Lumpy tickover and stalls
RX8telford
Forum Guest
Forum Guest
Colour: Kuro Black
Post by RX8telford »
Hi all, I’m new to the forum.
I have a 55 plate RX8 231 that is really lumpy on tick over when warm unless I hold the revs at 1500rpm. If I leave to idle it will stall this happens only when warmed up any ideas?
Has thanked: 1581 times
Been thanked: 365 times
Post by GreySilver Beast »
Mod Bit : Moved here as it's your first post :thumleft:
Hi & :welcome: to the RX-8OC :thumleft:
<<<<<<<<<<<<<< Please post your location here :thumleft:
PaulAV
Has thanked: 175 times
Been thanked: 524 times
Re: Lumpy tickover and stalls
Post by PaulAV »
First things first, clean your maf sensor and your eccentric shaft sensor then do a battery disconnect reset from cold, start the car and allow to idle up to temperature without touching the accelerator(about 20 minutes) if it doesn't improve then start looking at the ignition system and look for vacuum leaks. If you have a scanner you could look at the air fuel ratios and the long and short term fuel trims these could lead you to a vacuum leak if they are showing lean running. When were the coils, plugs and leads last replaced?
RX8telford
Forum Guest
Forum Guest
Colour: Kuro Black
Not replaced them for about 15000miles?
PaulAV
Post by PaulAV »
They should still be serviceable still then, start with the sensors and check for vacuum leaks as I already mentioned
Has thanked: 442 times
Been thanked: 2089 times
Does the tick over get any smoother with the clutch pedal down?
If so, the neutral switch on the gearbox has an issue.
Does the tick over change with a/c off?
Failed engine mounts are the most common cause of shudder on tick over.
PaulAV
Post by PaulAV »
It's not uncommon for the engine mounts to collapse, this can cause the engine to move more uneven and more vibration than standard
Has thanked: 29 times
Been thanked: 332 times
Post by 350matt »
a collasped mount shouldn't produce a stall though
my money is on a dirty MAF and an idle relearn required
Has thanked: 266 times
Been thanked: 320 times
Post by Shagrington »
Hi and :welcome: RX8telford. :)
