Hi everyone.
I've just bought a Nordic green 2005 RX8 192 from a friend who decided he didn't need 2 cars any more. It's been stood since the start of lockdown in March last year, so needs a bit of attention to get it up and running again.
I wasn't actually looking for another car (I already have an MX-5 which has become a bit of a project car) so it was a bit of an impulse purchase. Time will tell whether I made a good decision but it was cheap enough that I won't be out of pocket even if I have to give up and break it for parts! Hopefully it won't come to that.
So far it needs a binding front caliper sorted plus a leaking oil pipe at the front left oil cooler.
My plan is to sort the oil leak and front brakes then get it through an MOT before I decide whether to spend money on doing some other jobs on it, like sorting a couple of bits of rust.
The good news is that it starts quickly from cold and hot and all the electrics work, including the ice cold climate control.
Next thing on my list is to join as a member before I get into buying parts and needing some mechanical advice
I'll post some photos once I've worked out somewhere to host them.
New owner - Nordic Green 192
- Been thanked: 2080 times
Re: New owner - Nordic Green 192
Join as a member and you can attach photos directly, no host required.
The rest of the wagon will be along soon...
- RussB (Sun Jun 27, 2021 1:38 pm)
- Has thanked: 13 times
- Been thanked: 8 times
Thanks. I've just signed up, so as soon as that takes effect I'll get the phots up
- Been thanked: 323 times
Welcome, fingers crossed you don’t break it with Nordic Green being a rare colour . Starting from hot is a good sign at least
- Been thanked: 451 times
- hopefully you'll be able to get it back on the road
Hi Russ & to the RX-8OC
Nordic green is a lovely colour and seems to suit the RX8 really well.
Looking forward to seeing some photo’s.
Hi and RussB. Stainless steel braided oil cooler pipes (I got mine from Mazda Rotary Parts/Racing Beat Europe) are a sound investment as a replacement for your leaky ones if you are keeping the car.
It sounds like you have pre-empted my 5th (and most important) tip to join the club ... you should be upgraded and get access to everywhere before long, but it is a manual process so it does need someone with access to all the right buttons to get away from work, family and so on.
- These users thanked the author Shagrington for the post (total 2):
- RussB (Mon Jun 28, 2021 9:46 pm) • Torque23 (Tue Jul 06, 2021 3:26 pm)
Thanks. I'm keen to get the car sorted and keep it for a bit, but trying not to get too carried away with spending before I've confirmed it's solid enough to get through the MOT without too much bother.
I've been reading the FAQ a fair bit since agreeing to buy it. Fortunately the previous owner was pretty hot on keeping the oil topped up and it even came with a full bottle of Fuchs 5w30 in the boot. I've ordered some 10w40 from Opie Oils ready to refill once I've sorted the oil leak.
Looking forward to being upgraded and getting to dig into more of the technical detail (and add some pictures).
Some photos for you of how it looks now it's had a bit of a clean. I'll probably start a thread elsewhere to show what I've done so far.
It's currently in the air so I can take the front offside caliper off to try and free it up and to inspect which oil cooler pipe is leaking, but I hurt my back on Sunday so I've had to leave it for a couple of days. The bolts are all soaked in penetrating fluid though...
- These users thanked the author RussB for the post (total 4):
- Ainmhidh (Tue Jun 29, 2021 9:54 pm) • GreySilver Beast (Tue Jun 29, 2021 9:59 pm) • Nickp47 (Tue Jun 29, 2021 10:02 pm) • HarSc (Wed Jun 30, 2021 10:32 am)
