New Owner :D
- Been thanked: 12 times
New Owner :D
Update - I bought her!
Hello everyone, my name is Nadja and I'm up in NE Scotland. Going to be viewing an 40ae tomorrow and everything sounds good on paper, so might be a new first time owner.
My biggest question, are there any nice little kits for premixing available? Where I can just pre measure and have it ready for as and when?
I've been reading the guides and such for purchasing one. But my big problem is, I can't drive legally yet (I'm 29 but a late bloomer with learning okay ), would it be cheeky to ask the current owner to take me for a short drive? And just listen to knocking (if any) where and when?
My plan is to love and cherish this car, so definitely not going to just grab a nice condition car and burn it to the ground.
Anyway, hope to be part of your club properly soon
- Been thanked: 229 times
Re: About to possibly buy one :D
The buyers guide is quite comprehensive but don`t you know a qualified driver preferably someone with some mechanical knowledge that can test drive the car for you as it is a bit of a risk for you without either, premixing just needs a liquid measure of some sort, I keep a bottle in the boot which is marked for the correct amount to premix which I add to the tank before the petrol, its easy enough.
Thank you for the welcome . Only one who's available will just try to talk me out of it because *rotary*. So probably will be negative from the onset.
Unless there's someone magically available tomorrow before noon in Aberdeenshire
Hi & to the RX-8OC
Please update your location here
- Has thanked: 568 times
- Been thanked: 526 times
For premix kits, the main one i know of is rotary bum. Have one myself as it came with the car (old style narrow neck ones though) - they're not cheap for what they are though... Ultimately, any of those travel liquid bottles will do - doesn't have to be anything fancy to do the job
Its a bit short notice but you could try "hachiroku" a member in Aberdeen - use the search in top right corner to pm/email him.
- Has thanked: 99 times
- Been thanked: 59 times
Hi, yes I just got your email, not sure how to reply though!
Unfortunately I'm down in Glasgow tomorrow, or else I'd have been happy to help out.
Have you got a link to, or a photo of the advert? Don't think I've noticed another 40th for sale locally?
As already mentioned, read through the buyers guide on here.
When I bought mine (from a forum member) he took me for a drive in it as I wasn't insured to drive it. I'd owned an rx8 before so I kind of knew how it "should" drive though. If you know someone, anyone, who drives and could go with you then that may help.
Ultimately though buying any second hand car is a bit of a gamble.
Check for rust, especially the rear sills. Expect some underbody rust, it's an old car after all.
Check the MOT history online, see if there's previous Fails or advisories for rust.
Recent rotary compression test results are ideal, otherwise after it's been driven ask the seller to start it up after it's been sat 10minutes or so, if it takes more than a few seconds to fire up it "may" have low compression issues. I never saw compression test results for the RX8's I've bought, the 1st had it's engine still under warranty, and the 40th the seller did the above and it fired right up.
Don't be afraid to say "thanks for your time, but it's not the car for me at the moment", there's other cars out there, don't feel obliged to buy it if you're not sure of it.
If you do plan to buy it then haggle on the price, in a friendly way, even a few hundred quid off is better off in your pocket (especially with current fuel prices!).
I'll send you a private message with my number, if you have WhatsApp etc you can message me any other questions.
Oh, and for premixing I bought some sauce bottles from ebay they have a nozzle and a cap, I fill it up and squeeze the required amount into the tank when I fill up. I keep a litre bottle of 2-stroke oil, and a bottle of engine oil in the boot at all times.
You'll get used to it
- Has thanked: 515 times
- Been thanked: 172 times
One other suggestion for premix, which I think originally came from a user called ChrisHolmes, is to keep some 100ml bottles that you get for airway travel with the premix ready. I keep some in my passenger door, with a small funnel.
- These users thanked the author v-rex for the post:
- ChrisHolmes (Mon Apr 11, 2022 7:51 pm)
Just keep a litre bottle a a good squirt every fill up
Thanks guys will let you know later today if she's mine. Love the idea of the tiny travel bottles though, they're so cute
I got her!
Just not sure how to attach images
- These users thanked the author na69dja for the post:
- ChrisHolmes (Mon Apr 11, 2022 7:52 pm)
- Has thanked: 147 times
- Been thanked: 287 times
Use a big syringe from a pharmacy for a few quid,job doneHarSc wrote: ↑Fri Apr 08, 2022 5:05 pm
Just buy one of these I use Idemetsu Racing Rotary Premix From Essex Rotary
Hi and na69dja and congratulations on your new passion.
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but have been starting up again recently) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Hi Nadja, Welcome to the club - Congratulations on your new acquisition and thanks for joining as a full member.
You should have options to add pictures directly on the forum now too.
- na69dja (Mon Apr 11, 2022 6:33 pm)
As the original poster you can edit the first post in this thread, including the Subject, if you wish...
https://www.rx8ownersclub.co.uk/forum/p ... &p=1363554
- na69dja (Mon Apr 11, 2022 6:32 pm)
Re: New Owner :D
Just need to start looking at insurance but here she is.
- These users thanked the author na69dja for the post (total 6):
- GreySilver Beast (Mon Apr 11, 2022 6:38 pm) • nightfire10 (Mon Apr 11, 2022 7:01 pm) • ChrisHolmes (Mon Apr 11, 2022 7:52 pm) • Nanotrox (Mon Apr 11, 2022 8:01 pm) • v-rex (Mon Apr 11, 2022 8:02 pm) • Viperous (Tue Apr 12, 2022 7:43 pm)
Nadja | 40AE #61
- Sponsor Trader
Re: New Owner :D
Hi.
If you need any help with insurance at all then please feel free to drop me a line.
Regards,
Dan.
Regards,
Dan.
