1st Time Rotary Owner - South Wales
smash
Colour: Metropolitan Grey
Post by smash »
Hi All,
Just thought I'd introduce myself as I'm now a member of the RX8 community having recently purchased a 40th anniversary edition RX8 from one of the members on here (Horsey1642). The car seems to be a good one which has been well looked after and includes plenty of service history. It's pretty much stock, apart from a Bilstein B12 suspension kit, de-cat and uprated coils / leads.
I've had quite a few performance cars over my past 14 years of driving, but decided it was time to finally join the rotary club :) I'm looking forward to getting some good use out of the car this summer with a few track days thrown in to test its full potential.
My plans for the car are quite basic at the moment, although this will more than likely change, as they do with any project car :D
These users thanked the author smash for the post (total 3):
nightfire10 (Tue May 03, 2022 9:45 pm) • casey (Tue May 03, 2022 10:17 pm) • wreeve (Wed May 04, 2022 8:37 pm)
Has thanked: 1581 times
Been thanked: 365 times
Post by GreySilver Beast »
Hi & :welcome: to the RX-8OC :thumleft:
smash (Wed May 04, 2022 10:10 pm)
Conan
Has thanked: 26 times
Been thanked: 310 times
Re: 1st Time Rotary Owner - South Wales
Post by Conan »
Hi Smash and welcome to the club
There’s a few rotaries in South Wales who also do track days, I’m sure you’ll meet them soon
Nice car you have there 👍
Has thanked: 266 times
Been thanked: 320 times
Post by Shagrington »
Hi and :welcome: smash. :D Have a good read through whatever in the FAQ section you didn't already read :study: and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
2. Never [-X turn off the engine before it has reached at least somewhere towards normal operating temperature (should only take a minute or two, but best to go for a short drive if just swapping cars round on the drive etc). Switching off cold risks flooding, which is a real :censored: with a rotary engine. Mazda recommend rev to 4k and hold it for 8-10 seconds switching off while still revving if you have no option but to switch off cold (it is not necessary to do this in any other circumstance).
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it :twisted: and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great. ;)
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but have been starting up again recently) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more. :thumright:
