Solar Power Battery Charger
- djtonymorgan
Since I don't use my rex much and my OBD reader is always plugged in I find my new battery feels a little sluggish on starting.
So, I'm just rebuilding a till in a Halfords and notice they have the Ring Battery Maintainers at a really good price, cheaper than I can get them on Ebay! Amazon is a quid cheaper but I can take one away with me now from Halfords.
£14.99 for the RSP150, for up to 50Ah batteries which may be a little weak.
£24.99 for the RSP240, for up to 100Ah batteries which should be more than sufficient for an RX8.
Anyway, we know that you cannot just plug this into the lighter socket as the relays only engage when the key is in position 1.
So you would need to connect it to a permanent live from a fusebox or run a new cable.
Luckily I've fitted a powered sub into my boot so I already have a direct power cable to the battery so I'll fit the solar panel onto my parcel shelf with velcro tabs, I love a job that requires minimum effort!
SOLD
- madder
Re: Solar Power Battery Charger
The amount of inverted current these would provide into a car battery is neglible. Normally a suitcase sized array would do 250watts !.. An entire array of pv on a roof only.just manages 3kw in roaring sunshine. Can't really beat the effectiveness of fossel fuels into a altenator!
Racing brake 4 pots , stage 1 organic clutch, flywheel, Racing beat[/color] Resonated dc..Racing Beat Rev4 catback. COBB AP Black Halo Racing Ignition pack EVO2 race battery
rotorstock 8 fastest 1/4 mile 14.95 secs
- djtonymorgan
This is my first go at keeping the battery charged, if it doesn't work I'll have to get a mains powered trickle charger and the panel can the go on my shed to run lights inside.
SOLD
Or you could fit one of [urlw=http://www.ebay.co.uk/itm/Universal-Car ... 35d72bf62e]these [/urlw]
- warpc0il
- Has thanked: 822 times
- Been thanked: 3534 times
- Contact:
Leaving the battery disconnected for a long time can cause the power steering control module to fail.
There have been multiple reports of this happening, though it's still not fully understood why.
- Helisupp
Well I fitted one to my car, battery was still nearly flat after 4 weeks........................its now on the garage shelf never to be used.
I also tried it on my motorhome with no effect.
It was giving 13-14 volts so something must be happening, I think the battery is draining quicker than the solar panel can keep the charge.
- Ian.Mothersole
- Has thanked: 55 times
- Been thanked: 549 times
- Contact:
^^I have a similar story...
Tried a solar charger, and it was completely useless.
So I bought a fairly cheap trickle charger and a long length of wire to run it out to the car - Works perfectly
Ian.M - Keep It Simple!
Club Shopkeeper & Forum Admin Team
"Rex" 2009-16
Velocity Red 231; Hayward Rotary ported engine; Racing Beat exhaust, flywheel, air duct, anti-roll bars; Eibach lowering springs, wheel spacers; Essex Rotary mini-remap; Prodrive PZ spoiler.
"Rex 2" 2014-
Velocity Red 231; the project car.
"Blue Rex" 2015-
Winning Blue 231; RX ATE.
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
- warpc0il
- Contact:
Only for "trickle charger" read "smart charger".
A trickle charger supplies a small amount of charge current all the time, whereas a smart charger supplies the amount of current (varying from high, to low, to nothing) to keep the battery in top condition.
I suspect that's what Ian meant too.
- Ian.Mothersole
- Contact:
^Yes thanks Dave, smart charger is what I meant
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
- Flameshades
- Been thanked: 18 times
My solar charger has diodes oin it to stop discharge at night etc. Seems to work well. battery is up at same voltage it was when connected to the car (currently in garden as waiting for bits. )
- djtonymorgan
With the recent good weather I have noticed a definite improvement in starting after being left for over a week, must be keeping it at the same level.
SOLD
- Lineypirate
My car has a battery fitted that can only be described as "dog-egg" and normally fails after about 5 days. However, a Maplins own solar charger (cost about £25) kept the battery topped up enough to start after about 3 weeks with no issue. My trusty multimeter tells me it's putting out about 20v in the sun so it's doing something!
Velocity Red Mica 231 w/ Red and Black Leather / RR Rebuild + Street Port / Nexus Install / K&N Panel / Magnecor 8.5mm Ignition Leads / RX8Performance Engine Mounts / Drilled and Grooved Discs / SS Strakes / Lockwood Grilles / Toyosport Catback / RR D585 Coils / MRP Catch Can / Sokie Tech Bonnet Dampers / Personal Plate ... Always happy to help with spannering around Lincolnshire!
