New Forum, New Car!
- Has thanked: 14 times
New Forum, New Car!
Afternoon all,
I'm new to the forums and the world of RX8s. I put off buying one for too long, falling pray to the "horror" stories out there and arguing that they were too impractical, but I'm now at a point where I don't do as many miles, the wife has a nice comfy SUV thing, so I can have my RX8 :-)
After researching for what seems like forever, I've finally taken the plunge and bought a 2008 231 in Stormy Blue. She didn't miss a beat on the near 200 mile drive home with her yesterday so hopefully that's a good sign!
One question I have, I don't know 100% what oil brand is currently in the car. I know it's got 5w30 in it and the garage I bought it off has recommended upping to 10w40 on the next change. But for now, can I top up with any of the recommended 5w30s? Does potentially mixing brands matter for instance?
Ta!
Dom
Ta!
Dom
- Been thanked: 229 times
Re: New Forum, New Car!
and congrat`s on your new acquisition.
Have a read up on the Buyers Guide if you haven`t already its up there ^^^^^ on the header.
Without going into too much detail with regard to "the correct oil" read up here Oil101 for newbies and go by that for now.
Then when time suits change to 10w-40 as recommended.
- DomN (Fri Sep 24, 2021 4:44 pm)
Hi Dom and welcome to the forum. I'm sure the usual welcoming committee will be along shortly, but in the meantime my (non-professional) understanding is you should be fine using any of the standard mineral oils - no reason you couldn't top up with e.g. Millers 10/40 even if it's currently full of XYZ 5/30 - it'll just make what's in it already a bit 'thicker' (like maybe 6/32 if you added a whole litre).
edit: What Del said.
- Has thanked: 147 times
- Been thanked: 287 times
Change the oil ( double flush ) for millers 10-40 semi synthetic,it's a top quality oil that I have used for years on my 8 without issue.Rotary Revs use it so if it's good enough for them....
I'd also consider new coils if you're unsure of the ones that are currently on her,Ryan Rotary Performance do a top quality product.If it was me i'd change every fluid in the car just for peace of mind but also just because its good practice.Don't know what the tyres are like but if they aren't a top brand i can personally recommend Vredestein Vorti's but other people will also recommend top quality tyres also.
That should keep you busy for a bit
- These users thanked the author kopite72 for the post (total 2):
- DomN (Fri Sep 24, 2021 4:45 pm) • YORKSHIRE777 (Fri Sep 24, 2021 4:48 pm)
New Forum, New Car!
Hi Dom & to the RX-8OC
- DomN (Fri Sep 24, 2021 4:47 pm)
Thanks all,
Tyre change is on the cards as it's got cheapo Chinese ones on at the mo. It has had new coils and leads, I forget what the guy said they were tho!
Great info on that oil page etc and thanks for clarifying the top up situation. For some reason I had in my head that you shouldn't mix oils etc but that could have been back in my ford Capri days
Sent from my Pixel 4 XL using Tapatalk
- Has thanked: 99 times
- Been thanked: 9 times
Welcome drive it and forget the horror story's enjoy
- These users thanked the author YORKSHIRE777 for the post:
- DomN (Fri Sep 24, 2021 4:49 pm)
It is difficult spending if you think its not needed but if the previous owner has fitted cheap Chinese tyres then chances are that its the same for the ignition components and if your Rotary is misfiring its difficult to tell and any unburnt fuel washes the seal oil lubricant away and whilst you will get away with it to a certain extent in a piston engine you won`t with a Rotary and worn seals means low compression which will eventually force an expensive rebuild.
For eg. eBay cheapies Β£40 ignition coils whilst a quality set of OE Mazda coils = Β£300+ with other makes in between!
Better to be safe than sorry.
Cheers Del,
The car actually had some Falkens on it but I got the garage to swap the wheels for me as part of the sale, the Falkens were nearly dead (on the wear line) and on really kerbed wheels and the fresh refurbed ones had the Chinese tyres. So went for the nicer wheels with the idea of swapping tyres soonish.
He did tell me what coils were in it, wanna say they're the D585s? With magnacor leads.
I'll get out there at the weekend and have a look as like you say, don't mind springing for stuff like that which will provide longevity if it's needed
If they are D585`s that is a conversion kit and Magnecor leads will do nicely to go with them.
- Has thanked: 176 times
- Been thanked: 324 times
Just to clear it up, the guy said he fitted a set of good used Revision C coils with Magnecor leads as the car was still running its originals (which tbf were working pretty well)
- DomN (Fri Sep 24, 2021 8:59 pm)
That was it! Rev cs. Thanks Nick
- These users thanked the author DomN for the post:
- Nickp47 (Fri Sep 24, 2021 9:12 pm)
Hi and DomN. Looks very nice
3. Check the oil level regularly (use the dipstick - the oil gauge tells you nothing other than that you have or don't have pressure) and top up if necessary with semi synthetic 5w30 (most people and specialists are advising to use 10w40 now though) ... small amounts at a time, no more than Β½ a litre then check the level again before adding more as you don't want to overfill it.
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3Β½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but have been starting up again recently) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- These users thanked the author Shagrington for the post (total 2):
- DomN (Sat Sep 25, 2021 8:45 am) • Koren (Sat Sep 25, 2021 9:42 pm)
- Been thanked: 452 times
to the wonderfully whacky world of the wankel
- Has thanked: 34 times
- Been thanked: 40 times
When I was younger people always slated these cars off saying they're unreliable etc but out of all the cars I've owned since I started driving, the rx8 engine had given me the least grief.
Don't listen to the nay-sayers and enjoy it.
This forum has plenty of information to help you and we are a knowledgable and helpful bunch.
- Has thanked: 112 times
- Been thanked: 25 times
Been meaning to ask, what happens if you start it before the lights go out? I'm sure I've done it a couple of time sin absent minded impatienceShagrington wrote: βSat Sep 25, 2021 1:31 am1. To start up turn the key to position 2, wait for most of the lights on the dash to go out (I watch the airbag light by the glove box), press the clutch to the floor (optional, but reduces drag), turn the key to start and do not touch the throttle until it has started. You can drive off straight away, just keep the revs down for a bit (see #4 below).
Mine is less reliable than my friend's Citroen. But on the plus side at least I don't have to drive a CitroenPaul_13 wrote: βSat Sep 25, 2021 9:23 pmWhen I was younger people always slated these cars off saying they're unreliable etc but out of all the cars I've owned since I started driving, the rx8 engine had given me the least grief.
Oh no not a capri driver https://photos.app.goo.gl/Gsr8yuYkm6SKyvts6 Welcome to the forum!DomN wrote: βFri Sep 24, 2021 4:47 pmThanks all,
- These users thanked the author Koren for the post:
- DomN (Sat Sep 25, 2021 11:28 pm)
I'm a Peugeot convert to JDMKoren wrote: βSat Sep 25, 2021 9:47 pmBeen meaning to ask, what happens if you start it before the lights go out? I'm sure I've done it a couple of time sin absent minded impatienceShagrington wrote: βSat Sep 25, 2021 1:31 am1. To start up turn the key to position 2, wait for most of the lights on the dash to go out (I watch the airbag light by the glove box), press the clutch to the floor (optional, but reduces drag), turn the key to start and do not touch the throttle until it has started. You can drive off straight away, just keep the revs down for a bit (see #4 below).
- These users thanked the author Paul_13 for the post:
- Koren (Sun Sep 26, 2021 2:16 am)
More often than not - nothing. It is doing all the "pre-flight" checks on the electronics etc, so maybe the display won't work properly or something. I expect there are other possibilitiesKoren wrote: βSat Sep 25, 2021 9:47 pmBeen meaning to ask, what happens if you start it before the lights go out? I'm sure I've done it a couple of time sin absent minded impatienceShagrington wrote: βSat Sep 25, 2021 1:31 am1. To start up turn the key to position 2, wait for most of the lights on the dash to go out (I watch the airbag light by the glove box), press the clutch to the floor (optional, but reduces drag), turn the key to start and do not touch the throttle until it has started. You can drive off straight away, just keep the revs down for a bit (see #4 below).
Hi DomN - thanks for joining as a full member. Official welcome email and welcome pack to follow soon!
- DomN (Sun Oct 03, 2021 10:50 am)
