New Member - JDM Import
mattym85
Forum Guest
Forum Guest
RX-8: Import
Colour: Nordic Green
Post by mattym85 »
Hello, I have just imported an RX-8 from Japan, its an early one 2003 model in Nordic Green and has only covered 25,000 miles. (41k km)
I am a dealer and hope it is ok to be on here, I have joined as a person and not to promote.
We usually only import MPVs but I was offered this and simply could not refuse.
I will be changing as much as possible to UK spec, I have the head unit and sat nav buttons already and just awaiting to see if my speedo guy has the software to convert to MPH (it doesn't have the buttons to switch like some other models). My next job is to buy a uk nav DVD for the rear armrest as unsure if a Euro DVD will update, they are pretty cheap on ebay so will get one and see what happens.
Unsure how to add an image but sure I will figure it out.
Matt
These users thanked the author mattym85 for the post:
nightfire10 (Fri Feb 12, 2021 8:23 am)
nightfire10
Has thanked: 741 times
Been thanked: 283 times
Re: New Member - JDM Import
Post by nightfire10 »
Nice milage, kph to mph on uk one then we only press speedo button, probably not the same on an import, wasn't it expensive to buy then import?
Has thanked: 266 times
Been thanked: 320 times
Post by Shagrington »
Hi and :welcome: Matt. :) Nordic green is a nice and very rare colour these days ... and that mileage at that age is impressive.
mattym85 (Fri Feb 12, 2021 2:29 pm)
SmuttyHutty
Has thanked: 252 times
Been thanked: 206 times
Post by SmuttyHutty »
Shagrington wrote:
Fri Feb 12, 2021 8:36 am
It most certainly is.....
These users thanked the author SmuttyHutty for the post:
Has thanked: 1581 times
Been thanked: 365 times
Post by GreySilver Beast »
Hi Matt & :welcome: to the RX-8OC :thumleft:
<<<<<< Please put your Location in your Profile Box, it will help us to know where you are, if required any help in the future :thumright:
mattym85 (Fri Feb 12, 2021 2:28 pm)
mattym85
Forum Guest
Forum Guest
RX-8: Import
Post by mattym85 »
nightfire10 wrote:
Fri Feb 12, 2021 8:25 am
Nope, only the single trip button unfortunately so looking like maybe software change if possible and a heads up display, I don't know enough about the RX-8 to know if it would be possible to fit a set of uk clocks, if I could find a set that was, automatic.
And yes, it was expensive, but sometimes its nice to just have something special and bring it over and usually the people who buy them are enthusiasts and go to a good home, so always worthwhile in the end.
I will upload a picture once I figure out how to do it, will check the forum for details.
Thanks for the welcomes.
nightfire10 (Fri Feb 12, 2021 2:46 pm)
nightfire10
Enjoy
mattym85 (Fri Feb 12, 2021 2:59 pm)
SmuttyHutty
mattym85 wrote:
Fri Feb 12, 2021 2:33 pm
How to upload pics: viewtopic.php?f=2&t=35968
mattym85 (Fri Feb 12, 2021 3:23 pm)
Has thanked: 442 times
Been thanked: 2086 times
Juey has a JDM import that he not only converted to UK spec but also from Automatic to Manual. =D>
As only a guest on the forum you many not has access to his project thread
viewtopic.php?f=104&t=77722
Which would be an other reason for you to join the OC
https://www.rx8ownersclub.co.uk/members ... Select.php
In the meantime you could try sending him a PM
memberlist.php?mode=viewprofile&u=1034
MRWight
RX-8: Import
Colour: Stormy Blue
Has thanked: 9 times
Post by MRWight »
I have the same problem - Mine was set at MPH but in trying to fix another problem it has reset itself to KM. So I know the car can display it just need to know how? Have you been amor to reset it yet Matt
nitraM Wight
I assume as a JDM it doesn't have the button on the dash, or does it?
MRWight (Tue Jun 08, 2021 2:43 pm)
MRWight
RX-8: Import
Colour: Stormy Blue
Post by MRWight »
warpc0il wrote:
Tue Jun 08, 2021 12:22 pm
Hi Dave - Correct on mine (JDM) it only has 1 button which is the trip button.
Martin
nitraM Wight
Juey
RX-8: Import
Colour: Black Cherry
Has thanked: 8 times
Been thanked: 119 times
Post by Juey »
My JDM had 2 buttons and read in MPH no problem, but is an Evolve model.
If it has cruise control you'll find it only works up to 62 mph (100kmh) due to Japan's speed limits. There's no way of removing this without changing the ECU to UK spec etc.
I don't have the original clocks...can't remember if Pete at Boston Rotary or Nick changed them over for me after the manual swap was done. If it was Pete, he doesn't throw much away in case someone wants it later :lol: so he may have them and were low mileage at around 52k I think.
Other than changing out the stereo (and sat nav) there's not much else needs to be done to get to UK spec unless you have the smaller brakes which can fit 16 inch wheels.
If it's an auto, the box drains a lot of power to the wheels (about 20%) and I'd certainly recommend only driving in manual mode on the paddles as in 'D' it's appalling and wants to be in top gear very early in the rev range. Good on fuel on long trips though as 4th is a very long gear indeed :roll:
Black Cherry Mica
Has thanked: 2572 times
Been thanked: 940 times
Post by ChrisHolmes »
I wouldn’t bother with the SatNav as it’s so outdated image wise and also road wise.
MRWight (Tue Jun 29, 2021 3:35 pm)
GrantRL
Forum Guest
Forum Guest
RX-8: Prospective Buyer
Post by GrantRL »
Sounds like great plans for that car. How's it now? My uncle used to have a 2003 RX8 and it was also green. I'm coming over to his garage this week to help him install the rack and bakflip cover onto his pick-up truck. I'll see if he still got some photos of the RX8.
