Forge Action Day 2018 | Saturday 8th September | Castle Combe
From non-stop track action to huge club displays and some of the biggest names in the performance scene, this is not to be missed!
Track Action / Drifting Demos / Passenger Rides / RX-8 Club Stand / Show & Shine Competition / Forge Motorsport Exhibitor Village
Tickets available in the Club shop now!
Aluminium Electric Water Pump to help horsepower and cool your hot Rotary
Mazda Rotary Parts, RX-8 parts specialists for all your Rotary needs. We aim to help and assist our customers make the right choices for their Rotary whether they be standard or modified.
email:- sales@mazdarotaryparts.com Tele 01474 361800 (Part of the ShyAuto Group)
Mazda Rotary Parts
Forum Trader
Forum Trader
Has thanked: 19 times
Been thanked: 40 times
Post by Mazda Rotary Parts » Sun Oct 08, 2017 4:42 pm
For ardent track day users or just owners who want to make sure their Rotary stays nice and cool, used in our own race car for the last four years, this Davies Craig EWP150 High flow electric water pump with aluminium housing will aid cooling and increase horsepower as the power is not drawn from the engine and it also offers an effective way of still cooling your engine after a hard run once the engine is turned off.
With a flow rate of 150 litres per minute, this pump is now the highest flowing water pump of it's kind , can be put on a flip switch, plumbed into the ignition key or a full programmer can be added .
Many think I have another Turbo fitted but as you will see I have this electric water pump sitting below the real Turbo :mrgreen:
http://www.racingbeateurope.com/bdavies ... 2592-p.asp
REgards
Clive
http://www.mazdarotaryparts.com
We aim to help and assist our customers make the right choices for their Rotary, whether they be standard or modified. If you need further assistance, please do not hesitate to contact us:-
sales@racingbeateurope.com or call 01474 777 800
StreetDragster
Has thanked: 13 times
Been thanked: 42 times
Re: Aluminium Electric Water Pump to help horsepower and cool your hot Rotary
Post by StreetDragster » Sun Oct 08, 2017 4:50 pm
Do you sell the adaptors for the water pump Clive?
Matt
Has thanked: 146 times
Been thanked: 595 times
Post by PeteH » Sun Oct 08, 2017 5:09 pm
I'm going this route Clive :thumleft: Do you do the 115l/min plastic one? And what StreetDragster said about the adapter....
Has thanked: 162 times
Been thanked: 614 times
Post by warpc0il » Sun Oct 08, 2017 5:37 pm
We need a UK source for these
https://www.rx8performance.com/products ... water-pump
unless that pump fits differently, e.g. directly in place of the existing.
SeriousSam
Has thanked: 30 times
Been thanked: 179 times
Post by SeriousSam » Sun Oct 08, 2017 5:49 pm
I'm a little surprised that rx8performance don't have a distributor or reseller here in the UK, there would appear to be a slight gap in the market for someone with an existing import system to bring in some of their parts.
Post by PeteH » Sun Oct 08, 2017 5:53 pm
That looks like an easy one for Carl at RRP..........
Clive
Has thanked: 120 times
Been thanked: 147 times
Post by Clive » Sun Oct 08, 2017 7:57 pm
We were ideally placed to deal with Scott and actually tried to deal with him with very little results a few years back, but unfortunately you really need to trust people to trade with them, they actually used to be known as mindseyeengineering.com before becoming RX8performance
Anyway, I will look into having an adaptor fabricated but the water pump itself can be modified to run one of these pumps by modding or removing the impeller.
StreetDragster
Post by StreetDragster » Sun Oct 08, 2017 8:53 pm
That's a good idea, I've got a spare water pump, I'll have a look at it
Matt
Post by warpc0il » Sun Oct 08, 2017 10:21 pm
Have you got the Clarkson-designed gasket? #-o
water pump gasket.JPG (11.07 KiB) Viewed 357 times
StreetDragster
Post by StreetDragster » Tue Nov 07, 2017 10:02 am
Morning all,
I've started to make some changes ready for going to am electric water pump. The plan was to get an oem pump, remove the impeller etc and weld it up, then fit the pump in the bottom radiator hose, leaving the thermo stat in and just running a belt between the bottom Pulley and the Alternator (no ac)
However, the protrusion from the water pump fouls the belt run, so i'm just going to make a blanking plate instead from 4mm alloy sheet.
This would also affect the rx8 performance adaptor plate, not sure how they are planning to use it, but to me it seems like the pipes would be very close, if not fouling the belt run.
Something to look into prior to ordering the rx8performance plate if you are considering it
Pipe run from the bottom radiator hose doesn't look like much fun, not about of space down there
Matt
Post by PeteH » Tue Nov 07, 2017 10:14 am
Thanks Matt. Useful info. The alternative would be to remove the impeller, but leave the shaft, bearings and pulley on the casting. Then use the pulley as an idler. The belt run would then remain standard, but there would be no water flow restriction for the ewp, and the losses from the idler would be very small.
StreetDragster
Post by StreetDragster » Tue Nov 07, 2017 12:34 pm
Yep i had considered that too Pete, i just mainly wanted to highlight the potential issues with the RX8p plate prior to people shelling out nearly £200 for one.
I think i'm commited to fitting a plate at the moment, i like simple, and one less bearing and pulley appeals to my nature.
Post by PeteH » Tue Nov 07, 2017 12:58 pm
Yep, I agree Matt, and thanks again (because I may have bought the RX8p plate...)
Just one thing about a flat plate. The standard pump housing has a significant recess which contributes to the size of the water passages. If you use a flat plate you are reducing the cross-section of that part of the water system. I think the feed port for the impeller is already quite small, to speed up the flow onto the impeller, so making it even smaller may be a bad idea.
I think a better way to do it would be to mill a recess into your plate, but you may need to start with plate about 10mm thick, because I think you may need a 6 to 8mm recess. That's getting a bit involved though, so maybe worth a try with a flat plate first?
StreetDragster
Post by StreetDragster » Tue Nov 07, 2017 2:20 pm
Will have a look at the water pump and the engine casting once I have it all apart and report back. :-)
Matt
Has thanked: 2073 times
Been thanked: 700 times
Post by ChrisHolmes » Tue Nov 07, 2017 3:02 pm
Best check whether RX8Performance will ship to the UK.
Toyo SS Catback
SS Strakes
Custom Sat Nav 3 Gauge install
Meister Zeta R Coilovers
Whiteline ARBs F&R
Slotted & Dimpled Discs F&R
Mintex 1144 Pads F&R
Full OE Aero Kit
Revolution Alloy Front Strut Brace
Lockwood SS Grills
Passenger Footrest
Lambo doors
Original engine 86000 smiles (169.7 rwhp) and then it died!
Own build Steet ported engine fitted Feb 2018 and running sweet as nut
Return to “Mazda Rotary Parts”
