De flood.
- The Ginga NinjRx8
- Has thanked: 9 times
- Been thanked: 9 times
De flood.
I know there is a how to on here but can not find it could someone please direct me as I think I may have this issue
Stealth black 192:
Pioneer double din head unit
18"x9.5 ET40 all around
MisteR coilovers
Rear smoked LED
MisteR coilovers
Rear smoked LED
- Nickp47
- Has thanked: 278 times
- Been thanked: 508 times
Re: De flood.
Somebody correct me if I am wrong but all you REALLY need to do is hook the car up to a power source, hold the accelerator and clutch down and turn it over for about 10 seconds four or five times (with gaps in between of about 30 seconds to prevent overheating etc). Unless it is badly flooded, this should do it.
- kopite72
- Has thanked: 701 times
- Been thanked: 1706 times
Re: De flood.
Tow start it, easiest and kindest way to the SM
- Delanor
- Has thanked: 57 times
- Been thanked: 317 times
Re: De flood.
- Shagrington
- Has thanked: 964 times
- Been thanked: 1056 times
Re: De flood.
Or this is a slightly more detailed explanation for one method viewtopic.php?f=25&t=36551
Towing for a bump start is the kindest method for the starter motor - and the quickest way to do it.
- The Ginga NinjRx8
Re: De flood.
Thanks peeps I used d deflood guide on Essex rotary site I ended up needing to charge my battery as I think it was a bit down on power so we'll be giving it a go tonight
Stealth black 192:
MisteR coilovers
Rear smoked LED
MisteR coilovers
Rear smoked LED
- Delanor
Re: De flood.
If you are trying to start after a flood with a discharged or weak battery you are only exasperating the situation, you will be going round in circles as constantly turning it over without actually starting is just pumping more petrol in aside from the bore wash which is removing any protective oil film.
If you haven`t got a top spec` healthy battery, coils & plugs then you need them.
- The Ginga NinjRx8
Re: De flood.
Ok so I have just finally done my first successful de Flood I am currently taking it for a run to clear out but can anyone help me to get rid of the traction control light and sorry for the dumb description the little red that looks like a cable car with Windows lol
Stealth black 192:
MisteR coilovers
Rear smoked LED
MisteR coilovers
Rear smoked LED
- Nickp47
Re: De flood.
Traction Control light should go out once you re-start the car after a drive, the 'cable car' light sounds like the coolant level sensor which is a very common thing, options being replace the coolant tank or disconnect the sensor.
- The Ginga NinjRx8
Re: De flood.
Thank you very much once I stop the car after the run I will see what happens
I thought I had the coolant one disconnected already but will check
Stealth black 192:
MisteR coilovers
Rear smoked LED
MisteR coilovers
Rear smoked LED
- Ainmhidh
- Has thanked: 531 times
- Been thanked: 454 times
Re: De flood.
Assuming you have a tank full of coolant of course... ;-)
- The Ginga NinjRx8
Re: De flood.
Last time I checked
Stealth black 192:
MisteR coilovers
Rear smoked LED
MisteR coilovers
Rear smoked LED
- Shagrington
Re: De flood.
The coolant warning light - we all get that, or will get it. Most unplug the sensor and just check the coolant level visually regularly (I do that but left it plugged in - I just ignore the light).
You may need to turn the steering full lock to the right then all the way back to the left to clear the traction control lights.
- The Ginga NinjRx8
Re: De flood.
Traction light is gone only the coolant one is left. Cars running good and turning on first time now. Just to sort the coolant light
Stealth black 192:
MisteR coilovers
Rear smoked LED
MisteR coilovers
Rear smoked LED
