Hi everyone!
First time owner here; but have spent a loooong time wanting an 8 - meaning I've done a fair amount of research, what to look for and how to care for one. With the rising prices, what seems to be decreasing numbers, and for the first time in a while being able to actually afford to buy and run an 8 - I pulled the trigger last weekend.
I'm now the proud owner of a 56 plate PZ in Brilliant Black, (No 409 according to the site that used to hold the list). Good MOT and service history. Overall pretty clean, some carpark dents here and there, but as far as I could see fairly minimal rust, couple of bubbles on arches but thankfully not much more.
I've already got rust converter (arrived today) thanks to the forum posts for which to go for, planning on getting a better look at it this weekend and to start coating what is there ready for winter.
Sadly - shes missing her OZ alloys, otherwise all the usual PZ parts are there, most happy about the backbox being present
Once my membership gets approved - I'll throw some photos up
EDIT: adding the pictures in
Last one is the worst bit of rust I've seen so far.
Jordan
RX8 newbie here
RX8 newbie here
Last edited by FuelledByJordan on Fri Oct 15, 2021 7:27 pm, edited 1 time in total.
RX8 newbie here
Hi Jordan & to the RX-8OC
- FuelledByJordan (Fri Oct 15, 2021 7:19 pm)
Re: RX8 newbie here
Hi Jordan, welcome to the club and I hope to see you at our monthly “Allsorts” meet 2nd Thursday of each month. Just search Allsorts on here for full details or follow Nigel’s Events link above.
Which bit of Gloucestershire are you in?
Re: RX8 newbie here
Hi and FuelledByJordan. It sounds like you won't need this, but have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
It also sounds like you've pre-empted my tip #5 to join the club Your status should be upgraded so you'll have full access to the rest of the forum as soon as someone with access to the right buttons sees your application.
Re: RX8 newbie here
Hi Jordan, and welcome to the club. Thanks for joining - you're fully active now so you should be able to share those pics with us all.
Re: RX8 newbie here
Thanks everyone for the warm welcome
I'll do my best to come along and actually from the same neck of the woods as you Chris!ChrisHolmes wrote: ↑Thu Oct 14, 2021 11:44 pmHi Jordan, welcome to the club and I hope to see you at our monthly “Allsorts” meet 2nd Thursday of each month. Just search Allsorts on here for full details or follow Nigel’s Events link above.
- These users thanked the author FuelledByJordan for the post:
- ChrisHolmes (Fri Oct 15, 2021 7:22 pm)
Re: RX8 newbie here
If you need any help with anything let me know.
Re: RX8 newbie here
Thank you! I appreciate the offer I'm sure down the line I will take you up on it, vice versa too, more than happy to help where I can
