Hello everyone, just bought an R3 so looking forward to using these forums! After considering a Z4 and 135i (I used to own a few BMW's) I figured I should stick to Japanese only and now own the R3 alongside my Lexus LS400.
Going to take it to the performance shop at some point for a quick oil change and possibly MOT.
New r3 owner
- Been thanked: 3 times
New r3 owner
- These users thanked the author Ken90s for the post:
- Luke0611 (Sat Nov 06, 2021 9:16 pm)
New r3 owner
Hi Ken & to the RX-8OC
Re: New r3 owner
Hi and Ken90s. They'll look after you at TPS
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it although with the R3 you have a red line that rises with the water temperature I think this is still good advice as the oil will take longer to reach full temperature - and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but have been starting up again recently) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- Has thanked: 568 times
- Been thanked: 525 times
Re: New r3 owner
Good choice on the R3, best one out there (I'm not biased, promise ) definitely get some photos up though, we all love a good pic on here ha!
I've been making a register of R3's that we know of and currently have over 360 cars out of the 800 made here. If it's ok with you, let me know your plate and I can add it to the list
