Hi folks.
I'm Rich and have joined rotary ownership after purchasing a 55 plate 192 RX8. It's a car that I've always wanted but shied away from somewhat given their reputation! That said... after three weeks, I'm loving it!
It had a comp test done before I bought it and read 7.9-8.0 on each rotor and had only done 31,500 miles so super chuffed.
In the hot weather we've had recently, I've noticed a ticking sound coming from the passenger side front wheel which only seems to happen when it's warm/muggy outside. It happens when the car has been sitting in the sun for some time. I'm going to get the wheel off at some point though have had it up on a jack and can't see anything obvious but if anyone has any experience/suggestions, I'd be happy for it.
Happy motoring all!
Hello to the forum and rotary ownership!
- Has thanked: 6 times
- These users thanked the author HueyCrew for the post (total 2):
- nightfire10 (Fri Jun 11, 2021 1:04 pm) • wreeve (Tue Jun 15, 2021 7:21 pm)
Re: Hello to the forum and rotary ownership!
The noise might just be a stone caught in the tyre tread blocks, if it's connected to road speed.
If it's just at idle then it could be the a/c compressor drive clutch being switched in/out, which is normal.
- Has thanked: 176 times
- Been thanked: 324 times
Hi Rich, if the sound is also happening when the car is still, check the spark plugs are tightened and the leads seated properly at both ends.
Thanks for the replies. It's not a stone as the tread is clear but also, it's not there all the time - only when the outside air temp is on the warmer side.
It's linked to road speed so I'm thinking something linked to the rotation of the wheel assy...
Hi Rich & to the RX-8OC
Hi and Rich. Sorry, no thoughts on your ticking noise from me.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (we are gradually starting them again, they were all postponed for obvious reasons - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Hi GreySilver Beast & Shagrington.
Updated profile - it didn't give me all the options wrt location etc when I signed up... but all done now
Thanks for the tips. I made sure to read a lot before committing to the purchase and so had a looong list of questions about it before I drove her away. I'm doing most if not all of what you've suggested. The last thing to do is join the club which is something on my to-do list!
I'm also using a premix as well as lots of specialists recommend that... That said, the premium fuel seems to give a slightly better mpg, even when "driven"
- These users thanked the author HueyCrew for the post:
- Shagrington (Mon Jun 14, 2021 10:57 pm)
- RX-8: Prospective Buyer
- Been thanked: 3 times
Welcome aboard! Great to hear you are loving your new ride.
