So do they just pop off with some leverage?
And then press back on?
I should check for corrosion, treat if required, and spray with waxol.
Then they clip back on?
So Sills...
- willberry70
- Has thanked: 1089 times
- Been thanked: 366 times
So Sills...
Sparkling Black Kuro SN# 400/500. PZ suspension, Mini-mapped, EBC Red Stuff fronts disks, Custom Oil Lines, Varta E27 battery. Blacked alloys, K&C air filter, RRP Mk2 Coils and MSD Leads, Krown rustproofed.
Events Coordinator
Events Coordinator
- Has thanked: 49 times
- Been thanked: 587 times
Re: So Sills...
I'm assuming you mean the plastic guards? not the metal bit ....
but to remove them you have to undo a couple of anchor screws at the front and they slide off a plastic bayonet type of fixing
in my experience you'll generally be horrified at what you find......
- 13Black
- Has thanked: 507 times
- Been thanked: 811 times
- Contact:
Re: So Sills...
By remove screws, I assume you mean drill out
Or reach into the front wing and pop them out.
If they don't want to slide, a ruler stabbed inward to release the outer of the 2 clips and pry'd down can work.
Probably take half of the rear sill with it, but at least that would answer one of your questions.
