Hi new car, new Member
- Has thanked: 15 times
New to me, a 06 231, read watched many 8 buyers guides
I took the plunge on this 59K car with full service history, no MOT failures, cleanest underside minimal cosmetic corrosion on suspension in the bargain low end price bracket I could afford.
Car originally a Bristol area then Yeovil Somerset, 1 year in Leicester area, I got from trader in London bought sold as seen, jumped in the deep end.
Super happy with it,
ASAP I’ve done
Miller’s 10w/40 wix filter
NGK iridium plugs
Air filter
Premixing (not sure on past owners)
Today just replaced RR Coils with RRP Coils
Intermittent surge (P0302) code gone, running great now
Next full coolant flush, Tran & Axle oil
Then probably Tein Struts + 17 x 9.5 wheels
After next MOT in Jan plan decat japspeed full system as I know having a cat is a major heat back pressure issue
Don’t plan too many mods just enough to improve and sharpen its focus for fun drivers car
- Been thanked: 452 times
Re: Hi new car, new Member
Hi and to the wonderful, whacky world of the wankel
It looks like you've been doing your homework, given the list of things you've done already and have planned - well done
And, you've bought the best and fastest colour too
- srenguk (Mon Nov 22, 2021 7:01 pm)
Hi & to the RX-8OC
- srenguk (Tue Nov 23, 2021 6:45 am)
- RX-8: Nemesis
- Has thanked: 48 times
- Been thanked: 61 times
Welcome to the asylum.. lots of helpful folk in here. If you get stuck, it won't be for long.
Sent from my Phone 2 using Tapatalk
- These users thanked the author Calcifur83 for the post:
Gordon
.....Loading.....
Petit Racing Modular Exhaust
Tein S Lower Springs
K&N Hi-Flow Air Filter
.....Loading.....
- Has thanked: 568 times
- Been thanked: 526 times
Awesome to see yet another 8 being taken care of! As said above, you're definitely cracking on with the right jobs on it! Looks good
Hi and srenguk. Have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already - it looks like you've already done all the reading ) here are my best tips for keeping it all running sweetly:
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but have been starting up again recently) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- srenguk (Wed Nov 24, 2021 6:33 am)
- Has thanked: 99 times
- Been thanked: 9 times
Welcome looks nice & clean
- These users thanked the author YORKSHIRE777 for the post:
- srenguk (Wed Nov 24, 2021 9:56 am)
