New Rx8 owner
- Been thanked: 4 times
New Rx8 owner
Hi,
My friend had an Rx8, the engine went bang and he had some 'Rx8 expert' rebuild it, the rebuilt engine was a disaster leaking coolant from one of the main rotor housing seals and when the alternator supposedly failed we found the handful of swarf they left in the ECU box was causing a short, he sold it before anything else went failed. Anyway the way that car drove kinda stuck in my head, good handling, crazy revs and a power band bit like a 2 stroke, awesome
Fast forward 3 years and i managed to retire a little early and got to thinking about a fun toy to keep me occupied, somehow i remembered the Rx8, cheap to buy, lots of fun and having been in the motor trade for many years i'm not scared of the odd engine rebuild. So, off i went looking at Rx8's.
Now i was expecting some corrosion but the dented rust riddled rubbish i was driving hundreds of miles to look at (and that is just southern cars) was a bit of an eye opener
Long story short, i eventually found a good one and it was only 10 miles from where i live! Unmolested origional 06 plate with 41,000 miles with nearly perfect strato blue paint, lovely, drove like a new car the down side it is a 190hp but i guess i can live with that.
Of course there is rust in the usual places but mostly surface corrosion. After powerwashing the underside it looked pretty grim but a few hours with a needle gun revealed most of this was just staining on the stone chip and no swelling or weakness along the bottom of the sills or chassis. It did have holes starting at the front of the rear wheel arch/back of the sill which needed cutting out and plating and also the lower 3 inches of the wheel arch needed remaking, some seriously difficult shapes to make!
The welding and paint is now done and i'm in the process of dosing every inch of it with Dinitrol
Ade
Ade
- These users thanked the author Yozhek for the post:
- 30405 (Mon Jan 04, 2021 7:11 pm)
Re: New Rx8 owner
Hi and Yozhek Well done on finding a good one - and only 41k miles too. There's nothing wrong with a good 190, there really isn't much difference between that and a 230 on the road and the 190 is actually a bit better to drive in town.
Have a good read through whatever in the FAQ section you didn't already read and then (and just ignore me if you know all this already - I suspect you really won't need my tips) here are my best tips for keeping it all running sweetly:
5. Join the club for discounts on all sorts of things (you will very quickly get the cost of membership back - and then some), loads more info in the members only sections (including access to all the workshop and technical manuals), local meets (when we can start them again - or if you can't find one exactly local it is a good excuse for a drive if you come to one a bit further away), a sexy keyring just for joining and more.
- Has thanked: 508 times
- Been thanked: 453 times
Re: New Rx8 owner
Yozhek, a good story, and I'm pleased to hear you've found what sounds to be a good one.
As Shagrington said, don't worry about it being a 192. The gearing on that model does a lot to make it a pretty fair match for the 231 in the real world. We've done several timed circuit events and the 192 and 231 come in with very similar times. In a tight slalom course, a 192 actually did the fastest times at an event I attended many moons ago.
I'd miss the 9k buzzer though
Re: New Rx8 owner
Can't tell with the flash on that photo, but you mention the car is "Strato Blue", which is a very dark blue. Your photo suggests the much lighter "Winning Blue".
Oh, and your profile states "Titanium Grey", just to confuse
- Has thanked: 569 times
- Been thanked: 526 times
Re: New Rx8 owner
Awesome to see you've managed to find yourself a good one! At least rust-wise, and that's becoming a harder task these days! Top job.
Hey, maybe it's just multicolour camouflage
- Has thanked: 252 times
- Been thanked: 206 times
Re: New Rx8 owner
I'll add to the 192 vs 231 debate. I felt for a long time that I had missed out by not having a 231 and then I bought a PZ. Having driven them both I can say that the ride on the 192 is far more comfortable. The gearing in the 192 seems more sensible for the real world. And waiting for the beep on the 231 takes forever!
I just wish I could get rid of the damn rattles in each of them.
Re: New Rx8 owner
It just keeps going and going and going and going and going and going and going and going and going and going and going and going and going and going and going
...and I love it
Re: New Rx8 owner
Doesn't take long at all in 2nd or 3rd. But you will suddenly be going about 80mph for some reason.
Re: New Rx8 owner
1st......................beep.2nd.....................beep.3rd.........................beep.4th5th6th
- Has thanked: 750 times
- Been thanked: 175 times
Re: New Rx8 owner
What are 4,5 & 6 used for??????SmuttyHutty wrote:1st......................beep.2nd.....................beep.3rd.........................beep.4th5th6th
Re: New Rx8 owner
AutobahnVj4sothername wrote:What are 4,5 & 6 used for??????SmuttyHutty wrote:1st......................beep.2nd.....................beep.3rd.........................beep.4th5th6th
- 30405 (Mon Jan 04, 2021 9:27 pm)
Re: New Rx8 owner
Make me feel like I am being economicalVj4sothername wrote: ↑Mon Jan 04, 2021 9:26 pmWhat are 4,5 & 6 used for??????SmuttyHutty wrote:1st......................beep.2nd.....................beep.3rd.........................beep.4th5th6th
Re: New Rx8 owner
It's called an rx8 for a reason. Any mpg above that is wasted potential.SmuttyHutty wrote:
Re: New Rx8 owner
The words of a man who puts napalm on his cornflakes.
- 30405 (Mon Jan 04, 2021 9:47 pm)
Re: New Rx8 owner
Welcome to the club! Sounds like your diving straight in. Please consider putting a build thread so I can be nosey and steall ideasYozhek wrote:Hi,
Ade
Re: New Rx8 owner
When I was driving my 8 to and from work it was down country lanes... Get stuck behind a tractor or a slow driver... Sat in 3rd gear forever anyway... Would barely need 4th. 6th is purely an economy gear in any car anyway.SmuttyHutty wrote: ↑Mon Jan 04, 2021 9:08 pm1st......................beep.2nd.....................beep.3rd.........................beep.4th5th6th
New Rx8 owner
Hi & to the RX-8OC
Re: New Rx8 owner
Thanks for the welcome and advice
My profile is corrected now, my first purchase was a Titanium Grey 231 that was pretty good underneath but had the roof and bonnet painted due to vandalism. I hate doing bodywork so this is up for sale now.
Repairs are done both sides now and the dirty job of Dinitroling the inside and out is in progress
- SmuttyHutty (Tue Jan 05, 2021 10:29 am)
