Copied CD's
- Sykobabble
Copied CD's
I have been meaning to post this for a while.
Found the attached letter in the bumf when I bought my 8.
What are your thoughts, anyone else heard this?
- Attachments
- Mazda Letter.jpg (57.91 KiB) Viewed 6334 times
- Sykobabble
Re: Copied CD's
Maybe its just a ploy by Mazda to encourage the purchase of original CD's
Anyway it doesn't really effect me because I don't own any copied CD's
- ta88ycat
Re: Copied CD's
Buy this and all of your problems will go away (and you can still use the headunit with the Cd stuck in it):
http://www.rx8ownersclub.co.uk/forum/vi ... 15&t=26225
ex-VR 230 with FF Sat nav, R/B leather and RXB plate.
Rear deflectors, side aero skirts, S/S Crest, S/S Strakes, Chrome fog light surround, Rear parking sensors[Targa MR2], Audiolink ipod adaptor with Brodit clip and mount, Racing Beat Zorst.
Now moved to the dark side - BMW 330d M Sport, 245 horses, 374 torques and 50 mpg.
- nevryn
Re: Copied CD's
TBH that sounds like rubbish. I've just compared the first original CD I could find with the first blank I could find and the original is noticably thicker than the blank. Obviously not an exhaustive test but originals tend to be better quality (thicker, stiffer) than cheap blanks.
'56 Galaxy Grey PZ with RacingBrake callipers, disks and ET500 pads. No adornments other than a coat of wax.
- ta88ycat
Re: Copied CD's
I think the problem is more likely to apply to those CDR's with home made labels attached and the el-cheapo non major branded CDR's. The labels tend to come off and stick in the unit or stick the CD in the unit.
Best to use a CDR pen for labeling.
I think the letter above is a dealer generated one based on a few occurences of the problem and Mazda has perhaps commented on the matter.
- cool'n'funky
Re: Copied CD's
It's half pants, half true. As long as the CD you're using bears an official logo (either Compact Disc Digital Audio, Compact Disc Recordable, etc.), then the physical dimensions are exactly the same within specified design tolerances (which are the same for audio CDs as data CDs), so the only thing the player should do is spit them out if it can't read them. A good CDR is exactly the same as a good CDDA. If it doesn't bear one of those logos, then it may not conform to the CD standards (orange book/red book etc.), which means it's physical size may be different (fatter/thinner whatever). Same goes if you stick a label on it - by doing that you're effectively making it non-standard as well. And thinner is probably just as bad as fatter in terms of out of spec, as the mechanism may have trouble handling and thickness it's not designed to.
Upshot is, if you use cheapo knockoff CDRs, and they are that cheap that they don't have one of the logos, then your dealer has every right to make the excuse in the letter. If it does conform to the standards, then irrespective of if it is a CDR/CDRW the letter does not apply - as long as you've not gone and stuck a label on it and messed it up that way (i.e. you have used just marker pen as ta88ycat says).
Mildly modified.
Furiously Wankelling away since August 2004.
Engine 1 spun its last spin at 88620 miles (YouTube before&after). Engine 2 still going...
These views are mine alone, and do not represent the views of any organisation I may be - or may be perceived to be - associated with.
- Been thanked: 7 times
Re: Copied CD's
Sorry to bring up an old thread but I found something interesting in the handbook regarding using copied cd's.
It says to rub around the edge of a cheaper quality cd-r with a pencil to remove it's jagged edges. Apparently this should prevent the changer from swallowing cd's.
Don't know if this has been discussed elsewhere?
Jap.Club Project Page.
- Shaunzrx
- Location: Home Town: Harrogate, now living in Fernhill Heath, Worcester
Re: Copied CD's
Mines the same mate, been told to try thicker more expensive blanks but it's just the same, just have to stick with originals I'm afraid....
(Acquired Rex Sept 2009)..... (Now Sold) Click>>>> "My Personal Car Project"
- Shaunzrx
Re: Copied CD's
will give this a go...Joblin wrote:My eureka moment was when I burnt the CDs at a slower speed, 8x or 12x was fine
- Shaunzrx
Re: Copied CD's
Tried & doesnt work, give up trying now....
- warpc0il
- Has thanked: 822 times
- Been thanked: 3534 times
- Contact:
Re: Copied CD's
I've yet to have a copied CD rejected by mine.
Sounds like I've been lucky... so far.
- Bulldog
- Has thanked: 15 times
- Been thanked: 90 times
Re: Copied CD's
Basically anyway they can get away with you paying for something ...
- scylla
Re: Copied CD's
I know this thread is a little old now but its something i think many owners come across and are a little dissapointed with. This included myself buying 2 different brands 1 cheap one expensive and still rejecting them.
But i stumbled across something interesting. It seems the 6 CD changer Bose system has a underlying hatred for mp3 but seems to quite fond of wav format. I just burnt a cd using this new idea, worked a treat!!! Hope this trick helps someone else in future stress
Titanium grey: gone but not forgotten
- warpc0il
- Contact:
Re: Copied CD's
The S1 player is only designed to play CDA (Compact Disc Audio) format - which is a very specific implementation of WAV - and is what all pre-recorded audio CDs are.
When burning music to disc for playing in the car you need to convert to CDA (most CD writing software includes this option) and you'll be limited 70 minutes per disc.
The player in the S2 (R3) plays CDA and MP3 formats but it's still limited to a subset of the MP3 options.
It's not too keen on VBR (variable bit rate) so choose CBR (Constant BR) and don't try rates above 320.
- vic_cambridge
Re: Copied CD's
I just make an audio cd using Nero and use good quality audio cd's, Ive never had a problem.
Eibach Lowering Springs, Axial Short Shifter, Tarox F2000 Brake Discs, Braided Brake Lines, K & N Air Filter, Magnecor Leads, Rotary Revs D585 Coils, Toyosport Oil catch can, Rotary Revs Rebuild *SOLD October 2014*
New Ride: Mercedes CLC 220 CDI
- DanBass
- Has thanked: 19 times
- Been thanked: 153 times
Re: Copied CD's
Mine rejects all forms of CD, and having done an awful lot of sound engineering and having some fairly decent equipment I've tried a huge variety of formats, compression rates, everything. The fact is that the stock changer is pants, and the laser dies very quickly, so I went to xcarlink and never looked back.
- brix79
- Forum Administrator
- Has thanked: 133 times
- Been thanked: 445 times
Re: Copied CD's
Same here, nothing works. Just have to choose to go for Xcarlink, auxmod, connects2 or one of the Grom units...
Forum Admin Team
Forum Admin Team
- scylla
Re: Copied CD's
I take it the car does not like my musical taste. Regardless if I switch to cd when I switch the ignition on I guarantee it spits a cd at me. Very tempermental unit
- duckula67
- Has thanked: 9 times
- Been thanked: 10 times
Re: Copied CD's
I had this problem with my old BMW.
I found that the only cd it would accept was a sony one and i burned them at 1x speed.
never had a problem after that.
Mods:Black wheels.Start button.AEM CAI.D585Coils.EBC ultimax discs.Yellowstuff pads.Racing fluid.Stainless brake&clutch lines,Stainless vents.Cobra Catback.Bonnet struts.Auxmod.Custom Gauge pod.Eibachs&Fast road setup.Shortshift.Sohn adapter.Comp clutch&Flywheel.N/plate offset.Red calipers.Leather Gaiter.LEDs in&out.Smoke LED rear lights.LED 3rd brake.
- stever
- Been thanked: 8 times
Re: Copied CD's
My car's always intermittently rejected copied CDs and last week it finally tried and failed to reject one. Now whenever I turn the car on I get a bit of clunking from the CD player but nothing comes out, so I now have 6 (copied) CDs stuck in there and nothing to listen to but the radio
Titanium Grey 231ps 23/12/03 to 20/10/13
Velocity Red R3 20/10/13+
Racing Beat springs, anti-roll bars and exhaust. Eibach spacers. RB Big Brake Kit, K&N filter. D585 coils & Magnecor Leads. Sports mirrors. B-pillar trim. Scuff plates. Interior LEDs. Bonnet stays. Ultra light fly wheel. Axial Flow short throw shifter
The other car: Tesla Model X P100D 19/12/17+
