Another new R3 member here
- Colour: Diamond Grey
- Has thanked: 9 times
- Been thanked: 8 times
Hi guys,
another new R3 member here:
- These users thanked the author madein for the post (total 6):
- 30405 (Sat Apr 10, 2021 3:36 pm) • SmuttyHutty (Sat Apr 10, 2021 3:52 pm) • GreySilver Beast (Sat Apr 10, 2021 3:58 pm) • HarSc (Sat Apr 10, 2021 5:54 pm) • nightfire10 (Sat Apr 10, 2021 6:15 pm) • New Duke (Sat Apr 10, 2021 7:31 pm)
- Has thanked: 252 times
- Been thanked: 206 times
Re: Another new R3 member here
Very nice. Where are you located?
- madein (Sun Apr 11, 2021 9:55 am)
Hi & to the RX-8OC
- Has thanked: 569 times
- Been thanked: 526 times
Only one thing I can possibly say about that...
and I love those yellow calipers! proper good!
- These users thanked the author HarSc for the post (total 2):
- nightfire10 (Sat Apr 10, 2021 6:15 pm) • madein (Sun Apr 11, 2021 9:58 am)
Hi and madein. Very nice.
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it with the R3 you do have a redline that rises with the coolant temperature (as shown with the lights on the rev counter) but I still think the above advice is good as it allows time for the oil to warm up too) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (they are all postponed right now I think but may start to happen again in a while) - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- madein (Sun Apr 11, 2021 9:58 am)
Snells Weld and Auto is in Harlow so I am guessing you're Essex/Herts way?
- madein (Sun Apr 11, 2021 10:01 am)
Well that's one way to find out the attention to detail on that photo is insane there Smut
Not much gets past Chief Inspector Smut of The Yard!
- These users thanked the author SmuttyHutty for the post (total 2):
- HarSc (Sat Apr 10, 2021 9:20 pm) • madein (Sun Apr 11, 2021 10:01 am)
New hire for MI6 right here
- Has thanked: 23 times
- Been thanked: 32 times
Welcome to the R3 club!
- These users thanked the author Jester* for the post:
Mazda RX8 R3 - Aurora Blue
Mini Cooper S - Dark Silver
Thank you, doneGreySilver Beast wrote: ↑Sat Apr 10, 2021 3:57 pmHi & to the RX-8OC
- These users thanked the author madein for the post:
- GreySilver Beast (Sun Apr 11, 2021 11:59 am)
Thank you, tool little bit of time for me to like them, but I finally do
- HarSc (Sun Apr 11, 2021 10:56 am)
Thank you, although I red a lot, those are very useful tipsShagrington wrote: ↑Sat Apr 10, 2021 8:53 pmHi and madein. Very nice.
Correct, I'm traveling a lot between London and Harlow,SmuttyHutty wrote: ↑Sat Apr 10, 2021 9:10 pmSnells Weld and Auto is in Harlow so I am guessing you're Essex/Herts way?
Thank you, it is hard to believe how good those cars are for the money you pay.
