Hi everyone, bought my first rotary yesterday. 2004 RX8. Very excited - as you should be.
Test drove it a couple of days ago - all seemed fine.
Picked it up yesterday (from a private buyer) and within 5 mins the engine light came on - P2270 and P2096 codes.
I’m lookin for a list of relays - the ST relay under the bonnet fuse box is broken (plastic top smashed) so no idea what type it is to replace !!
Just trawling though the site for some help….
Anyhow. Previously owned an MR2 Turbo, and I’m hoping once I sort out the above stuff, I’ll have just as much fun in it.
Newbie owner - trouble already !!
Hi & to the RX-8OC
- Judderman (Wed Jul 21, 2021 6:05 am)
- RX-8: Nemesis
- Has thanked: 47 times
- Been thanked: 59 times
Re: Newbie owner - trouble already !!
Hi and welcome.
I have just googled those codes and here are the results...
P2270
P2096
I am not an expert by any means, but I would check the O2 sensor in your exhaust. The way I work these out is to search both codes and then find something common to them both. In this case, the O2 sensor seems to be the common denominator. Could just need a good run if it's been standing for a while.
Good luck, there will be someone who knows more than me alone in no time to help.
P2270
P2096
- These users thanked the author Calcifur83 for the post:
Gordon
.....Loading.....
Petit Racing Modular Exhaust
Tein S Lower Springs
K&N Hi-Flow Air Filter
.....Loading.....
- Been thanked: 550 times
- Calcifur83 (Tue Jul 20, 2021 2:55 pm) • Judderman (Wed Jul 21, 2021 6:06 am)
- Has thanked: 112 times
- Been thanked: 25 times
When I bought my rx8, it was decat, but the previous owner neglected to mention!
- These users thanked the author Koren for the post:
- Has thanked: 173 times
- Been thanked: 172 times
Yeah faulty rear O2 sensor, just replace it
- Judderman (Wed Jul 21, 2021 6:06 am)
Hi and Judderman. Hopefully you'll get your codes sorted quick and easy. When that's done - have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they were all postponed but are beginning to happen again now) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- Has thanked: 44 times
- Been thanked: 29 times
Thanks everyone for you’re advice etc, very much appreciated
I reset the ECU yesterday, and took it out - no faults back so far
Wanted a bit of a project car - and i deffo seem to have got one !
Cheers
Cheers
- These users thanked the author Judderman for the post:
- Calcifur83 (Wed Jul 21, 2021 8:09 am)
- RX-8: Nemesis
Good news! I think the RX8 makes a great project car, and there is plenty of information here and elsewhere on the net to help out. Don't believe the name sayers, these car are fantastic, if your a car guy/gal, if you just want a car you can drive and forget about, it's not for you! LOL
Gordon
.....Loading.....
.....Loading.....
