Hi Guys,
I bought an R3 at the start of the year.
Loving the looks and sound. Its got a Toyo catted downpipe, but I think its shot as I'm getting P0420. But it did pass its MOT in Dec, so it maybe ok.
Not as quick as I was expecting, as my previous car was a Gen 1 MPS running an SRI and TIP with a remap. Probably about 280bhp.
Only mod planned is to remove the Toyo and get a decat fitted. I was looking at the RB twin resonated one, but thought you could get one made a exhaust specialist for a lot less.
New rotary owner from Inverness
- Been thanked: 8 times
Hi & to the RX-8OC
Re: New rotary owner from Inverness
Sorry for the MPS speak
SRI - Short Ram Intake (basically the cone air filter)
TIP - Turbo Inlet Pipe (from air filter)
I understand my old Mazda 3 MPS MKII is still in the MPSOC
- Has thanked: 23 times
- Been thanked: 32 times
A Gen 1 MPS will feel much faster down to the torque and also being a minimum of 60bhp up on the best RX8's. Mines running about 320bhp (fully bolted CST4 and being mapped at the moment).
RX8 will handle better, feels lighter, sounds better and has suicide doors.
They are completely different feeling cars that is for sure.
Mazda RX8 R3 - Aurora Blue
Mini Cooper S - Dark Silver
- Been thanked: 453 times
to the whacky world of the wankel
A few of us RX-8 owners had some fun on track with a group of MPS's at Castle Combe in 2014, at Japfest, when the original Top Gear trio turned up and came out with us in 3 non-japanese cars . It was fun overtaking the trio 2 or 3 times in one 15 minute session and the RX-8's surprised the MPS guys with their superior handling and speed through the corners. That's my RX-8 in the pic.
Found a link to that event: https://www.rx8ownersclub.co.uk/forum/v ... &t=58057&p
- GreySilver Beast (Tue Feb 01, 2022 7:41 pm)
Hi and alisdairm. I suspect you really don't need these, but just in case - have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it although with the R3 your redline rises with the coolant temp, I think the above is still good advice as it gives the oil time to warm up too) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
Thanks for joining the club which also saves me including tip number 5
- alisdairm (Mon Feb 21, 2022 9:16 am)
- Been thanked: 169 times
We do one at Ryan Rotary Performance, will be updating the website soonalisdairm wrote: ↑Tue Feb 01, 2022 3:21 pmHi Guys,
- Has thanked: 170 times
- Been thanked: 115 times
I was actually looking at emailing RRP to see if you do a dual res decat do you know how much you'd be selling them for?
Also welcome Alisdairm! the car is honestly not the fastest thing in the world especially compared to modern cars but it comes into a league of its own on backroads and the high revs are very addictive
Lightened and balanced rotors
Pettit Catback
Exedy Clutch
CC Ultra Lightweight Flywheel
CC Counterweight
Tein S.Tech Lowering Springs
Racing Beat Ram Air Intake
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Sure,Nanotrox wrote: ↑Fri Feb 18, 2022 3:27 pmI was actually looking at emailing RRP to see if you do a dual res decat do you know how much you'd be selling them for?
We can do dual resonated for £450
Resonator & muffled for £530
Neither has a O2 boss, we can put one in but you'll need to extend the wiring on the sensor.
- These users thanked the author MadTaz for the post:
- Nanotrox (Fri Feb 18, 2022 3:58 pm)
