rover fuel pump help
For reviews / technical discussions on the other car.. using the knowledge of others on the forum
Dazza44
Has thanked: 155 times
Been thanked: 70 times
Post by Dazza44 » Sat Jun 23, 2018 10:57 am
hi all
trying to fix a rover 75 for farther in law,the fuel pump isnt perging hence no fuel getting into engine,ive checked fuses/relays all good,so i decided to connect a live/and earth to battery and pump connecter and bingo all working and car starting
my question is
if i run that live/earth feed to an alternative live prefferable one that is only live with ignition on,was thinking the in car heater unit, so therefore the fuel pump will only work with car on and will switch of when turn car of
would this be safe i assume it would be, but would appreciate anyone elses views
many thanks
darren
goodeggbob
RX-8: Kuro
Colour: Kuro Black
Has thanked: 454 times
Been thanked: 655 times
Re: rover fuel pump help
Post by goodeggbob » Sat Jun 23, 2018 11:05 am
hi Daz ,the issue you would have is that god forbid an accident occured,the pump would keep running if no one could turn off ignition.is there a way you could run live to something that is cut when engine stops,not ideal as engines can keep running even after a collision,but safer than heater unit.good luck ,rob.
Dazza44
Post by Dazza44 » Sat Jun 23, 2018 11:10 am
hi rob,thanks for reply, i see your point,any ideas what cuts of when the engine stops?, im pretty useless when comes to electrics
goodeggbob
RX-8: Kuro
Colour: Kuro Black
Post by goodeggbob » Sat Jun 23, 2018 11:20 am
hi daz ,it would have to be something like the dizzy or alternator.i am no expert but maybe airbag supply?have you tried a new wire from live side of fuse or relay just to see where problem is.that would be much better if that worked without compromising safety.rob.
These users thanked the author goodeggbob for the post:
Dazza44 (Sat Jun 23, 2018 6:29 pm)
Dazza44
Post by Dazza44 » Sat Jun 23, 2018 12:18 pm
thanks rob i give that a try live feed from the fuse
rhanka for your help
Has thanked: 399 times
Been thanked: 1573 times
Post by warpc0il » Sat Jun 23, 2018 1:21 pm
It could be the crash switch that has cut power to the fuel pump.
The switch is often mounted somewhere in the front footwell and can get triggered by a random thump.
Most have a reset button.
Dazza44
Post by Dazza44 » Sat Jun 23, 2018 1:34 pm
cheers dave i will have alook for it
Post by warpc0il » Sat Jun 23, 2018 1:35 pm
It might be hidden behind a trim panel, hopefully with an access flap
Dazza44
Post by Dazza44 » Sat Jun 23, 2018 1:43 pm
silly question would it likely look like a normal switch as in on/off ?
Been thanked: 785 times
Post by PeteH » Sat Jun 23, 2018 1:48 pm
Dazza44
Post by Dazza44 » Sat Jun 23, 2018 2:02 pm
thanks pete, time to fo some hinting dor said switch goto be worth a shot
Post by PeteH » Sat Jun 23, 2018 2:45 pm
:?: :-k :-s :scratch:
Rotary Potato
Has thanked: 51 times
Been thanked: 243 times
Post by Rotary Potato » Sat Jun 23, 2018 2:51 pm
English wrote:Thanks Pete. Time for some hunting of said switch. It's got to be worth a shot.
Am I close? :lol: :lol: :lol:
These users thanked the author Rotary Potato for the post:
Dazza44 (Sat Jun 23, 2018 3:03 pm)
Huw
Dazza44
Post by Dazza44 » Sat Jun 23, 2018 3:03 pm
^^^spot on
These users thanked the author Dazza44 for the post:
Rotary Potato (Sat Jun 23, 2018 3:22 pm)
Post by warpc0il » Sat Jun 23, 2018 5:23 pm
The switch looks like this
https://www.ebay.co.uk/itm/MG-ZS-ZR-ZT- ... 1438.l2649
and is located behind the glove box, according to Google.
http://bfy.tw/Ijrd
Apparently the switch might need to be reset or there could just be a loose connection, which isn't uncommon
Dazza44 (Sat Jun 23, 2018 6:15 pm)
goodeggbob
RX-8: Kuro
Colour: Kuro Black
Post by goodeggbob » Sat Jun 23, 2018 5:49 pm
hi,glad someone can interpret dazza,it was a complete load of waffle to me.
Dazza44 (Sat Jun 23, 2018 6:27 pm)
Post by warpc0il » Sat Jun 23, 2018 6:22 pm
Many of us on here speak "Dazza", having practised on the early forms of "Aston", which was even more challenging ;)
Dazza44
Post by Dazza44 » Sat Jun 23, 2018 6:29 pm
i blame my phone honestly, i type one thing and it appears to change it to something else, well thats the reasoning im giving
Dazza44
Post by Dazza44 » Sat Jun 23, 2018 6:31 pm
havent has much chance to take alook as the wife decided we was going out for dinner(which didnt include her paying) ,but will crack on tomorrow and update
thankyou all for the help
Post by PeteH » Sat Jun 23, 2018 7:09 pm
Never change Dazza. You always make my day with your alternative English. :thumleft:
Dazza44 (Sat Jun 23, 2018 8:00 pm)
Dazza44
Post by Dazza44 » Sun Jun 24, 2018 3:58 pm
right very confused now, tryed the reset switch as suggested,car still didnt start,charged the battery and car started turned it on/off bout 5 times all good just been outside no start(cant here the pump) so decided to run a live to a feed, a car started again, turnt car off tryed restarting nothing no fuel pump priming again and thats with a contstant live feed
does anyone have any othee suggestions aa im all out of ideas
thanks
goodeggbob
RX-8: Kuro
Colour: Kuro Black
Post by goodeggbob » Sun Jun 24, 2018 4:06 pm
hi daz,sounds like an intermittent fault with pump.do you have current going to it every time you try to start thru the original wiring.if yes it must be the pump itself.daft idea but try tapping pump with something ,you never know ,rob.
Dazza44 (Sun Jun 24, 2018 8:24 pm)
Post by warpc0il » Sun Jun 24, 2018 7:22 pm
Connect a bulb temporarily across the pump connections so you can if/when there is and isn't power
Dazza44
Post by Dazza44 » Sun Jun 24, 2018 7:35 pm
dave,do u mean like a 12volt bult run the wires to the bulb and to the live/earth of the fuel pump?
Post by warpc0il » Sun Jun 24, 2018 9:26 pm
Yep, so you have an "at a glance" indication.
Just make sure that the bulb's not going to burn/melt anything.
Dazza44 (Sun Jun 24, 2018 9:28 pm)
Return to “The Other Car..”
