COME ON THE R3's
- kopite72
- Colour: Diamond Grey
- Has thanked: 458 times
- Been thanked: 889 times
Re: COME ON THE R3's
If it's on coilovers it's not a problem
R3 GONE, FUN WHILE I HAD HER BUT NOW LOVING MY 25TH ANNIVERSARY MX5.... MODS INBOUND
- warpc0il
- Has thanked: 491 times
- Been thanked: 2004 times
- Contact:
- GreySilver Beast
- Has thanked: 11856 times
- Been thanked: 2912 times
COME ON THE R3's
I know what Marc went for and it wasn't PZ Suspension
, so he shouldn't have any trouble on the track Dave and Ian
GSB III 03/08/13 - Present
- kopite72
Adjustability,you're saying that dropping a car that low may cause issues whilst on track,surely by adjusting the height you can negate said issues to a certain extent?
- warpc0il
- Contact:
If you have adjustable coilovers and if you take the time to re-adjust them, and the potentially camber settings, for the track, then sure they'll be fine and, if they're good quality coilovesr then they'll be more than fine.
What I was saying was that a car sitting with that stance isn't going to work well on the track.
- Dr. FrankenRex
- Has thanked: 267 times
- Been thanked: 586 times
- Contact:
That's a slightly redundant statement without knowing what the car is running in any way, shape or form...
It's like saying putting nitrous in to a car without adjusting the handling will make it slower on track. It may or may not be factual, but alone it's not a helpful statement.
My R3 is on lowering springs, coupled with up-rated strut braces front and back and some RB ARBs. It most certainly doesn't lift an inside wheel or spear off in to the boonies as you say. It most definitely is quicker on a smooth track than a stock R3 on the same tyres and isn't purely for style...
- warpc0il
- Contact:
Which is why I said "Lowering to that level" rather than just "Lowering".
I'm sure that you car isn't on the deck and has sufficient remaining suspension movement to get the benefit on a smooth track.
- Dr. FrankenRex
- Contact:
Mine's about the same as Marc's from what I can see. It's not that low to be honest and I'd expect it to handle quite well (assuming supporting modifications and/ or setup) on a track...
It's not like it's been stanced on 'bags or anything completely stupid.
- Dr. FrankenRex
- Contact:
- warpc0il
- Contact:
Looking at photos, taken at different angles, isn't an exact science and it looks to me that the silver R3 is lower than yours.
Let's just agree that there is a point where lowering a car crosses the line and handling benefits, even on a smooth track, become compromised.
Yours is above the line, while Mpv2k3's, if it's as low as it looks to me, is close or potentially over the line.
However, as kopite has also pointed out, if it's on adjustable coilovers, then it could also be reset for better handling as appropriate.
- Dr. FrankenRex
- Contact:
I still don't think so, sorry Dave. If you're talking about splatting it on the deck with a set of bags resting on the bump stop then yeah, but we're not talking about that. Even if Marc's R3 is sat on lowering springs without much else being done I'd expect it to be OK - this is speaking from experience as my car was running just springs when I first got it and I've added the other bits myself.
Also don't forget that the R3 has 19" wheels, which fill the arches more, and make an 8 look lower than it would on a set of 18s (which Marc runs on track). All these things mean that, bluntly, I don't think you're right, regardless of if it's coilovers or lowering springs.
In this case Marc is running coilies AFAIK, and based on what I know of Marc and his car he'll have had the work done properly and set up correctly.
- Eddie_r32
- Has thanked: 44 times
- Been thanked: 157 times
Marc's isn't that low, the 19s and the side skirts make it look lower but there is a decent arch gap and cars still pretty high off the ground, I'd be happy to bet that the suspension arms will be level, you get problems when you start to have the arms pointing upwards
2007 Galaxy grey 231.
- kopite72
I don't agree, I'd be willing to bet she's dropped by at least 30mil. There's minimal arch gap, in fact you'd be hard pushed to get a finger between the top of the tyre and the arch.
Marc correct me if I'm wrong here but aren't you running electronic adaptive suspension? If that's the case you can set her up at the touch of a button from the steering wheel, nooooooice
- Eddie_r32
How fat are your fingers?!
- Dr. FrankenRex
- Contact:
I can't fit my fingers between the rear wheel and the wheel arch - no problems with mine on track as said
- V8 Power
- Has thanked: 234 times
- Been thanked: 488 times
Marc parked his R3 next to our R3 last saturday and although lower it did not look ridiculously low.
In fact for some reason it looked lower in the photo.
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
MSD leads
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
- Has thanked: 177 times
- Been thanked: 786 times
I suggest we draw a line under this now. There's a lot of guesswork and speculation. And it's diluting the thread.
- GreySilver Beast (Mon Apr 08, 2019 4:09 pm)
- Dr. FrankenRex
- Contact:
Consider line drawn (or at least, picture drawn...)
- MARKTHOMASBRAND
- Has thanked: 1551 times
- Been thanked: 1567 times
- Mpv2k3 (Mon Apr 08, 2019 11:01 pm)
- gareth72
- Been thanked: 3 times
Hi everyone just had a message my old R3 is now in France a nice gentlemen called Wilfred had bought her.
Hopefully he’ll post some pics of the old gal
Hope everyone is keeping well
COMMITEE - Discounts (2004 - 2007)
MODERATOR 2004-2007 for my sins 2010-2013
2004 RX-8 192 Titanium Grey Pocket Rocket
2007 Focus ST'2 276BHP
2009 RX-8 R3 Sparkling Black + custom Spirit R seats PE58RKF
2013 Audi A3 S-Line Sportback - current
2016 LR Discovery Sport SE TECH Corris Grey
2019 LR Discovery Sport HSE Landmark Edition Narvik Black
- Shagrington
- Has thanked: 841 times
- Been thanked: 861 times
- gareth72
- GreySilver Beast
COME ON THE R3's
Hi Gareth and
back to the RX-8OC
- gareth72
Never left Nigel just lurking in the background
Its amazing I joined this club 15 years ago.
- These users thanked the author gareth72 for the post:
- GreySilver Beast (Thu Apr 11, 2019 6:26 pm)
- Has thanked: 6 times
- Been thanked: 25 times
Taken a while back but I never shared it, looking back I quite like it.
Mazda by Graeme Sugden, on Flickr
- These users thanked the author graemeS83 for the post:
- Dr. FrankenRex (Wed Jun 26, 2019 10:27 am)
