evening I'm new here.... but i think I'm here for some years
- Has thanked: 99 times
- Been thanked: 9 times
Bought my first Rx8 231 recently and I love it
I've owned quite a few quick cars in the past but the RX8 is amazing ...... handling, and the engine like nothing I've drove before
if anyone would give me some new owners tips please? that would be great I've bought it blind really don't know much at all but love the car and here to stay as long as possible
any tips please would be much appreciated
one question is do I mix the fuel ? 2 stroke?
I've just filled up and added 150ml to the tank
but the more info the better please
as much info for a noob as possible
Thanks Mark.
Thanks Mark.
Hi Mark & to the RX-8OC
- YORKSHIRE777 (Tue Mar 02, 2021 2:21 pm)
- Has thanked: 319 times
- Been thanked: 257 times
Re: evening I'm new here.... but i think I'm here for some years
Have a read of this section of the forum....
Click here
Being in South Yorkshire you won't be too far from Rotary Revs
Website here
- Has thanked: 568 times
- Been thanked: 526 times
I think his username is a small clueGreySilver Beast wrote: βMon Mar 01, 2021 5:28 pm<<<<<< Please put your Location in your Profile Box, it will help us to know where you are, if required any help in the future
Helloooooo Mark! good to see some more Yorkshire peeps here!
Adding premix to the fuel tank is common with the RX-8s, it's to aid in engine lubrication and generally I believe the normal amounts is around 100-150ml per full tank.
As for newcomers, there is a wealth of information on the OC, notably the buyers' guide here and a lot of other questions are answered in the FAQ section. Anything specific and the search bar is your friend to find anything that members have posted previously
Borrowing Shagrington's advice as below, as it's the best way of saying it for general use and tips for the car -
Shagrington wrote: βSat Jul 04, 2020 10:11 pmHave a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already) here are my best tips for keeping it all running sweetly:
3. Check the oil level regularly (use the dipstick - the oil gauge tells you nothing other than that you have or don't have pressure) and top up if necessary with semi synthetic 5w30 (most people and specialists are advising to use 10w40 now though) ... small amounts at a time, no more than Β½ a litre then check the level again before adding more as you don't want to overfill it.
4. Use all the revs once the engine is nice and warm (don't sit idling to warm up, start up and drive but keep it below about 4k until the needle on the water temperature gauge is pointing straight up, then give it another 10 minutes for the oil to warm up too before really thrashing it ) and hit the beep often. Best acceleration is from 4k revs up - to pull away you really need to rev to 2k - you can let the revs drop after lifting the clutch if you are in traffic, cruising steadily at 3Β½k revs and changing down to go up hills or accelerate gets you the best mpg ... which still won't be great.
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (when we start them again, they're currently all postponed for obvious reasons - if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
Reason: removed the R3 specific sentence from tip #4
- These users thanked the author HarSc for the post (total 2):
- Shagrington (Tue Mar 02, 2021 2:26 am) • YORKSHIRE777 (Tue Mar 02, 2021 2:21 pm)
- Has thanked: 147 times
- Been thanked: 287 times
Regular oil changes,change sparks every 10K or so and if the car has stock ignition leads change them out for magnecor ones.Regarding premix don't worry too much about it,it's not an exact science.The way I used to work it out was plus 20pc,so if I was chucking 50 quids worth of petrol in I'd chuck in 60mils of premix,you get the idea
Hi and YORKSHIRE777. Tips as posted by HarSc above
- Has thanked: 252 times
- Been thanked: 206 times
When someone talks of their first RX8 it is a clear sign that the patient is fully infected with the bug. There is no cure. We can only monitor the situation and send hopes and prayers whilst knowing that the situation is hopeless.
This one, I'm afraid, is well and truly lost to the RX8 virus.
Welcome, Mark! Looking forward to your stories of adventures with your new car. Sounds like you're having fun already.
Another Yorkie in the club, eh? Can't ever accuse this club of being discriminatory if we take Yorkies in!
(I went to boarding school in Yorkshire back when the world was black and white so I can mock with a great deal of affection)
Thanks for the welcome and tips
Loving the car
Loving the car
- Been thanked: 330 times
One thing these cars are prone to is rust damage that starts from the rear arches and then rots out the back of the sills
so if the car is rot free currently then get it rust proofed now
- YORKSHIRE777 (Sun Mar 07, 2021 2:34 pm)
where do you get them rust proofed?
Krown. There's a club member discount as well. Result!
Very true^ Thread for the Krown group buy/club discount is shown here and has plenty of juicy photoshoots of what it does and what other rx8s look like underneath - mine included in that bunch can wholeheartedly recommend going to krown, definitely worth the trip down to Birmingham.
