Noisy Steering Wheel
- Evolve RX8
Hi
Has anybody had any creaking noises from when they turn their steering wheel? Is this something I should go back to Mazda on?
Any advice would be welcome.
Ta
Ta
Evolve Owner
Copper Red Mica with Club Decals
Withiut casting doubts are you sure it's not the drivers seat? Well documented "issue" that seems to come from everywhere in cabin other than the actual seat
J.
J.
Former Club Chairman
Former Events Coordinator
PZ,GG, SS Strakes, Tints, R B Exhaust, K&N Filter and Bonnet Stays.
190 Strato gone but not forgotten.
'08 Applecross Tug of War Winning Team Member
- Everton
- Has thanked: 7 times
Re: Noisy Steering Wheel
Old thread resurrection time!
Have a major problem with the steering that developed over the past couple of weeks. Had the notchy steering last year so cleaned and lubed the steering joint - all sorted. The problem occurred again a couple of weeks ago, so did the same - whipped the wheel off, wire brush to get rid of the surface rust, drenched with WD40......lock to lock a few times, then given a liberal coating of silicone grease afterwards.
You may be surprised to hear the the problem got much, much worse after this
Took it for a test drive and the steering got really stiff and creaks like crazy - to the point where you can let go of the steering on a roundabout and the car carries on turning around it. Left it on the drive until today when I did the same - wheel off, degreaser, WD40 (a LOT of WD40!) , silicone grease. Creaking as loud as hell, really stiff. Out of ideas now so it's officially off road.
Checked the movement of the track rod ends and droplinks - all moving smoothly, no damage to the rubber boots. Anyone got any ideas? No way I can drive it to RR in Leeds (I wouldn't drive it any distance in this state) and would cost a fortune to get it trailered up there.
HELP!
HELP!
Sorted by Rotary Revs | RR D585 Coils | Castrol Power 1 Premix and V-Power Nitro+
Rotary Revs Gold Rebuild and Street Port
- warpc0il
- Has thanked: 822 times
- Been thanked: 3534 times
- Contact:
Your actions could have released some rust/grit from the outside of the joint and washed it inside, where it's now interfering with the movement of the bearings.
You might get away with flushing with more WD40 (or paraffin) and, if you're lucky, wash the grit back out of the bearing.
- Has thanked: 172 times
- Been thanked: 787 times
The UJ contains metal needle roller bearings. You should lubricate them with some kind of mineral based grease. I definitely would not use silicone lubricant, which is intended for rubber and plastic lubrication.
It's probably too late for your UJ so you will be needing a new one. I lubricate mine with motorcycle chain lubricant. It goes on as a liquid, but turns into a grease, and is kind to the rubber seals.
I know people say clean it with WD40, but I don't do that either. I don't want to wash out any of the grease already in there.
- Everton
My bad - I used Lithium grease, not silicone
Is it a difficult job to replace the steering UJ? From the amount of WD40 and grease it's had applied over the past two weeks and the noise it is making I suspect it is kaput
- binghamf6
- Been thanked: 25 times
you can take the joint off I would take the two bolts out of the uj but don't take it off the steering rack or shaft yet then set the wheel to straight ahead remove the ign key then turn the steering wheel until it locks (this will stop the steering from rotating when you remove the uj and damaging the clockspring for the airbag) now make a mark on the rack and the uj so you can line them up later now take the uj off , now check it for wear and if theirs any tight spots if there are try tapping it with a hammer to see if it loosen up if it does then clean off and soak it in some thin oil and leave it for a time then check it again to make its ok then grease it to death and leave it for a while check it again if ok the refit it .
Shane..
HID's + LED'S , Custom Gauge Pod , Piano Black Center Console , Later Interior , Bonnet Struts , Catch Tank
Poly Bushed Front End , Meister R Zeta S coil overs , Braided brake lines , Sohn And 2T Tank
RE-Amemiya short shifter, Show 'N' Go Front No. Plate , R3 Style starter motor.
Racing Beat Silenced de-cat and Rev 8 Cat back , Lambo Doors
Rebuilt and Ported at Hayward rotary
- Everton
Thanks for the tipsbinghamf6 wrote:you can take the joint off I would take the two bolts out of the uj but don't take it off the steering rack or shaft yet then set the wheel to straight ahead remove the ign key then turn the steering wheel until it locks (this will stop the steering from rotating when you remove the uj and damaging the clockspring for the airbag) now make a mark on the rack and the uj so you can line them up later now take the uj off , now check it for wear and if theirs any tight spots if there are try tapping it with a hammer to see if it loosen up if it does then clean off and soak it in some thin oil and leave it for a time then check it again to make its ok then grease it to death and leave it for a while check it again if ok the refit it .
Next question, how do you actually get to the joint? Not through that tiny porthole in the wheelarch I hope!?
- binghamf6
unfortunately yes I'm afraid so.
or try using some of this stuff it the mutt nuts lol
http://www.ebay.co.uk/itm/INNOTEC-DeBlo ... 0958777149
Shane..
- warpc0il
- Contact:
Yes, though taking the wheel off helps a bitEverton wrote:Next question, how do you actually get to the joint? Not through that tiny porthole in the wheelarch I hope!?
- Everton
Thanks, will give that a whirl. If it doesn't work, may have to consider my optionsbinghamf6 wrote:unfortunately yes I'm afraid so.
- Everton
Well that goes without saying reallywarpc0il wrote:Yes, though taking the wheel off helps a bitEverton wrote:Next question, how do you actually get to the joint? Not through that tiny porthole in the wheelarch I hope!?
- warpc0il
- Contact:
Re: RE: Re: Noisy Steering Wheel
You'd think so but I've seen people struggle trying to avoid removing the wheel.Everton wrote:Well that goes without saying reallywarpc0il wrote:Yes, though taking the wheel off helps a bitEverton wrote:Next question, how do you actually get to the joint? Not through that tiny porthole in the wheelarch I hope!?
The bizarre thing is that you want both front wheels up off the ground to do the job anyway.
Sent from my GT-I9195 using Tapatalk
- mrspiller
- Has thanked: 280 times
- Been thanked: 763 times
I'll second that - I thought I would be clever and used silicone grease , was ok for a bit then good a lot worse very quickly - avoid silicone grease at all costsPeteH wrote:The UJ contains metal needle roller bearings. You should lubricate them with some kind of mineral based grease. I definitely would not use silicone lubricant, which is intended for rubber and plastic lubrication.
- Everton
Thanks for the tip! Ordered some DeBlock from eBay as WD40 was doing nothing. It arrived this morning so, as I was off work, went out and gave the UJ a good spray with DeBlock and left it for 10 minutes to soak. Job done - freed up a treat and after a good coating with Lithium grease, steering is now as smooth as butter again. Not cheap at almost £15 a can but obviously very good stuff.binghamf6 wrote:unfortunately yes I'm afraid so.
- binghamf6
Glad to see you got it sorted .. you wont need the WD40 anymore lol.
Shane..
