Hello everyone. I just bought my first one of dreamed RX-8
I'm open to any advise in the future.
Thank you for such a warm welcome
Hello everyone...
- Been thanked: 14 times
Hello everyone...
- These users thanked the author Peterovicz for the post (total 5):
- 30405 (Sat Sep 18, 2021 11:14 pm) • GreySilver Beast (Sat Sep 18, 2021 11:15 pm) • v-rex (Sun Sep 19, 2021 4:13 am) • New Duke (Sun Sep 19, 2021 10:48 pm) • ChrisHolmes (Sun Sep 19, 2021 11:10 pm)
Hello everyone...
Hi & to the RX-8OC
- Been thanked: 310 times
- Been thanked: 229 times
Re: Hello everyone...
Nice to see another Coventrian owner - where about in Cov` are you?
Hi and Peterovicz. Have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but have been starting up again recently) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- Has thanked: 508 times
- Been thanked: 453 times
to the wonderfully whacky world of the wankel
