018 7:58 pm
Bear in mind if you do cut the original studs down,you run the risk of leaving them too short to safely keep the wheel nuts tight,should you decide to remove the spacers ;)
Spin Doctor Phil Bate,posted a calculation on the necessary thread lengths,for both ally and steel nuts,but I can't dig it up right now :(
He did however,post this on a Spacer thread in the DIY section:
Phil Bate wrote:
Mon Nov 06, 2017 8:59 am
I cut the studs on mine initially - easily done with a bi-metal bladed hacksaw if you don't want to mess around with a grinder - but this caused a problem later when I removed the spacers to fit after-market wheels as the studs were then too short to offer enough thread through the thicker wheel centre.
Replacing the studs is easy enough on the front but meant removing the stub shafts on the rear and consequently replacing the rear wheel bearings. For me this was delightful as I enjoy that kind of thing, but it does mean a fair bit of work including removing the rear knuckles (and tackling the usually-seized tow-control arm), and having access to a hydraulic press. You can share the pain joy here if you wish! viewtopic.php?p=953415#p953415
If I ever did it again I would be more inclined to recess the wheel instead of cutting the studs, given the work it takes to reverse it.
direnza spacers...
Post by GreySilver Beast » Tue Mar 06, 2018 9:12 pm
Just to add something else that some of you haven't quite grasp the beauty of Direnza Spacers is you can buy ones that are pacific to the car they are going on, so should fit your car without having to cut the Studs down to size =D>
This was one of the many reasons why Jay Murray (JR Motors) recommended them to me over having Eibachs :!: :!:
Hence why the ones I bought fitted the GT86 perfectly without cutting the Studs which also means they can be taken back off the car when you want to return the car back to stock :thumleft:
Rotary Potato
Has thanked: 59 times
Been thanked: 277 times
Post by Rotary Potato » Tue Mar 06, 2018 9:15 pm
... that are pacific to the car ...
I sea.
:lol:
Huw
2004 Velocity Red 231 - SatNav, parking sensors, sunroof, red/black interior, K&N Typhoon, Toyo backbox, f- :censored: -ked engine - bought Jun 2016 sold Oct 2016
2006 Black PZ - Rotary Revs full Bridgeport Gold rebuild - Toyosport decat - SAI delete - 585R coils - K&N air filter - purchased Oct 2016 - Engine rebuild Dec 2017
Has thanked: 2700 times
Been thanked: 997 times
Post by ChrisHolmes » Tue Mar 06, 2018 9:21 pm
They must have magical properties then Nigel as a 20mm space regardless of make would leave the same amount of original stud proud of the wheel mating face so the the interference problem still remains if the wheels involved have shallow recesses.
Toyo SS Catback
SS Strakes
Custom Sat Nav 3 Gauge install
Meister Zeta R Coilovers
Whiteline ARBs
Slotted & Dimpled Discs
Mintex 1144 Pads
Full OE Aero Kit
Revolution Alloy Strut Brace
Lockwood SS Grills
Passenger Footrest
Lambo doors
Original engine 86k miles (169.7 rwhp) and then it died!
Own build Steet ported engine 173whp Feb 2018
Low comp at 7k miles 8th Dec now SORN
wiggles
Has thanked: 91 times
Been thanked: 110 times
Post by wiggles » Tue Mar 06, 2018 10:20 pm
They do come in several bore sizes which is good though
Project thread Galaxy grey 231 - Street Port, Enkei 9J wheels, Tein coilovers, Jperformance exhaust
untakenname
Has thanked: 74 times
Been thanked: 88 times
Post by untakenname » Wed Mar 14, 2018 7:43 am
Noticed a Direnza hub adaptor warning doing the rounds on facebook this morning
Has thanked: 532 times
Been thanked: 735 times
Post by 13Black » Wed Mar 14, 2018 8:55 am
As a machinist myself, I've gotta say that making them THAT far out of spec has to be a one-off. Something has to go very wrong for them to be that bad - typically just chucking something in the lathe (even a cheapy chuck) you'll get it within 0.15mm runout.
If they were all that bad, everyone's car would have shaken itself to bits before you got to the end of the road.
Surprised that something this obvious went unnoticed, but I suppose big companies can only QC a percentage of their batches.
Juey
Colour: Black Cherry
Has thanked: 15 times
Been thanked: 72 times
Post by Juey » Wed Mar 14, 2018 9:18 am
20mm spacers on anniversary rims, also on eibach springs, modest 15-20mm drop.
I do not spook easily and those who think I do are wasting their time with their surprise attacks.
Women feel comfortable in my presence, with my tales of sexual experimentation both on the high seas and on railway property.
I am a wizard with star shaped Chinese weaponry, which I throw accurately and without due for-thought.
Delanor
Has thanked: 6 times
Post by Delanor » Wed Mar 14, 2018 9:51 am
Direnza spacers have a good spec` on paper with all the right materials, when fitting 20mm spacers to my 40th Anniversary the studs needed shortening.
Rotary FX fender grills, Japspeed stainless exhaust, K & N filter, Kinetix slotted & dimpled discs, EBC Red stuff pads, DIY AC Delco D585 coil conversion, Magnecor leads, Stainless front & rear grills, HID main beams, LED tail lights, front side lights/front fogs.
AndyBrad
Has thanked: 4 times
Been thanked: 8 times
Post by AndyBrad » Wed Mar 14, 2018 11:08 am
so will you need to shorten the studs with r3 alloys?
SeeJay
Post by SeeJay » Wed Mar 14, 2018 12:47 pm
As I mentioned above,when I had 20mm spacers on my R3,with the original wheels,the studs didn't need cutting down..
Goobie
Has thanked: 17 times
Post by Goobie » Wed Mar 14, 2018 12:54 pm
20mm all round on my R3 to, no cutting etc, fit and forget, although mine are Eibach.
AndyBrad
Post by AndyBrad » Wed Mar 14, 2018 2:57 pm
why did you take them off?
SeeJay
Post by SeeJay » Wed Mar 14, 2018 3:08 pm
Also,as I said earlier :roll: - do you not bother reading a thread from the beginning? - I fitted aftermarket wheels which were wider,with a lower offset,which gave the equivalent effect of 20mm spacers..
direnza spacers...
Post by GreySilver Beast » Wed Mar 14, 2018 3:24 pm
Well I am very happy with the Direnza Black Edition 25mm Spacers that I have on my car =D> =D> =D> =D>
I just couldn't justify the price of Eibach's anymore so looked for other makes on the market and then asked for some advice from my friend Jay aka jrmurray1108 :thumleft:
I took his advice as he had used Direnza on a few of his cars before 8)
AndyBrad
Post by AndyBrad » Wed Mar 14, 2018 3:46 pm
aye sorry my bad. :oops: [-o<
Has thanked: 159 times
Been thanked: 700 times
Post by PeteH » Wed Mar 14, 2018 6:06 pm
Don't worry Andy, no question is a daft question, and SeeJay was just offering helpful advice. And you have my permission to shout at Nick as well, he usually deserves it... ;) :lol:
AndyBrad
Post by AndyBrad » Thu Mar 15, 2018 9:50 am
Post by 13Black » Thu Mar 15, 2018 9:51 am
I like the abuse.
Makes me feel alive.
Has thanked: 225 times
Been thanked: 768 times
Post by warpc0il » Thu Mar 15, 2018 11:19 am
:kinky: :censored:
xamtex
Been thanked: 42 times
Post by xamtex » Thu May 17, 2018 4:30 pm
pz rim faces are flat so studs need trimming
