I'll be picking up my S1 on Friday and am a tad excited to say the least. I've done all my buyer research, having owned one in 2016 (and learnt about the joys of rotary engines) so have not rushed into buying but having found the right one, I'm very much looking forward to picking her up and driving her home.
Mid life crisis?
Maybe but I've not felt this excited at 'xmas' time since I was a kid!
Am sure you all have fond memories of your maiden drives in an 8 so any do's and don'ts would be much appreciated...
Two more sleeps to go
- Has thanked: 46 times
- Been thanked: 58 times
- These users thanked the author Magsrx8 for the post (total 4):
- New Duke (Thu Dec 09, 2021 1:40 am) • casey (Thu Dec 09, 2021 7:41 am) • njkmr (Thu Dec 09, 2021 8:25 am) • wreeve (Sat Dec 11, 2021 4:36 pm)
Re: Two more sleeps to go
Do drive in one gear lower than normal.
Do try not to grin like an idiot when you see your reflection in shop windows.
Thanks Dave, I'll bear that in mind but make no guarantees about not grinning like an idiot I'm afraid.
Don't worry about when to change gear ;you'll hear a BEEP telling you it's ready for the next gear
Exciting I'm not sure how much use you got from your last one, so I'll post my usual ... Have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but have been starting up again recently) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- Been thanked: 35 times
Do try to get the engine over 6500 RPM on a reasonably regular basis, it will thank you for it in the long run.
Try your hardest not to grin like a loon when you first hit the beep in second gear. You'll fail, because we all did (still do if we're honest), but it's rude not to try.
Also don't beep it until it's up to temperature. Takes about 15-20 minutes to get to the proper temperature for that sort of thing, but it's worth the wait.
- 30405 (Fri Dec 10, 2021 10:19 am)
Thanks Shag & Sam, that's very handy.
I've picked her up and driven the 130 miles home and she was absolutely awesome, although I didn't see many reflections to gauge my grin size so will have to try harder.
Will post up some pics etc once I've given her a good detailed clean but am in love already. Reckon I've got an absolute bargain too looking at the rest of the market but may pick some OC brains re insurance valuation, as the mileage is ridiculously low and it's in mint condition.
Loving the beeps too, felt like roadrunner around a load of wiley coyotes!
- These users thanked the author Magsrx8 for the post (total 2):
- HarSc (Fri Dec 10, 2021 6:14 pm) • Shagrington (Fri Dec 10, 2021 10:33 pm)
- Has thanked: 569 times
- Been thanked: 526 times
Awesome to hear! Definitely get some pics up too - us lot on here rather enjoy looking at new buys and what 8's are out there in good hands
So had the car for a day now and am absolutely loving it, starts on a button, purrs like...a rotary engine does...and drives beautifully. One happy chappy right here.
The only fault I've found so far is the clock wasn't right as hadn't taken daylight savings into account lol
How many miles
She had 10,589 genuine miles on the clock when I collected her yesterday.
- HarSc (Sat Dec 11, 2021 11:50 pm) • nightfire10 (Sun Dec 12, 2021 4:06 am)
She's a great find, especially when I see the price that BostonRotary is selling his blue one for, as it has comparable mileage to mine. Xmas came early this year for sure.
- These users thanked the author Magsrx8 for the post:
- BigPete (Mon Dec 13, 2021 5:23 pm)
- Been thanked: 229 times
17 years later and it still happens to me - a hopeless case I`m afraid!
